Vizio P50HDTV10A powers on no video
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    Just picked this up for free. The set powers on, led is yellow on standby, when I press the power button, it turns green but nothing comes up on the display.
    Will post pics in a bit. Boards seem to be lg.
  • sordids999
    • May 2013
    • 2161
    Re: Vizio P50HDTV10A powers on no video
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • Malachi
      • Dec 2015
      • 1077
      • Usa
      Here are the pictures. There are bulging caps on the pcs, with some showing leakage.
      This seems almost a clone of the P50pc3d I just fixed, it had bulging caps but it didnt completely solve the problem.
      Replacing the caps on that one allowed it to power on with some display and then with help from the forum, figured out it was the ysus.
      This one shows nothing on the screen.
      • Malachi
        • Dec 2015
        • 1077
        • Usa
        I think this picture of the back is better.
        • Malachi
          • Dec 2015
          • 1077
          • Usa
          Ok, I guess I should replace the caps then. No one seems to have an opinion.
          • whiz62
            whiz62
            • Dec 2013
            • 242
            • usa
            I am by no means an expert, but I would for sure replace all bad caps and ESR test the others if you have a ESR meter.
            • Malachi
              • Dec 2015
              • 1077
              • Usa
              I don't have an esr meter. I just ordered the bulging caps replacement from digikey.
              • vinceroger69
                • Mar 2012
                • 6714
                This thread has some good info on regarding voltage testing etc maybe worth a read.
                https://www.badcaps.net/forum/showth...zio+P50HDTV10A
                • Malachi
                  • Dec 2015
                  • 1077
                  • Usa
                  Thanks vinceroger69, I had already tried disconnecting the Ysus then the Zsus and nothing changed.
                  I've already put the back on the TV and carried it out to the garage as we have company tomorrow for Easter and needed the room.
                  After I replace the caps, I'll install the psu and see if there is any difference. I'll then check those voltages if there us no change.
                  I had read that thread but being new at this I'm still kind of scared testing for voltage when I see numbers that high so I was waiting for advice. Lol
                  • JaquesPratt
                    Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                    by JaquesPratt
                    I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                    This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                    07-16-2024, 01:04 AM
                    HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera EliteDesk 800 i7-7700 Specification for Upgrade or Repair
                    This specification for the HP EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera boardview and EliteDesk 800 G3 + GoPro HERO6 Black 4K Ultra HD Video Camera schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our...
                    09-12-2024, 02:00 PM
                  • csmith
                    Vizio D50u-D1 Powers up no picture
                    by csmith
                    I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                    Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                    supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                    issue. Set will power up with remote but not power off....
                    07-11-2025, 11:52 AM
                  • Chivo77
                    DELL LATITUDE 5420, ST 20TFKN3, LA-K491P REV:2.0 (A01) powers on and die about 15 secs later, no video
                    by Chivo77
                    hello friends, I have a DELL LATITUDE 5420---MODEL P137G, ST 20TFKN3 LA-K491P REV:2.0 (A01) and its quite a challenge. It powers on with the battery disconnected, lasts on for about 15 secs, and then shuts off. It does the same with battery only (no adapter). With battery and adapter it sometimes starts after hitting the button several times. It displays nothing in every case. Since only the Boardview is available, I guided myself with schematics similar to this laptop (I'll add them down).Some measurements:
                    1- After receiving power SIO_SLP_S0# goes high and never changes.
                    2-every...
                    07-03-2025, 09:20 AM
