Zenith plasma bad thermal resistor on Power supply
  • Nick's Tvs
    • Jan 2014
    • 621
    General question on thermal resistors, please see my scenario below.
    Zenith (Really all LG inside) plasma tv wouldn't stay on. Panel would prime, and then the set would shut off immediately after.
    Did some basic troubleshooting and decided bad PSB. Then started testing all components when I found 2 thermal resistor labeled 5w 22ohms next to eachother. One measured 22ohms, the other open. I don't have any 22ohms 5w thermal resistors laying around, but I do have a few 4.7ohm 5w. I replaced the open one with a 4.7ohm one. My thoughts were (its such low ohms, can't really think it would make a difference at this point since its more of a fuse than anything else at this point right) I boot up the set and it works for 5 seconds, then shuts back off to same symptoms. So I take the board out, and come to find out, the one I replaced is fine, but the second one that was fine before is now open. So I replace that one as well with the same 4.7ohm 5 watt thermal resistor and boot it up.
    TV has been working fine for about 5 hours straight, turned it on and off several times with out a problem. Now I just don't know enough about these to know if it actually makes a big difference. I bought a few extras of these 22ohm 5w thermal resistors online to do a proper replacement, but for general knowledge, does that matter when we are looking at such low ohms? Is it better to go with more ohms less ohms or not ok at all and need an exact replacement.
    Thanks for the info!
    -Nick
  • dick_barton
    • Aug 2015
    • 6643
    • Wales
    Re: Zenith plasma bad thermal resistor on Power supply
    I would attempt to repair it back to factory setting and reinstall the two 22 ohm resistors.
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8352
      As a professional tech you should know the answer what it the 4.7 Ohm thermal resistor does in a place that had 22 Ohm ones in it as inrush current protection.
      So with lower Ohms on the inrush current resistors, the main cap(s) are going to charge faster. They may charge that fast, it could blow the fuse.
      • R_J
        • Jun 2012
        • 9624
        Not sure exactly what circuit this is in but sometimes there is a relay that shorts out the current limiting resitors once the caps. have charged. if the relay is bad ie: burnt contacts, current constantly flows through the resistors, heating them up and they open.
        This may not be the case here but something to check.
        leaving the 4.7 ohm in place of the 22ohm may work but if the tv is left off for a while (day or two) and the caps drain down, when first turned on the fuse could blow or sometimes will weaken and after a few turn ons will open.
        • jinu_j
          by jinu_j
          Hi
          05-03-2025, 10:51 PM
        • mikey5791
          by mikey5791
          Hi to all forum members,
          12-26-2024, 04:55 AM
        • MidnightRoller
          Can a resistor lose resistance after hot air?
          by MidnightRoller
          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
          02-02-2022, 11:46 PM
        • pete g
          zenith plasma tv. the model is Z50PX2D.pix problem
          by pete g
          hi, i have a zenith plasma tv. the model is Z50PX2D. i really love this tv. as of late its coming on with 6 vertical lines of white dots. they flicker, the audio seems to affected also with static sounds. all other aspects of the pic are good. i have good color, and no other problems with picture. can someone help? thanks.
          06-18-2022, 12:10 PM
        • chth96
          Is it okay to replace 1/2 watt resistor with 1 watt resistor in AC/DC adapter?
          by chth96
          I have purchased an 100-240v AC/5v 2a DC adaptor from aliexpress,and a month ago It smelled burning when I plugin it powerstrip.
          Since then, This AC/DC adaptor have been out of order.
          But A few days ago,I replace 0.5 watt resistor with 1 watt resistor(1ohm) in this adapter.
          After replacing resistor,It succeed to recharge all of android phone.And When I measure voltage on the two pins of USB port,It shows 5.5v
          And Is there any possibility that it will suddenly explode as well as to be out...
          12-03-2023, 04:40 AM
