LG 42LC2D Interesting Capacitor
  • zacheriaj
    • Jan 2014
    • 138
    Obvioiusly the samxon caps are bad, but look at the larger 2200uF cap on the far right. I've never seen a cap do this where the sleeve drops from the can. Has anyone else seen this? The cap itsself tests ok so i'm thinking probably just from heat or a faulty sleeve.
    You Can't Succeed Until You're Willing to Fail
  • tech2014
    • Aug 2014
    • 807
    Re: LG 42LC2D Interesting Capacitor
    thats different lol. I take it this is out of a Samsung.
    • zacheriaj
      • Jan 2014
      • 138
      It's an old 2006 model LG 42"lcd. Nabbed it for $20. I don't miss the weight of the older LCD tvs. 85 lbs!
      • tech2014
        • Aug 2014
        • 807
        cool, never seen domed caps on an LG. Yeah I hate the old ones too, very heavy.
          • 31288
          the short sleeve means it's totally cooked!!!
          the sleeves on caps are made from thin heatshrink sleeving.
          • zacheriaj
            • Jan 2014
            • 138
            have you ever seen it where the casing of a cap shrivels down like that? Even though the cap is fine? haha
            • steviewonder
              • Dec 2013
              • 183
              • england
              This was very common back in the 1970's and 80s,particularly the black nichicons.Some may remember hitachi TV's with this issue-think the plastic sleeve was not as heat resistant as the cap itself!
              • MORETTIGIAN
                Capacitor detached from PCB – RTX 2070 Super Founders Edition
                by MORETTIGIAN
                Title:
                Description:
                During maintenance on an RTX 2070 SUPER Founders Edition, I found a capacitor lying on my desk after reassembly.
                I did not notice it detaching, so I am unsure of its original location on the PCB.
                Procedure performed:
                - Removed backplate
                - Cleaned heatsink and PCB with isopropyl alcohol + soft ESD brush
                - Reapplied thermal compound
                - Reassembled card
                Observed behavior after reassembly:
                - GPU powers on and operates normally under...
                09-18-2025, 12:14 PM
              • Prolog
                RTX 3080 FE Identifying capacitor
                by Prolog
                Hi people, I hope this is the correct spot to post this, I'm new to the forum.
                I have an RTX 3080 Founders Edition which has a burnt up capacitor (it was in parallel with another capacitor which appears damaged too), so I am hoping to be able to identify the capacitor values and order replacements.
                I hope these photos make it clear which component I am referring to:
                (yes, the soldering is a bit botched from removing the blown one, I know)
                I have found the board schematic (attached), but there does not seem to be a boardview available. I have never...
                12-01-2024, 08:27 PM
              • Agent24
                Dick Smith Q-1760 linear power supply filter capacitor question
                by Agent24
                I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
                It has at least one problem.
                The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
                I have already ordered a replacement potentiometer, so that's not an issue.
                Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
                All are CapXon...
                10-21-2025, 05:39 PM
              • chth96
                If I replace with inferior capacitor, Is it No harm to other IC components at all?
                by chth96
                I replaced some capacitor which is located on optical pickup pcb which is shown in the table below(PCB #2).Because it have been out of order.
                Now,It works very well,But I just have found that all caps (6svpc100my and other part number as well) ,which is shown in the table below, has ultra-high ripple current spec.
                It is not able to obtain any capacitor which can be a substitute for this ultra-high ripple current nichicon capacitor.
                So I replaced it with samxon and rubycon's general capacitor(GP,YXA series).
                I know that these capacitor will not last as long as nichicon capacitor...
                12-22-2023, 04:34 AM
              • chth96
                How can I test non-polarized capacitor?
                by chth96
                I desoldered samwha NF capacitor(50v 5.6uf) from PCB circuit of 29inch CRT TV which have symptoms of no display after I heard sound of inrush of current to TV whenever I switch on this television.
                I measured ESR value of this non-polarized capacitor(samwha NF capacitor 50v 5.6uf) by means of MESR-100 ESR meter and It displayed 0.3 ohm
                And When I measured its capacitance with digital multimeter and LCR-T4 Mega328 meter, It displayed 10uf from DMM and 8uf from LCR-T4 meter.
                I found catalogue of samwha capacitor(samwha-catalogue_3.pdf file), which is attached to this thread,...
                06-02-2024, 07:31 PM
