Hello all ~
I am currently working on this Philips 46PFL3705D/F7 that I inherited. When I first turned it on, it showed a picture for about 20 seconds accompanied by a flickering screen and a very loud buzzing/hissing sound coming from the back. That was the only time I saw the picture. After that, I could only get the Philips logo to display for about 5 seconds before the set would shut itself down.
Long story short, I opened it up and traced the sound to a transformer on the PSU. I have ordered all of the caps that surround this transformer (about 9 in total) from Digi-Key and will replace those as soon as they arrive.
I also tested all of the diodes on the entire PSU, and found only one (D662) to be what looked like it might be out of range. I have a PSU from a 40" Philips model (40PFL3705D/F7) to compare the diode reading to, and all of the others were extremely close or close enough to not be of great concern.
However, I am wondering if anyone out there has had experience repairing either the 46" or 40" model of this set and might have some insights that I can utilize as I try to first eliminate the buzzing/hissing noise, and then work to regain both the picture and the sound on this unit.
I have heard that snipping one of the diodes might help eliminate that sound, but I think that was more for a light buzzing noise only in standby mode and that my current situation is more severe than that. Diode 655 was mentioned, but my PSU does not even have that particular diode number.
Hope I tested the diodes correctly. I was getting readings all the way from 153 (the low # from D662 that I intend to replace) all the way up to 913, depending on the size and type of the many (over 50) diodes I measured.
Does anyone have ideas as to what is causing this extremely loud and apparently trouble-causing sound emanating from the transformer on the right-hand side of the PSU, above and beyond the capacitors and that particular D662 diode that I will be replacing already?
One note: When I disconnected the PSU from the other boards, there was no buzzing/hissing present. It was only when I reconnected those ribbons and cables when it returned.
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
