Telefunken T32TX182DLBP NO Turn on - Blinking LED
  • GeorgeVasil
    • Apr 2016
    • 9
    • Greece
    Hello Guys,
    I own this TV for the last 2,5 years (~380 days uptime).
    The TV refuses to turn on and returns an infinite blinking LED.
    It only boots up by itself when the power cord is reconnected to the power source repeatedly, while the antenna cord is removed.
    After watching MrReeceyburger123's troubleshooting videos on YT, I checked the Power Supply (Vestel 17IPS19-5) for shorted Diodes, but none off them gives a beep sound to the multi-meter..
    I also tried to Reset the TV via the service menu but no luck.
    The TV Works fine for hours, if a successful boot happens. but a power off causes blinking LED and no power on..
    Is there anything i should investigate more?
    Looking forward your advice..
    Keep up the good work!!
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Telefunken T32TX182DLBP NO Turn on - Blinking LED
    Hello did you watch my video on how to repair the 17mb82 firmware ? Might need the firmware to be reflashed, if not I will link it.
    • GeorgeVasil
      • Apr 2016
      • 9
      • Greece
      I have seen that video too. But i cant find a firmware :/
      Is the freezing process a must part?
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        You need to find the core update file on the internet then reflash that. Guessing you didnt watch all the video as it shows me doing that
        • GeorgeVasil
          • Apr 2016
          • 9
          • Greece
          I searched this site http://www.vesteldriver.com/
          but i cant find a matching code to my service menu. :/
          So i cant find the file to flash..any help here?
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            It doesnt matter if its for your menu the core update works on all 17mb82 and 95s boards.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              Link to core update:
              http://www.vesteldriver.com/TV_MB82_CORE_UPDATE.html
              • GeorgeVasil
                • Apr 2016
                • 9
                • Greece
                Thanks man! I am struggling to power on the TV again :/
                Another thing i want to mention, is that i can hear a buzz sound every time the LED blinks.
                I will post again about the results!!
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Ok mate, the buzz is normally poor standby oscillation when the Led goes on it loads the standby power a little then off it becomes unloaded but because the feedback is poor so you can hear the transformer switching to supply the standby Led when it goes on lol its normal for Vestel sets though. Also you need to hold ok with the Usb with the core update plugged in it will take a few tries to get it going.
                  • vinceroger69
                    • Mar 2012
                    • 6714
                    maybe freeze whichever chip it has either a eeprom/spi flash this sometimes makes the set start up ok then add the core update.
                    • Diah
                      • Feb 2013
                      • 6560
                      buzz sound not related to Firmware. its much at Video Processing section , include LVDS. check or reset LVDS
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Nothing to do with the Lvds signal but poor standby power oscillation. You would know that up you read further up. Also dont cry about my reply not offending or slating you just correcting.
                        • Diah
                          • Feb 2013
                          • 6560
                          i dont care... i just write what i have on mind... buzz sound when he hearing, mean the the first Bit BOOT passed and PWB turn on. second BIT wont start.. as error.. .. this Firmware construction. eeprom, sip. or what ever you call will have only the first 8 BITS of standby boot firmware.. and he had it as hear buzz sound
                          • GeorgeVasil
                            • Apr 2016
                            • 9
                            • Greece
                            m8!
                            The TV works AGAIN! Thanks for the support!
                            I want to ask you something else:
                            I got some replacement diodes on Saturday from a local store because i was in a hurry.
                            Is it OK to replace the 5404 x2 and 1x 5402 with some 5408's? (The shop owner told me that i won't have a problem..he didn't have 5404/5402 available).
                            Is there anything else to change on the PSU, in order to protect the tv from failing again?
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              m8!
                              Awesomeness glad to hear it worked Also yes they will work fine they have a higher current and reverse voltage so they might actually hold out for longer. Also nothing else really to change on these apart from the diodes
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Also one last thing now that you have done the firmware you need to first time install the Tv and turn the backlight down to low if not an Led will burn out in no time flat lol
                                • GeorgeVasil
                                  • Apr 2016
                                  • 9
                                  • Greece
                                  Yes I have already done that, as mentioned to your video.
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    Good stuff
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      m8!
                                      Have you still got a copy of the core update file you could upload please as the vestel site is now charging for the download
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        Vinceroger69 Is this what you want?
                                        • mar1in
                                          LG UH652T doesn't turn on and stands is blinking once a second
                                          by mar1in
                                          I've got this LG TV here that wouldn't turn on and be stuck in a standby loop (blinking red once every other second).
                                          Did test the following:
                                          * LED's seem fine as they all light up using LED Tester
                                          * Power Supply supplied around 111V for each LED Strips (2x edge lid strips)
                                          * PWR_ON would be at around 3V but dropping every other second (just like the standby light)
                                          * DRV_ON is doing the same
                                          * power supply has a green LED onboard, but that doesn't seem to do anything (stays off the whole time).
                                          * there is a tiny clicking...
                                          11-10-2024, 06:23 PM
                                        • jxrepman
                                          Asus X453MA won't turn on and green led light blinking
                                          by jxrepman
                                          Hi there,
                                          I have this ASUS X453MA Laptop that's not turning on. When I plug in the charger, the green light just keeps on blinking and pressing the power button does nothing.
                                          I have checked the charger and it is giving 19+ V
                                          I have disconnected the battery and pressed power button for 30 seconds.
                                          I tried another RAM stick.
                                          Tried disconnecting the keyboard and touchpad.
                                          Tried disconnecting the HDD and the wifi adapter.
                                          The problem persists.
                                          Hope you could help me out on this one. Thank you.
                                          12-14-2024, 06:40 AM
                                        • pajdek
                                          Lenovo Y700-17ISK turn on and off
                                          by pajdek
                                          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                          09-20-2023, 02:49 AM
                                        • zvvvpnrsa
                                          Telefunken D50U600M4CW does not turn on.
                                          by zvvvpnrsa
                                          Mainboard Vestel 17mb130s 23527519
                                          Panel VES500QNDC-2D-N15
                                          NAND Flash Memory 29F4G08ABAEA
                                          SPI Flash 25L1606E
                                          Hello everyone, I need help, there is a Telefunken D50U600M4CW with a problem that does not turn on, the duty LED is flashing red.
                                          All voltages are present on the power board, I tend to the version that the firmware has flown. I read the dump from SPI Flash 25L1606E, as I understand it, it is broken.
                                          Can anyone share a dump for SPI Flash 25L1606E or fix it, or if possible, is there a firmware for this model.
                                          11-28-2022, 04:39 AM
                                        • my dodge
                                          HP ZBook 17 G3 Mobile Workstation LA-C391p won't turn on and the power light is blinking
                                          by my dodge
                                          Hello
                                          I was looking for a schematic or board view but unfortunately I didn't find anything.
                                          By connecting the drain and source of pq58, the device turns on and works perfectly, but the battery doesn't charge, and I don't know the path of the circuit to the MOSFET.
                                          Is the problem with the adapter? Or is there a problem with the MOSFET activation circuit?
                                          Please guide me.
                                          Thank you.​
                                          12-12-2024, 08:37 AM
