Panasonic tc50pu54
  • Anderjoppf
    Andy
    • Jan 2016
    Panasonic tc50pu54
    Set has 8 blinks problem, repaired SS module with shop jimmy parts is definitley
    Ok, still same problem, then also replaced a module and sc module still same problem. Checked tp101 on c1 module no short has 3 volts.help! Anyone have any suggestions?
    Anderjoppf
  • AlexVG
    Replacing the WiFi module on a vacuum cleaner iROBOT i7
    by AlexVG
    I have had an iROBOT i7 with a camera error (error 68) version REV M, year 2018.
    I bought a liquid damaged Mainboard with WiFi module, from the same vacuum cleaner, but a different year and a different version (REV G).
    (This board does not respond, only the LEDs light up in a circle.
    The liquid damage is catastrophic and restoration is impractical).
    (I bought this board to get the WiFi module and camera).
    The boards are completely different in the installation of elements, even the connector for the WiFi module is different.
    If...
    10-22-2024, 07:20 AM
  • Andre Gilbert
    by Andre Gilbert
    11-20-2024, 08:52 PM
  • repair-it
    TOSHIBA DLP 52HM95 How to reset timer module on bulb
    by repair-it
    I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
    Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
    10-11-2023, 07:18 PM
  • m1ch43lzm
    70mai Dash Cam A510 - help identifying connector on camera module
    by m1ch43lzm
    Hi everyone
    I have a 70mai Dash Cam A510 which failed after about 3 months of being installed in my car, likely due to heat, i got it from aliexpress so no point in trying to return it for warranty (and shipping it back would cost me almost the same as a new one from ali)
    The camera would boot loop showing 70mai logo on the screen, sometimes it would boot fine then the live view would freeze or display purple lines
    I already took it apart, and found out that the camera boots fine if i unplug the camera module from the main PCB, sometimes "playing" with the connector...
    05-11-2025, 06:02 PM
    Light that has a bug zapper in bottom section of light fixture the LED light module took a crap but the zapper still works
    So I got the bright idea to remove the LED light module from the fixture and put it on top of another enclosure and keep using the zapper
    The removal of light module was a successful and now I just have to cut a hole in the enclosure and put a power cord that has an on and off switch on it
    You are lucky to get about two years of service out of one before the LED module starts flicking and just stops working because it is mounted on an aluminum plate and these are hard to solder on it and it is not worth messing around with them and especially this one because it has line...
    09-07-2024, 07:26 PM
