Samsung UN40D6400 led problem
  • Diah
    • Feb 2013
    • 6440
    Re: Samsung UN40D6400 led problem
    change yours metter on diode beep lol
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      #62
      I don't know if the leds could be stripped of this unit to repair your set. Each operates at 6V.
      http://www.iccfl.com/product_info.php?products_id=21544
      • Malachi
        • Dec 2015
        • 1077
        • Usa
        #63
        Is there in interchangeable led strip I could get or am I stuck with one with the same exact number?
        I'm telling you guys, I don't have the skill to change these little LEDs.
        • Diah
          • Feb 2013
          • 6440
          this is not what he have on this tv.
          • Diah
            • Feb 2013
            • 6440
            you need to trust your self, if yours hand soldering iron had the solder head 0.5 or 1.0 mm you can do it easly.. believe me,, i did it and no way of mistake even you exchange all the 72 leds
            • Malachi
              • Dec 2015
              • 1077
              • Usa
              #66
              When I do that, they don't beep.
              I think I'm done with this TV. Time to scrap it. Thanks for all the help guys.
              • Diah
                • Feb 2013
                • 6440
                your choice, but when no beep it show you the residences of the led if its below 700 it mean leaks.
                • Malachi
                  • Dec 2015
                  • 1077
                  • Usa
                  #68
                  None of them beep so that means they are all bad? But we know that only 18 out of 72 don't light.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    #69
                    Come on Diah you should know that they shouldn't beep if so that means they are shorted. Normally test them and see which one does not light. Reverse bias your meter leads in diode mode and test the Leds see if any do not light.
                    • Malachi
                      • Dec 2015
                      • 1077
                      • Usa
                      #70
                      I done even know what that means. Lol.
                      I do have a pc psu rigged up like you did in your video. Can I use the. 5v on each led? One lead on one side and one on the other?
                        His meter cannot light up LEDs that are in series internally with Vf of 6V, it probably does not put out enough Voltage to bias on the two 3V Vf LEDs connected in series.
                        He can put two white LEDs in series and find out if his meter is capable or not.
                        Internally the LED also has protection diode connected in antiparallel fashion.
                          09-07-2024, 05:50 AM
                        • alro7779
                          Samsung UN55MU6103F video problem; has colored stripes on the display
                          by alro7779
                          Hello, everyone!
                          A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                          09-27-2025, 11:29 PM
                          09-06-2024, 11:40 PM
                          09-06-2024, 08:40 PM
