TC-P50X5, solid red LED, no blinks, no prime, no picture or sound
  • johnboy1313
    • Nov 2012
    • 1959
    I picked up a TC-P50X5 a while back with the no power issue common with this PSU. I ordered the IC and replaced it which brought the set to life. I buttoned it up and called it fixed. When I went to sell it, I plugged it in and tried to turn it on. The LED on the front lights solid red and stays lit. The optical audio out on the main board lights for a second, then turns off. Voltage at the main cap starts at ~170 and climbs to ~380, then when the optical audio out light shuts off, it drops back to ~170. If you hold the power button down for three seconds, the LED will turn off and the set is completely unresponsive unless unplugged and plugged back in. I have a second PSU but no other boards to swap out. There is no change with the second PSU installed. There are four wires at connector SN2 on the SN board. There is a S/C between the white wire and the two middle wires at that connector. There are also a few components that show S/C in circuit. I am leaning towards a faulty SN board, but there is no blink code that would suggest it. Do any of you have any ideas?
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: TC-P50X5, solid red LED, no blinks, no prime, no picture or sound
    There's a thread with service manual located
    https://www.badcaps.net/forum/showthread.php?t=44747
    • johnboy1313
      • Nov 2012
      • 1959
      Where are you seeing the service manual in that thread?
      • dick_barton
        • Aug 2015
        • 6642
        • Wales
        Look at post #12
        • vinceroger69
          • Mar 2012
          • 6714
          this may help?
          • johnboy1313
            • Nov 2012
            • 1959
            Originally posted by dick_barton
            Look at post #12
            I see a datasheet for an IC and schematics for the PSU.
            this may help?
            Thanks, it's a start, but doesn't really help with the troubleshooting. They reference a training manual. I've had a look at that one and it doesn't really help either. I do appreciate the input though.
            • dick_barton
              • Aug 2015
              • 6642
              • Wales
              The power supply is a good starting point to check what voltages if any are missing.
              • johnboy1313
                • Nov 2012
                • 1959
                I've already done that and tried a second power supply.
                • dick_barton
                  • Aug 2015
                  • 6642
                  • Wales
                  So you have and can confirm that when tested all the voltages are correct ?
                  • tw2005
                    • Oct 2011
                    • 6458
                    sounds like shorted Vsus. On the SN, Pin 6 or SRV-Vsus to gnd what do you get withe the P2 disconnected.
                    • tw2005
                      • Oct 2011
                      • 6458
                      I guess you know this but if the PSS is good, a an A-board & SN together is the princely sum of $43 from SJ!
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        tw2005 is there a training manual that covers this set? ive had a quick google search they list loads of diffrent generations, just for future refrence how do you tell which one covers what models? thanks
                        • tw2005
                          • Oct 2011
                          • 6458
                          I have not found anything except the 50 UT/ST model. I don't understamd what you mean how do you tell? Year / models/ chassis or look at it.
                          • tw2005
                            • Oct 2011
                            • 6458
                            at SN2, Pin 1 is gnd, 3,4 are MID or the ERC from the PSS, 6 is Vsus
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              Sorry tw2005 i worded that completly wrong (been one of those days) ive just found a site with a fair few panasonic training manuals on i will have a read of them as may help me understand plasmas more and test procedures.
                              • ChaosLegionnaire
                                by ChaosLegionnaire
                                09-13-2022, 09:02 AM
                              • kca
                                Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
                                by kca
                                Hello all ~
                                I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
                                This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
                                No picture. No sound.
                                I tested all the voltages coming out of the power supply...
                                10-12-2023, 05:23 PM
                              • LEECH666
                                Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                by LEECH666
                                Good day ladies and gentleman!
                                I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                01-19-2024, 05:46 PM
                              • Christos Tsiligiannis
                                Marian Trace Alpha sound card repair help
                                by Christos Tsiligiannis
                                Hello to the forum.
                                My name is Christos, I am new to the forum here and i am posting from Greece.
                                So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                11-18-2024, 05:26 AM
                                HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                09-12-2024, 02:30 PM
