blaupunkt 32/146L-GB-6B tp.msd309.bp 85 restarting
  • ReeceyBurger123
    replied
    Re: blaupunkt 32/146L-GB-6B tp.msd309.bp 85 restarting
    Originally posted by Diah
    there are temporary solution, it can be work, dont put any signal or cable in the tv, just the AC one, turn it on, it will stay on... then go to system menu and reset it.
    Please read the thread properly.
  • Diah
    replied
  • comptek
    replied
    Originally posted by sordids999
    i could try it although im unsure what the difference is with 5B TO 6B ?
    could be how many hdmi or usb ports, hd ready or full hd i dont know Sordids
  • sordids999
    replied
    Originally posted by comptek
    I have 2 boards here and led strips
    But they're 5B not 6B any good to you?
  • ReeceyBurger123
    replied
    I would say try the mainboard, these Tv's actually are worse than Vestel Led sets IMO.
  • comptek
    replied
  • ReeceyBurger123
    replied
    Originally posted by budm
    that sounds like main board problems to me.
    +1
    replied
    That sounds like main board problems to me.
  • sordids999
    replied
    So it keeps restarting, and still doing the same without LED connector (the one with RED/WHITE wires).
    Will it also restarting if LVDS cable is also disconnected?
    And how do you stop it from restarting? Unplug the AC power cord or you can still use the power switch or the remote to turn it off?
    Hi budm
    First question is yes
    Second is yes
    Third question is unplug the AC power cord
    replied
  • Diah
    replied
    when he remove the first front frame, put LCD on face on clean table then left it fro other, so it will stay as its, same way to to bring it back. place chassis frame on the lcd which grounded on the table
  • ReeceyBurger123
    replied
    Hmm I dont think so but worth a try to check it, also be very careful the Lcds in them are paper thin.
  • sordids999
    replied
    Thanks ill open it up and take a look and hopefully report back
  • Diah
    replied
    you have bad led open and one shorted
  • sordids999
    replied
    No i only have literally one second before the backlight goes off
  • Diah
    replied
    did you see picture on the screen when you put flash light?
  • sordids999
    replied
    if you mean unplug the backlight ?
    then its still the same i thought that i found a diode that was shorted but once removed from circuit it was fine
  • ReeceyBurger123
    replied
    Hmm doubt the Bl would be causing that though. It should work with the Bl on or not, what happens when you in plug the Bl ?
  • sordids999
    replied
    Originally posted by ReeceyBurger123
    Preprogrammed one from OHM supplies.
    correct
    and no sound or image backlight lights up for about 2 secs then restarts in a loop
  • ReeceyBurger123
    replied
    i see it seem the photo on first post before replacing eeprom... sorry....
    No worries lol
  • Takeatry
    Yet another Samsung QLED Boot Loop
    by Takeatry
    Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
    10-04-2024, 02:57 PM
  • murko1
    HP zbook 17 G3 T7V35ES - endless restarting pre-POST loop
    by murko1
    Hello community,
    I am hoping that you could help me diagnose and find solution for my problem with HP ZBook 17 G3 T7V35ES.
    I will try to describe my problem by posting exactly what I asked on official HP support forum, on reddit, etc.. (basically everywhere I posted, but got zero solution/help).
    Original post from 14.12.2020 at HP Support Forum : (link here)
    Hope you read it all, because I will continue the story - after around 4 months from the time I wrote that original post - the notebook turned on correctly...
    05-13-2021, 11:03 AM
  • blaster_
    Samsung UE49MU6105K - boot loop, horizontal lines
    by blaster_
    Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
    Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
    06-22-2022, 05:19 PM
  • Stefano Crivellari
    Lenovo Legion 5 (15ITH6H) kind of boot loop but not sure
    by Stefano Crivellari
    Hi, I wonder if anyone can help me fix my Lenovo Legion 5 (15ITH6H) laptop. Basically, after a windows update the computer would not boot anymore. When powering on the laptop the screen has no backlight and nothing would show up, using an external monitor did not help. However, the laptop would still spin up the fans and turn on the keyboard backlight. The keyboard backlight intensity function key would work and the power button led and the charging led are also working. I've tried every possible combination of key press and power button hold down time but did not change anything. At this point...
    01-14-2025, 03:49 PM
  • ferah831208
    HP gaming 15-0013dx quanta G3HA no video, screen polarize on and off loop
    by ferah831208
    I have an HP gaming 15-0013dx laptop , motherboard quanta G3HA with AMD Ryzen 5 cpu and Nvidia discrete grsphics card. The laptop turns on and u can see the screen polarizing on and off in a loop but no video signal. All voltages are ok measured and stable (I checked all with oscilloscope). This schematics don't have power sequence but I'm using a similar sequence from another laptop with AMD CPU and I get all to the point CPU must release apu_pwrok and apu_rst#, this signal comes valid only for the period of time the screen is polarized and they disappear and same loop behaviour (active/inactive)....
    12-07-2024, 04:02 PM
