Hitachi 40HXC06U sometimes turn on
  • PhaseCoder
    • Nov 2013
    • 62
    • Uk
    Hitachi 40HXC06U sometimes turns on and runs fine, others just stays on standby and flashes? anyone have any experience with these? im thinking a badcap/s?
    all input will be greatly appreciated.
    thanks
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Hitachi 40HXC06U sometimes turn on
    Thats a firmware fault, guessing a 17mb82-2 ? I will link my video on how to repair it.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Check out my video on how to repair it. Also I had the exact same Tv a few days ago same fault same fix, you also NEED to consider replacing ALL the output diodes on the Psu:
      https://m.youtube.com/watch?v=kPCisa9BYkk
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Also this time can YOU reply to thread if YOU fix it or not ! It does everyones head in if YOU dont reply after we try to help YOU !
        • pajdek
          Lenovo Y700-17ISK turn on and off
          by pajdek
          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
          09-20-2023, 02:49 AM
        • RdeveLabs
          MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
          by RdeveLabs
          To all the members here...
          Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
          So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
          05-05-2025, 04:59 AM
        • robante15
          Acer Aspire 4520 won't turn on after reboot
          by robante15
          Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
          It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
          The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
          If I remove the...
          04-06-2024, 06:50 PM
        • masoksian
          Dell latitude e7470 not turn on .power buton on off and Run Power problem
          by masoksian
          I am dealing with the problem of turning on and off my Dell e7470 notebook.
          The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
          The system does not turn on, there is no post.
          I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
          The problem continues in the same way.
          I tried to turn on the Fn key, nothing came to the screen....
          02-15-2025, 12:08 PM
        • Ledgurra
          MacBook Pro A1425 it doesn't turn on
          by Ledgurra
          hello! hope you are all well. i have a macbook pro a1425 and it won't turn on. i took it to the service center and they said it's fine, it turned on 2 times and then it wouldn't turn on. on the power supply there is a yellow dot that is charging and turns green when charging but when i turn it on it doesn't turn on. i opened it and saw on the motherboard that 2 elements are missing, i am attaching the photos for you to understand better.
          thank you all
          11-09-2025, 06:07 AM
