I have replaced the psu for a friend on this tv twice now. So I bought him a brand new psu. Don't ask me why. Anyways no I have no HDMI or tuner. The component and composite inputs work though. I had a spare seine but it just gives me 3 red blinks so it's either a faulty seine or needs programming. After reading other posts, it would seem it's the seine board. Ideas?
42HL196 No HDMI?
by jackclementsHello,
I have replaced the psu on this Toshiba 42HL196 twice. I have no HDMI or tuner. The component and composite inputs work though. I had a spare seine but it just gives me 3 red blinks so it's either a faulty seine or needs programming. It would seem it's the seine board. Ideas? -
by aliougmI have problem with my AVR(Marantz SR4003) HDMI board issue. I connect to my TV but screen color distorted,see attached picture.
Connection as below:
Set-top box HDMI output >AVR 3 HDMI input/one HDMI output>HDTV HDMI port
If I bypassed AVR then HDTV screen color be good.
I take out HDMI board from AVR and check services manual the schematic shown the HDMI signals path:
3 HDMI input port > SIL9185 chip(HDMI switch) > SIL9033 chip(HDMI receiver) > SIL9030 chip(HDMI transmitter) > HDMI output port
I replaced all... -
by japlyticWith a setup including a TV and AV receiver where HDMI Consumer Electronics Control (CEC) and Audio Return Channel (ARC) functions were working, these two functions stopped working after changing some connections (not the one between the AV receiver and TV), so I believed it was a corrupt setting in the AV receiver or TV, but when I disconnected a passive DisplayPort-HDMI cable (which a Multimode DisplayPort connector supports HDMI with a low cost passive cable or adaptor) connected to a home theatre PC, HDMI CEC and ARC functionality was restored.
An examination of the HDMI CEC wiring...07-10-2022, 09:48 PM -
I have this TV hooked up to only an AppleTV 4K and a Creative soundbar. Originally HDMI-CEC and HDMI-ARC wouldn't work at all, I replaced all the HDMI cables with decent UGREEN cables meeting the latest standards, now it all works perfectly but once or twice a day the TV itself reboots while watching a program, the AppleTV keeps running. I haven't fully pinned down whether it is ARC or CEC causing it yet. All are running latest firmware.
I assume it is just HDMI-CEC being buggy as usual on a shitty Vestel machine, but can anyone think of anything I can try before disabling it? -
LG LCD TV picture comes on intermittenly using hdmi port.The sound is on permantly.The hdmi ports looks fine and soldered in securely.The 3.4v coming to the main board is not present(not sure if will affect the hdmi port or where that voltage goes.)The hdmi cable is fine because it works on another tv.The ceramic caps connected to the hdmi controller ic is reading 39 ohms.Could the hdmi controller ic be faulty(feels very warm to touch).The RCA jacks work normally .Thank you in advance for your assistance..
- Loading...
