42lg2100 dead, no standby led help
  • sousavti
    • Nov 2015
    • 27
    • Portugal
    hi all
    tv model 42lg2100
    psu model: eax 55357701/32
    what happens is:
    i connect the main cable power nothing happens completly dead, no standby led nothing... then i measure the +5v of standby and i got 5v on standby voltage, if i disconnect mainboard
    i still got the 5v standby but no led on front
    so what i do is to disconnect the mainboard and turn on psu with a 10k resitor shorted between +5v and pwr on, then i connect maisn cable again with the mainboard disconnected and measure
    the voltages and i got all voltages, +5v +12v and plus 20v, also on inverter error i got 3 volts more or less, so i assume the psu is working....
    i connect again mainboard and i put multimeter on the 5v line and when i press the button i notice that the voltage drop to 2 3 volts and back on to 5v when i release...
    this board has inverter in it so what i do next is disconnect mainboard again, short +5v with pwr on with a 10 resistor to turn on psu and then i short with a wire the pwr on with the inv on
    to see if i have backlights... and i dont have... so the psu is working but i cant have backlights...
    on the board there is two inverter transformers, when i measure the primary it gives 0ohms, when i measure primary vs secondary it gives OL but when i measure the two pins on secondary side i get 0 ohms...
    on both transformers
    here is the image where i get 0 ohms reading:
    http://postimg.org/image/keloc3vor/
    adult image hosting
    each transformer has 2 pins underneath where i put the red circle i think it is the secondary because it goes straight to the lamps after that...
    is the inverters shorted? or this is normal ? i dont know if i should replace the mainboard or the psu ? can you help me please ?
    thanks so much
    Re: 42lg2100 dead, no standby led help
    EAX is the blank PCB number, the PCB assembly should be EAY?????????. What numbers are printed on the barcode sticker?
    Right now we at least know that the main board is not sending the PS-ON to turn on the power supply board.
    The backlights may not come on without the Dimming signal.
    Can see the pictures of the whole back side of the TV and the pictures of the whole board?
    • sousavti
      • Nov 2015
      • 27
      • Portugal
      how do i send the dim singalĀ» do i have to short it too ?
      • sousavti
        • Nov 2015
        • 27
        • Portugal
        when i press the on button the voltage 5v drops to 2 3 volts and then back to 5v.. maybe something is shorted on psu no ?
        • comptek
          • Aug 2013
          • 606
          please post a picture of the full power supply
          bright clear images of front and back thank you
          • sousavti
            • Nov 2015
            • 27
            • Portugal
            ok here it is...
            i only need to know if to turn on the inverter is just short the pwron with inv on ?
            is it normal to have 0ohms of measure on both sides of the both transformers on the secondary ?
            http://s24.postimg.org/49of2du5x/IMG...403_200946.jpg
            http://postimg.org/image/g1cad6os1/
            photo storage
            free picture upload
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              What are the labels on the pins and what voltages do you have on each.
              • sousavti
                • Nov 2015
                • 27
                • Portugal
                ok labels are:
                nc p-dim
                a-dimerroe
                nc inv on/off
                20v
                gnd
                12v
                gnd
                5.2v
                5.2
                gnd
                gnd
                nc power-on
                with psu off i have all 5volts only
                with psu on with a resitor of 10k ohms shorted between 5v and nc power on i have all 5v 12v ands 20v
                on a-dim error i got 3 volts more or less...
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  So it looks as though the power supply is working.
                  If you reconnect the power supply back to your mainboard but disconnect the wire Power_On that comes from the mainboard to the power supply and measure the voltage on that wire.
                  • sousavti
                    • Nov 2015
                    • 27
                    • Portugal
                    i connect the plug normal, and disconnect the wire pwr on on the psu? then i measure the voltage on that pin on mainboard ?
                    do i have to press the button on off when i measure the voltage ?
                    • sousavti
                      • Nov 2015
                      • 27
                      • Portugal
                      i connect the plug and disconnect the wire pwr on on plug on psu, i measure voltage on wire it gives 0.001 or 0.002 volts...
                      if i press on off button it still gives the same....
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        You need to measure the voltage on the Power_ON wire coming from the mainboard (not the power supply) when you switch the set on.
                        • sousavti
                          • Nov 2015
                          • 27
                          • Portugal
                          its what i told you...
                          it gives no voltage 0.001 volts.. the set is all connected and i disconnect the pwr on wirecomign from the mainboard
                          if i press buttons nothing happens voltage still the same....
                          i dont have nothing on front no standby led nothing.. is completly dead...
                          • Diah
                            • Feb 2013
                            • 6436
                            never do such mistake, you have fault on main board, DC to DC conversation, i don't have the service manual of it, but you can follow the wiring of 5 volts on main boards. and put here your thought.
                            • sousavti
                              • Nov 2015
                              • 27
                              • Portugal
                              i didint short it
                              on service manul it says to replace on chip really small its impossible to get this ic...
                              i think its better to replace all main then...
                              is it normal dont have the standby led ?
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                Sorry but just checking that you were measuring the voltage coming from the mainboard and not the voltage on the Power_ON pin on the power supply.
                                If you have no voltage being sent to the power supply from the mainboard then it would indicate that your mainboard is at fault.
                                Can you post a sharp image of your mainboard. Perhaps one of the voltage regulators are faulty.
                                • sousavti
                                  • Nov 2015
                                  • 27
                                  • Portugal
                                  yes i measure on the wire coming from mainboard, and i disconnect on psu
                                  here is the image where the cable enter so i assume is those regulators you talking no ?
                                  http://postimg.org/image/ceftsvxnl/
                                  free picture upload
                                  • Diah
                                    • Feb 2013
                                    • 6436
                                    its okay dear dick_barton yours suggestion always i read here as wise one and exact reasonable facts too
                                    • Diah
                                      • Feb 2013
                                      • 6436
                                      yes i measure on the wire]
                                      could you put the link of the service manual, or upload it here,,, lg main boards are doubled sides not easy to talk on photo
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        The two regulators I can see are marked although there could be more on the circuit board that are not shown.
                                        Can you check what voltages, if any you have on each one. Also check that they are not shorted.
                                        Edit
                                        I have missed out IC801
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • piposarcade
                                          Samsung UN50KU6300 dead no standby led
                                          by piposarcade
                                          01-04-2024, 01:33 PM
                                          Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it...
                                          05-22-2024, 02:07 PM
                                        • jacobtc
                                          LG C1 65'' dead standby
                                          by jacobtc
                                          I've owned this C1 from new since late 2021, and it has now suddenly started with the following symptom:
                                          If power has been connected for a while, the red standby lamp turns off, and the tv wont turn on (no reaction from remote or button on tv).
                                          If power has been disconnected for 5 minutes, the tv turns on fine, until turned off and left for a couple minutes, as the standby light will then turn off again.
                                          I've seached and found that this is most likely a failing PSU, and I've seen repair services on eBay fixing these symptoms, so I am hoping that someone here has fixed...
                                          01-29-2025, 04:27 AM
                                        • piposarcade
                                          by piposarcade
                                          Greetings to all, a while ago my TV was dead, it didn't turn on and the standby light was off, the next day it is working. But these days it no longer wants to turn on, I did some troubleshooting, I disconnected the main board, I checked the voltage on the backlight and there is 400 DC, when I connect it again the main board the voltage drops, in all that troubleshooting, miraculously the standby light comes on and the TV works. After an hour I check and test, I turn on the TV, the Stanby light flashes 3 times and it doesn't turn on.
                                          01-04-2024, 12:03 PM
                                        • jamesp
                                          Acer Aspire A315-55 Dead mainboard
                                          by jamesp
                                          Hello, can someone please help me. i have a dead laptop mainboard, aspire a315-55 with board model DA0ZAWMB8G0 rev. G
                                          upon checking of voltages at s5, 19v is present Vin, 5v and 3v is present at PL6001 and PL6000 respectively, but no signal from MAINON And s5_ON to be able to produce +3v_s5 to give power to vcc of BIOS CHIP U2. MAINON and S5_ON is coming from ec chip U37 it8987e/cx.
                                          do i need to reflash the EC? any advice? thanks...
                                          09-30-2024, 08:24 AM
