Samsung LN46D630M3F, TV powers on, sound works but no backlight
  • Five_magics
    • Apr 2016
    • 47
    Hey! So I have this LCD TV (Samsung LN46D630M3F) which is my brother's and needs to be fixed, been out of the troubleshooting world for a while, thought I'd ask here. The set is 5 years old or so.
    Basicly, the TV powers on, plays some Samsung tune, and isn't backlit(not even for a second). From what I got told, the TV worked just fine one night, and the next morning it didn't.
    Already ordered an inverter board on a whim, until then I'm trying to see if the power supply isn't at fault. Already swapped all electrolytic capacitors, also checked most semi-conductors and they all seem fine (at least none are shorted). When everything's plugged in and TV is powered on, there's a coil whine coming from the power supply unit for half a second then it stops.
    Took some voltage readings at the inverter's connector tonight, which are;
    LD=10,8v
    13v=12,1
    CNT_PRT (current protection?)=11,6v
    OVP=0v
    GND=0v
    Also tried powering up the set without the main board connected; backlight lights up for half a second and shuts down. Tried taking readings at the inverter connector with the main board/inverter disconnected, but forgot to take notes. Will do it again tomorrow. Didn't bother taking primary readings at this point.
    After a google search, couldn't find the power supply schematic (BN44-00463A), so if anyone has it, that'd help a ton.
    Any help is welcome. Thanks!
  • RCA2000
    • Sep 2014
    • 111
    Re: Samsung LN46D630M3F, TV powers on, sound works but no backlight
    USUALLY...a BL that "lights for a couple of seconds and then drops...is the fault of the BACKLIGHTS--be they CCFL tubes of LED"S.
    Show a rear pix of panel with all boards--and I will get a better idea of things to go on...
    • Five_magics
      • Apr 2016
      • 47
      Like I said, with everything plugged in the backlight(CCFL) doesn't even light up. When the main board is disconnected, it lights up for half a second and shuts off.
      Will take pictures and post tomorrow.
      EDIT: Missed the stickied thread. Sorries!
      • CapLeaker
        Leaking Member
        • 8186
        probably the inverter board.
        • Five_magics
          • Apr 2016
          • 47
          Here are pictures of the main board, power supply and inverter board.
          Took the power supply to work today to test the ESR of caps. Turns out one of the electrolytic I put in is bad (30 ohms+). Also CM801 gives no reading, wondering if that could have to do with the value? I usually measure capacitors above 1uF. You can also clearly see heat marks near it.
            CM801 is part of the main power supply and you are getting the 12V, etc. so that will not be the problem.
            You have power supply-inverter transformers driver board (QI802, QI808 are the power MOSFETs for driving the inverter transformers (3) board).
            Fuse FS802S for supplying the B+ to the Inverter driver circuit is OK?
            You also need to check the cap CI818 (0.47uF) to make sure the capacitance is still within 10%.
            • Five_magics
              • Apr 2016
              • 47
              QI802 and QI808 are okay (at least, not shorted). FS802S is good.
              Tested CI818's ESR which was fine, gonna check the capacitance tomorrow.
              • dick_barton
                • Aug 2015
                • 6643
                • Wales
                Have you measured the primary and secondary sides of the inverter transformers to check that they all have identical readings?
                • CapLeaker
                  Leaking Member
                  • 8186
                  So what cap was bad on the PSU that you exchanged?
                  As already been posted before: You have BLon coming from the main board to the PSU? No BLon no backlights.
                  What DCV do you get on the main filter cap (measure with both leads directly at the cap), should be more than 360V DC. So be careful.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Ahh that's one of them crappy slot in type of inverters. I have had the output connections on them that go to the lamps corrode and not make connection and more. Remove the inverter and inspect the output connections to see if they are worn down. If they are add fresh solder to them, then wick it off and clean the tab with Ipa.
                    • Five_magics
                      • Apr 2016
                      • 47
                      At work right now, CI818 measures at 452nF. Already measured the impedance of the inverter's transformers and theyre all identical (IIRC 0,8 ohms on primaries, 1,2k ohms on secondaries).
                      Will check the main filter caps, BLon signal and CCFLs contacts when Im home, gotta get back to work.
                      • Five_magics
                        • Apr 2016
                        • 47
                        The bad capacitor is the small electrolytic by the main board connector (CI801 I think).
                        • Five_magics
                          • Apr 2016
                          • 47
                          Checked the inverter/CCFL's contacts, seemed fine. Redone them anyways and didn't fix it.
                          BLU_on= 5v
                          Main filtering caps(they're in parallel)=160vdc
                          Checked SMD transistors; one of them (QI816) connected to the BLU_on signal reads 0,570~ and the other junctions read overload. Unfortunatly I can't for the hell of me read what's on it, if anyone has any idea...
                            The backlights inverter requires the boosted Voltage from the PFC/Voltage booster circuit to run, the filter caps should have closed to 400VDC when TV is turned on, so we need to check the PFC section next, starting at PFC diode to see if it is shorted or not, check DP810.
                            • Five_magics
                              • Apr 2016
                              • 47
                              DP810 is good.
                                BTW, when you check the DCV on the filter, the PS-ON signal is present, right?
                                The PFC IC is the 8-PIN SMD ICP801, need to get the P/N so you can get the pin out to find out if it is getting the VCC for it to run or not.
                                • Five_magics
                                  • Apr 2016
                                  • 47
                                  Haven't checked those yet. IC is barely readable, all I can see is 903B, 803B, something like that.
                                  By the way, I haven't heard of PFC circuits before (really only repaired computer monitors and SVDU's (IFE display on aircrafts)), so if you have a good read explaining how they work and everything, that'd be much appreciated, so I at least understand what I'm dealing with. Also, if you have the schematic, I'd love having it, or at least a schematic that somewhat looks like it.
                                    http://www.toms-service-manuals.com/...&typekey=0&p=2
                                    tom66 provides lots of free sch.
                                    You can look through some of the PFC Voltage booster circuits.
                                    Or just search for 'pfc boost converter tutorial', or 'power factor correction using boost converter pdf'
                                    Example in the attached PDF.
                                    • Five_magics
                                      • Apr 2016
                                      • 47
                                      Pics from the circuit around ICP801.
                                      There's a repair kit on ebay that includes ICP801 for this very board, but the P/N isn't listed -_-. Can't read the IC except for the bottom part (which usually isn't the part number, IIRC). If that can help you guys identify it or at least give you some kind of idea.
                                      PIN 4 and 7 are grounded. At least, PIN 4 goes through a ceramic resistor (0,4 ohms?) straight to the ground(kathode of main filter caps). PIN 7 goes to a diode (which isn't shorted), so either the pins are internally connected or it is shorted.
                                      • RCA2000
                                        • Sep 2014
                                        • 111
                                        Are you getting boost converter action--when the set is turned on? You will NOT see this in standby. The PFC ckt ONLY operates in the RUN mode--to reduce current flow and (theory--at least) power draw of the power supply. There should be close to 400 V dc on the filter caps in the RUN mode--around 160 or so in standby. 160 is NOT enough...for run...
                                          09-07-2024, 05:50 AM
                                        • ex250
                                          Kenwood SW-505D no sound issue and pops from time to time when it works
                                          by ex250
                                          Hello mates,
                                          I bought this subwoofer a few days ago used and blind and it works erratically, as far as I could see, it has been tampered with, the speaker is not the original one and of 8 Ohm when it should be of 4, and there are some welds like reworked by the boards.
                                          It doesn't have much power (expected more from it) and it distorts if you increase the volume over the middle, maybe it's because of the high impedance of the speaker. The problem is that it has sound when it wants, the led panels all work correctly, you can hear the power relay on power on, but right now...
                                          12-29-2024, 03:27 PM
                                        • jchang
                                          Samsung UN70NU6900F no picture and no sound
                                          by jchang
                                          Hi all
                                          I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                                          Symptom:
                                          No picture no sound.
                                          When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                                          No sound at all.
                                          What I tried:
                                          1. I tried unplugging the left or right ribbon...
                                          01-09-2023, 06:28 PM
                                        • Ierwin
                                          by Ierwin
                                          05-13-2025, 03:31 PM
                                          09-06-2024, 11:40 PM
