Samsung UN40D6400 led problem
    Re: Samsung UN40D6400 led problem
    Originally posted by Malachi
    I already did that. Post #31.
    OK I did not know if that the reading of just one +pin or all 4 +pins.
    The result is telling us that when all connectors are in the place, the one with reading of 325V is not seeing the load so the Voltage is same with and without the connectors (Loads) in place, as you can see when the loads (connectors removed) are not connected to the other 3 output Voltage of all three went up high.
    • Malachi
      • Dec 2015
      • 1077
      • Usa
      #42
      So what does that tell you?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        #43
        It confirms that the fault is with the leds and not led driver circuit.
        • Malachi
          • Dec 2015
          • 1077
          • Usa
          #44
          Ok so both strips are bad at exactly the same spot.
          I looked for the led strips, considering the price for both and that I paid $50 it's not worth it to buy led strips and fix it.
          It's more logical to sell the board.
          • Diah
            • Feb 2013
            • 6614
            if i am in your place would not buy strips, just replace dead LEDs,
            CH1 bad from the test you did, follow it wiring to side strips and check Leds on
            you have 72 Leds on side, / 2 make 36 on CH1, and CH1 had 3 groups mean 36/3 make 12, from this 12 you have one Open or more. they are not hard to replace at all.
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              #46
              There was a discussion on this board within the last few weeks about cheap LEDs being purchase directly from China at a very low price. I'll see if I can locate the thread.
              • Malachi
                • Dec 2015
                • 1077
                • Usa
                #47
                It looks like one solid piece of aluminum with the LEDs on it. No breaks anywhere.
                • Malachi
                  • Dec 2015
                  • 1077
                  • Usa
                  #48
                  You can see it here. http://www.tvparcasi.com/ltj400hv02-...72-bn64-01640a
                  • Diah
                    • Feb 2013
                    • 6614
                    No, you have screw first to move , then the Strip should pushed to outside forward to the socket direction, the Alu of the strip had an hole being in pin of the base, by pushing it to the direction of socket the hole and the pin will be in center to left it out
                      +1, and how we go about finding out where the problem is.
                      • Malachi
                        • Dec 2015
                        • 1077
                        • Usa
                        #51
                        I see the screws but I searched for the LEDs by the number on the led strip themselves. The only ones I found are in that link.
                        • Diah
                          • Feb 2013
                          • 6614
                          i wrote to you.. they are 7030 6 volts, https://www.badcaps.net/forum/showthread.php?t=52847
                          • Malachi
                            • Dec 2015
                            • 1077
                            • Usa
                            #53
                            Sorry Diah, I told you I didn,t understand what you were saying.
                            The ones in your link don't look like mine.
                            • Diah
                              • Feb 2013
                              • 6614
                              on my post above the replacements of the LED Module.
                              you have total 72 LEDs, does not matter which LED power on or not, just with your measure netter Diode option check one by one, and evry one open or had less Ohm at reading than 750 mark it and replace it. same things if there shorted one
                              • Malachi
                                • Dec 2015
                                • 1077
                                • Usa
                                #55
                                How do I replace individual LEDs on this thing? It's beyond my skill level.
                                • Diah
                                  • Feb 2013
                                  • 6614
                                  this kind of strip very easy to replace all in one hours lol
                                  Leds of one Group if you took one by broken it, and with shaving plate clean the bed on the line to next led, and put solder, set the LED in place and just heat the solder between the lEDs they will be tight on boards.
                                  hand soldering not air
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    #57
                                    You need to use hot air IMO hand soldering simply melts the led even if your careful.
                                    • Diah
                                      • Feb 2013
                                      • 6614
                                      you are wrong. cause the soldering will be heat between leds not direct on led pin.
                                      • Malachi
                                        • Dec 2015
                                        • 1077
                                        • Usa
                                        #59
                                        I tested the LEDs with my meter. 18 LEDs on each strip don't lite but 36 if them, when tested with my meter set like this show a number. The rest are all 0.L
                                        • Malachi
                                          • Dec 2015
                                          • 1077
                                          • Usa
                                          #60
                                          I don't think I can solder them. And I don't have a hot air machine.
                                            09-07-2024, 05:50 AM
                                          • alro7779
                                            Samsung UN55MU6103F video problem; has colored stripes on the display
                                            by alro7779
                                            Hello, everyone!
                                            A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                            09-27-2025, 11:29 PM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
