Broken screen? Make a giant night light! But...
  • JDC
    • May 2015
    • 273
    To the point: Is there a way I can physically disable the energy saving capability of the TV so it stays on all the time?
    Summary: I inherited a Funai (yeah, I know) TV with a busted screen. I had the idea to remove the busted parts and make a nice light out of it. It works fine but it shuts off after 10 minutes or so, probably due to the energy savings feature of the TV. Any ideas how I could circumvent this feature? Maybe something I could cut or solder on the main board? I was also thinking about making an RCA cable "loop" so the TV thinks there is something plugged into the AV ports all the time but have no idea how to do that.
    Any ideas?
    Re: Broken screen? Make a giant night light! But...
    You can force the power supply and the backlights to stay on so it will not go into standby due to lack of Video signal, you will disconnect the wire between main board and power supply board then use 1K resistor between STBY power supply (5V or 3.3V depends on the set) and the PS-ON pin, and another 1K between STBY power supply and the BL-ON pin, but with this setup the power switch will no longer be active but you add a switch to switch in these two resistors to turn the backlights/power supply on and off.
    If you want dimming control then you will have to use the Analog dimming pin and a potentiometer for adjusting the lamp brightness.
    • JDC
      • May 2015
      • 273
      I'll try that, budm! Thanks!
      • JDC
        • May 2015
        • 273
        Hmmmm, nothing is clearly marked on the power board or main board. I'm sure I could learn how to figure out what is what but I was thinking, I have a ton of RCA cables. I wonder what it would take to rig a "loop" so the TV thinks something viable is plugged into it?
          You could wire it up to a video source (like an old VCR or digital camera), or if the TV has a video output, connecting the output to the input may work sufficiently well.
            It looks for Video signal so I am not sure as to what you are going to loop through to simulate Video signal.
            Pictures of the power supply board/s?
            • JDC
              • May 2015
              • 273
              I have a portable video game system plugged into it and it's still on. I'm looking into making something that simulates a VGA signal.
              • JDC
                • May 2015
                • 273
                Please see attached.
                  Is this you board?
                  Funai A3AFMMPW-001 Power Supply for LF320FX4F ME1
                  http://www.shopjimmy.com/funai-a3afm...upply-unit.htm
                    Remove the flat whit cable from the power supply board first and then
                    put 1K resistor between ALL 3.3V and BL_SW.
                    1K resistor between ALL 3.3V and P-ON-H2.
                    See if the backlights will come on the minute you plug the TV into the outlets.
                    Notes I cannot find the dimming control pin.
                    • JDC
                      • May 2015
                      • 273
                      Like this? It didn't work.
                      • JDC
                        • May 2015
                        • 273
                        Bump.
                          • 31301
                          try connecting the resistors to GND instead of all 3.3v
                          some systems use GND to indicate on rather than a positive signal.
                          • JDC
                            • May 2015
                            • 273
                            No good but on a side note I'm proud of the fact I haven't burned a hole in a board yet! :P
                              Well, you can verify this by removing the resistors, put the cable back in place and measure the DCV on those 3 points when TV is off and when TV is on with backlights to see what you get.
                              As I indicated also that I cannot locate the Dimming control signal pin which it may need for the backlights to come on.
                              • JDC
                                • May 2015
                                • 273
                                P-ON-H2 OFF = .003 BL_SW OFF = .007
                                P-ON-H2 ON = 2.968 BL_SW ON = 3.27
                                Both on and off 3.3 ALL measure 3.34
                                  So what we did with the force on resistors are correct (ACTIVE HIGH), we pull those pins HIGH to simulate the P-ON-H2 ON HIGH and BL_SW ON HIGH.
                                  So put the resistors back on to see if the 1K resistors will provide about the same DCV as shown in your readings.
                                  Both on and off 3.3 ALL measure 3.34' That is 3.3V STANDBY POWER SUPPLY, so that is normal.
                                  I hope it does not require the dim command signals which I do not know which pin that is, unless we look for the spec sheet of the LED driver IC.
                                  • JDC
                                    • May 2015
                                    • 273
                                    Doesn't seem to be any change. Thanks for your help, all. I'm probably going to tear apart a video game system and use that. If anyone has other ideas, please let me know! Thanks again.
                                    • BlueNitesFire
                                      I need Lenovo yoga 6 13ARE05 bios- broken screen and no bright light on keyboard
                                      by BlueNitesFire
                                      So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.
                                      03-08-2025, 03:49 PM
                                    • Ryan.man
                                      by Ryan.man
                                      02-04-2025, 12:23 PM
                                    • Rav_tangle
                                      MacBook Pro 2011 turns on with keyboard light , screen dead
                                      by Rav_tangle
                                      Hi all , thanks for having me & I think this has been asked before but my case seems a bit odd.
                                      I have a MacBook Pro , board 820-2915a and it turns on , chimes etc etc , keyboard lights up, fans spins , can turn caps lock on/off but screen is dead.
                                      Iv tried the resets , shine torch through back logo , nothing , it seems the screen has no power. If I plug charger , it charges but if I disconnect battery it displays green light but won't turn on. Iv tried screen on with another board & it works & seems I'm not getting any voltage at pin 2 , next to ground pin .
                                      is this...
                                      05-31-2024, 04:09 PM
                                    • Alicat
                                      Panasonic Plasma TH-50PZ85U No screen No blinks on red power light
                                      by Alicat
                                      Stopped by this site trying to fix my parents Panasonic Plasma TV.
                                      Model number is TH-50PZ85U
                                      Power comes on and the red power light stays on solid.
                                      Did a few checks like hold the power button on for 60 seconds, hold the - Volume while holding the menu button, no luck, still@ blank grey screen as the screen lights up very vague.
                                      I also hear a few clicks.
                                      I also think my parents said there was a thunderstorm and the TV failed after that.
                                      Section 6 in the service manual talks about power and no screen,...
                                      10-30-2024, 10:09 AM
                                    • reformatt
                                      by reformatt
                                      07-31-2025, 08:37 PM
