Hi all.
I have done a few searches on the forum and read a few posts but still at a loss on what to try next.
Turn on the tv the green flashes fast for a few seconds then the red flashes 7 times.
I started on the SU / SD / SC isolation with the jumper.
SC only - turned on but squeel noise from the SC board.
SC + SD - 7 flashes
SC + SU - worked for a few seconds then pop and now 7 flashes :/
I have gone through the pocket manual i found on a link with the tests and got these results
SU
Pin2 + VF GND 14.1 ohm
SD
pin9 - VF Gnd 34.1 ohm
sc
sc42 vf + pin 3 2.95k
" " + pin 5 5.51k
So as the manual says the SD and SU is bad and the SC is ok.
But why did it pop the SU board.
Im not an expert tech but know enough to see me through everyday life
WOuld someone have any suggestions what to try / test or replace.
thanks in advance.
SC + SD - 7 flashes
SU
SD
sc
" " + pin 5 5.51k
thanks in advance.
