Samsung UN40D6400 led problem
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    Re: Samsung UN40D6400 led problem
    Originally posted by Diah
    okay, i saw the photo,
    you have each side had 2 strip separate each one had 3 Group , each Group had 12 Diode
    its 7030 6 Volts Diode,
    Ok? What does that tell us? Do I need a new psu? Lol
    • Malachi
      • Dec 2015
      • 1077
      • Usa
      With my meter in diode mode this, I assume, diode beeps everyone I test it. It's on the board but none of the others beep.
      • Diah
        • Feb 2013
        • 6438
        you need LEDs one by one by as Diode measure them, not as power them.
          Your board is Samsung BN44-00427B (PD46B2_BDY) Power Supply / LED Board?
          http://www.shopjimmy.com/samsung-bn4...upply-unit.htm
          • Malachi
            • Dec 2015
            • 1077
            • Usa
            Also bbs801 beeps but I don't think it's a diode.
            Also another one like it labeled bbp801 beeps.
            • Malachi
              • Dec 2015
              • 1077
              • Usa
              #26
              Correct budm, it is.
              • Malachi
                • Dec 2015
                • 1077
                • Usa
                #27
                I'm sorry Diah, I don't really understand what that means.
                • Diah
                  • Feb 2013
                  • 6438
                  you saied some Leds on back light not powring up. u need to check them if one Diode shorted then all strip die.
                  • Malachi
                    • Dec 2015
                    • 1077
                    • Usa
                    #29
                    As the pictures show 3/4 or more of the LEDs work.
                      Check the CH1+, 2+, 3+, and 4+ (Anodes Voltage feeding pins) one at time by leaving the probe on one pin at a time and see how high the Voltage goes up too and then drops down, do that on all 4 + pins, Black probe on the chassis.
                      The drivers has 4 boost converter circuits to feed 4 stings of LEDs.
                      Pictures provided by shopjimmy.
                      • Malachi
                        • Dec 2015
                        • 1077
                        • Usa
                        #31
                        I appreciate the help budm, do I touch those with the red lead and black to ground on the chassis? Can I do it with the led unplugged?
                        With the led unplugged the all got to about 320v for the high and then to about 240v for the low.
                        And then it cycled back up.
                          OK, LED connectors in place, Black probe on the chassis, red probe on the CH1+ pin, you to have leave the Red probe on the pin then turn the TV on and look at your meter when TV is turned on and then wait may be 5~10 seconds to see if the Voltage drops down, repeat the same on the other 3.
                          • Malachi
                            • Dec 2015
                            • 1077
                            • Usa
                            #33
                            Ok. Connector in place ch1 high of about 325v, low of about 225v, ch2, ch3 and ch4 about 116v high and about 90v low.
                            • Malachi
                              • Dec 2015
                              • 1077
                              • Usa
                              #34
                              Do you mean unplug it to see what it drops down to? Because I don't get 5 to 10 seconds before it turns back on.
                                OK, as you leave the red probe on CH1+, you turn the TV ON then you see the Voltage jumps up to 325V and also see the backlights flash on then the backlights go out and the Voltage drops down to 225V, is that correct?
                                • Malachi
                                  • Dec 2015
                                  • 1077
                                  • Usa
                                  #36
                                  Correct. Give or take 1 or two volts. It goes so quickly it's hard to see.
                                  Just did it again. I guess the low was about 250v.
                                    And doing the same to the other 3 and they do not show the same result as CH1+, is that correct?
                                    • Malachi
                                      • Dec 2015
                                      • 1077
                                      • Usa
                                      #38
                                      Correct. 116v high about 90v low.
                                      Do I need a psu?
                                        OK now do it without the LED connectors in place.
                                        They should all show high Voltage and really close readings to each other.
                                        • Malachi
                                          • Dec 2015
                                          • 1077
                                          • Usa
                                          #40
                                          I already did that. Post #31. I did the edit I think as you were typing #32
                                            09-07-2024, 05:50 AM
                                          • alro7779
                                            Samsung UN55MU6103F video problem; has colored stripes on the display
                                            by alro7779
                                            Hello, everyone!
                                            A co-worker gave me a 55-inch Samsung TV model UN55MU6103F so I can try to fix the following problem... As soon as I plug it in to the wall, the TV turns on, and the display shows a few stripes all over the screen. I took off the back cover and disconnected both ribbon cables that go to the display (one at a time) so by doing that I can narrow down the bad section of the problem, but in both cases the display turns black. I know there are some voltages that I have to check (VGH, VGL, etc.) but don't know what reading each has to show. If anyone could guide me on this,...
                                            09-27-2025, 11:29 PM
                                            09-06-2024, 11:40 PM
                                            09-06-2024, 08:40 PM
