cracking noises ?
  • ivtec
    • Dec 2008
    • 1967
    cracking noises ?
    Hi guys;i've been wanting to ask some question to owners of Vizio VW42L,
    doesn't show any defects fromthis but i've never seen that on other LCD's.
    My Vizio vw46l making some clicking noises similar to relays on and off upon powering up and shutting down, it only happens just for few seconds and after that it stops,
  • sordids999
    • May 2013
    • 2161
    • uk
    Re: cracking noises ?
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • ivtec
      • Dec 2008
      • 1967
      Thanks sordids99; but i have no issue, tv works fine and has been working find for as long i have it,just would like to know from the owners of this model Vizio VW42L ,if this is normal? it looks like some type of discharging and charging or the power supply regulator clicking on and off while backlight is discharging or charging till caps release charge, i ask this cause i've just fixed a similar specks Vizio GV42L and hear the relay clicking 1 time when turn on, and 1 time relay click when turning off which is normal on all LCD's
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • nbnb
        Vizio VO47L FDHTV30A Picture but no speaker audio, clicking sound
        by nbnb
        I have a Vizio VO47L FDHTV30A. The picture works well, but the sound only works through the RCA output jacks. The sound does not work through the internal speakers or the headphone jack. The TV has a rapid clicking sound when the tv is on that occurs about 4 times per second. The clicking sound volume is fairly low and is not affected by adjusting the internal speaker volume level. The clicking occurs whether or not I disable the internal speaker through the Vizio setup menu. The clicking only occurs while the TV is on.
        Any idea what is causing the clicking sound? Any easy way to...
        11-23-2019, 12:03 PM
      • SS454
        vizio e650i-a2 backlight flashes then turns off
        by SS454
        vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
        panel: au optronics T650HVN05.4
        72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
        link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
        Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
        https://www.shopjimmy.com/vizio-56-0...-power-supply/
        Vizio 55.75J01.001G (91.75J10.004G) Main Board...
        08-20-2020, 03:57 PM
      • Sisko
        Onkyo-593 No power and now clicking sound
        by Sisko
        Hi all!!
        Ok just got a Onkyo SKW-593 sub woofer that has no power person told me that it smoked and that his GF let the volume full when she powered off the amp and when he came to turn it on the sub played but then suddenly smoke was coming out, didn't say from where. So opened it up and saw a resistor made of metal (pic) but can't see any writing on metal par so what ever was written on it was burnt. So I'm kinda stuck here with this. I did ask for a repair or schematics in the other group section and waiting for this but I hope someone here might lend me a hand to try and identify...
        10-03-2025, 02:18 PM
      • mrtek
        Vizio M65-C1
        by mrtek
        Hi.
        picked up another TV. This time is a Vizio M65-C1. TV does not turn on. I had repaired another 60 inch vizio , Bad main board.
        When power button is pressed, the Power led indicator on the bottom right, turns for a few seconds and then it fades away. No backlight or Vizio logo on screen. Removed back cover and repeated test.
        This is the TV This TV is a little different from the Samsung I have worked on. Power supply is on the Left side, Main Bd is on the right side, T-CON , not in the picture is on the bottom. I am assuming that the boards in the middle are the LED...
        07-14-2025, 07:28 PM
