I have had several LG tv's in the past that gets stuck at the LG logo so when I got this one I was pretty sure the eprom was bad. When I took the main board out a IC fell off it and there were several more that were suspicious. So my question is does anyone know where to get a good main for this tv. I see there are several different models for it. The one in the tv is EBR66043801.
Lg 47le5400
by cheeky2I suppose the real question is whether the existing pinouts from ether a 17IPS71 psu are cross compatible with a 17IPS12 psu? If they are then the exchange of the main boards should have no issues providing the screen is compatible with both main boards. Obviously you can change the screen configurations easily enough (providing you have the correct files) for the main board. Why may you ask would I do this? Well a lot of the smart features are no longer working on a Hitachi 48HBT62U main board I wish to give it a new lease of life!
Obviously the same LVDS connector for the screen connection... -
by Dani_2024Hi and thanks in advance for any input you might provide!
Last Sunday I was watching a dvd and fell asleep for about half hour, when I awoke the tv screen was black and couldn't get the dvd menu to show, so I changed the input to antenna and had sound but no picture, turned it off. I then got online and found this great site! ....read many troubleshooting tips and this...5 Photos -
by ygorsanHi everyone,
Iām looking for help with a persistent issue on an LG TV model 55NANO77SRA, which uses the main board EBU66792103 (also used in LG UQ80 and NANO75/NANO80 series).
š§© Problem Summary:- The TV keeps scrolling through the menu or selecting items by itself.
- I removed the physical button board (the entire panel with power and volume buttons) and also disconnected the flat cable (CN202) from the main board.
- The remote control is not in use (batteries removed), and the TV still shows the same behavior.
- I
07-28-2025, 08:34 AM -
by Asraf AtbHi everyone,
Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....1 Photo -
by JSin21Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
I have Samsung Smart TV UA65MU6100WXXY version DA01
Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...4 Photos - Loading...
