PS60E550 Intermittent Vs On Control Board Issue ?
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Hi badcappers, have the 60" Samsung Plasma here which is showing an image intermittently. When the image works its fine with no distortion however it works intermittently but they set has sound. I took the Y and Xmain out and resoldered a few suspicious joints but the issue is not solved.
    Uppon checking out the Vs and Va rails they seem to come up one time then not the next. I found that the Psu was not being told to turn them rails on as the Vson signal was coming up at 3.3v (working) then falling to 0v (not working). The Vson is generated on the control board, so do you lot think this is the fault ?
    I sure it is but just want some others to confirm as the owner does not want to spend too much on the Tv. Cheers
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: PS60E550 Intermittent Vs On Control Board Issue ?
    Does an externally applied voltage for PS_On bring up Vs and Va each and every time and if so then I would think you are correct.
    The only other thought is if PS_On is buffered from the main processor PS_On via a mosfet or transistor.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Cheers, looking like it had this before on a Lg.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Well chaps the control board is not at fault. Its the Ymain here I was able to find the component causing the issue thanks to the one and only Tom66 mentioning something to me. There is an Ic on the Ymain U5014 which is a 3br0665jz which I think controls something for the Vsus feedback is faulty.
        This as I mentioned in the video (will be uploaded after repair) the Ic has gotten very hot and is breaking down internally, if I freeze spray it the Tv works fine but if I heat it the Tv wont sustain an image. I have the Ic on order and will keep you updated. Here is an image of the Ymain.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          I also have some mini Vga ram heatsinks on order which I will out on the Ic to help it cool. Close up image of the Ic:
          • Soulzink
            Samsug washing machine. Power supply DC41-00189a board issue
            by Soulzink
            I am trying to fix a samsung washinmachine power supply main board.
            I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
            Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
            The power supply board reference is the following: DC41-00189a
            I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
            04-19-2025, 06:26 AM
          • Yanleb
            LG 60PK550 Logic Control Board EBR63450301
            by Yanleb
            Hi all, I just want to share the repair of my 60PK550-UA TV set.
            The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
            But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
            All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
            C57: 3.30V
            C61:...
            07-20-2023, 12:38 AM
          • Asraf Atb
            by Asraf Atb
            01-27-2025, 05:02 PM
          • Stephen
            A2991 Logic Board issue, 20volts 0 amps help!
            by Stephen
            Customer plugged in samsung monitor into the board and used it as a power supply, killed UG800 and UG400. I replaced those two with an exact donor board we had In stock and working, board pulls 5volts and then gets like 2.89 amps on the left side. The singular port is the port that failed. Used a perfectly working chips from donor (board was locked) Now I only get 5volts 0 amps on that power and then 20volts 0 amps on the two left side ports, I checked for DFU and nope nothing, computer not turning on. No shorts present anymore. I am confused as I used the exact components from an identical...
            09-10-2025, 03:16 PM
          • Stephen
            A2991 logic board issue, 20volts 0 amps help!
            by Stephen
            09-10-2025, 03:15 PM
