Panasonic TC-P50X5 Chassis GPF15DU Training Manual?
  • kevinm34232
    • May 2012
    • 1884
    Can someone help me find the training manual for this series (April 2012), I have the SM but the troubleshooting section refers to a different manual:
    For detailed troubleshooting information and circuit explanations,
    refer to the "QSM/Service Hints/Troubleshooting Information(TI)" and Seminar/Training Manual/Technical Guide(TG) documents
    posted on the TSN web site.
    For information about this model, type TC-P2012 in the model box under "Direct Search".
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TC-P50X5 Chassis GPF15DU Training Manual?
    what exactly are you trying to figure out? I don't think i've seen anyhig other than the ut/st 50 guide so unless there's someone with a panasonic login who can get it I think we may be out of luck on this one.
    is this a no power issue?
    • kevinm34232
      • May 2012
      • 1884
      Here's a few quick photos. The story is a guy brought this to me to fix, and he cracked the screen on transport. I don't know what was wrong before, but I was going to try to find the issue so I know what parts are good. I imagine it was in the same state before the screen broke.
      I have 5V on STBY5V, and 15V on F15V, nothing else. Nothing happens on pressing the power button. The power LED is not lit (I'm not sure if it would be anyway while in standby), but the optical connector is lighting up red on the main board when plugged in so I know we're getting the 5V to the main board.
      From there I don't know where to TS or if those other voltages in the photo should be on at this point or only after it gets the PS-ON signal.
      Seems very easy to work on if I had the troubleshooting flow chart.
      • tw2005
        • Oct 2011
        • 6458
        yeah, ok , well I think finding out what the original symptoms from the person would be handy place to start.
        having 5vstb and F15v is a good start plus the optical jack suggests the A board is somewhat functional, no front LED though, not sure.
        This is one of those horrible PSS boards which seem to give trouble.
        have you had GENERAL PROBE ON THE pss AND THE sN TO SEE IF THERE'S ANY OBVIOUS SHORTED PARTS?
        ignore the CAPS, clumsy fingers.
        • tw2005
          • Oct 2011
          • 6458
          what's the serial number of the PSS
          • kevinm34232
            • May 2012
            • 1884
            No obvious shorts, on the SN board there is a SRVP5V test point which has 5V.
            • kevinm34232
              • May 2012
              • 1884
              See Attached
              • tw2005
                • Oct 2011
                • 6458
                I honestly don't know. I have the darfon schematic for the PSS and I know u203 can cause a dead TV but not having any experience with these i can't remember if you end up with no standby or not when it is faulty or if it is present and the front LED is out.
                so have you watched the front LED as you plug in, any sign of life there even if only brief?
                • kevinm34232
                  • May 2012
                  • 1884
                  There is no light from the LED but I think it may just go red when you power it on. Can you post the schematic? (It may be in my SM I haven't checked)
                  • tw2005
                    • Oct 2011
                    • 6458
                    Originally posted by kevinm34232
                    See Attached
                    I wonder which one is the serial
                    The doc i found says up to 2560001 was applicable for faulty U203, looking at the board the sequence 20 00006 maybe the serial but then I'm suspicious of 00006 as just being related to the part number.
                    Not really helping, I think i may be just complicating things. If I was shooting in the dark and had to pick the most likely thing to fail in these it would be the PSS.
                    From the few posts we've had it does seem to be a common fault.
                    • kevinm34232
                      • May 2012
                      • 1884
                      I have read your info on U203 before and had searched for that part but seems like only found in the UK, I found a datasheet that said it was not to be shipped to the USA by order of a court injunction??
                      This board has a U203 with markings PC2AB, 675SU
                      • tw2005
                        • Oct 2011
                        • 6458
                        sure , no schematics on P boards in these later series.
                        I thought you said you had no front LED lit?
                        • tw2005
                          • Oct 2011
                          • 6458
                          Really, it will be 6755U onthe chip I expect. Do you have that info on the court injunction for us to read. Is that a recent doc?
                          • kevinm34232
                            • May 2012
                            • 1884
                            I meant I had another newer Panasonic and the power LED only lit up red when you press the power button and TV comes on it stays red and is off when TV is off.
                            • kevinm34232
                              • May 2012
                              • 1884
                              https://cdn.badcaps-static.com/pdfs/...7a3595ec1a.pdf
                              https://www.fairchildsemi.com/about/...gation-update/
                              • tw2005
                                • Oct 2011
                                • 6458
                                just found this on mouser
                                AC/DC Converters This particular part was found to be patent infringing and we are unable to sell this product.
                                So that's an interesting situation, panasonic has a Power board that contains an illegal chip so how does one repair this board and how can they continue to supply it as a spare?
                                I wonder who they've copied this from /
                                I wonder if you get it offshore if it will get past customs?
                                • kevinm34232
                                  • May 2012
                                  • 1884
                                  I guess it would be worth trying U203 if I can find one.
                                  (I just ordered one from UK I'll update if it should fix it. The problem is the broken screen and if it will still power on anyway)
                                  • tw2005
                                    • Oct 2011
                                    • 6458
                                    Wow, I just dug up a list of Fairchild violations.
                                    http://www.businesswire.com/news/hom...d#.VPuOm3yUfE0
                                    AS1000 FAN6793 FSEZ2007 SG5841J SG6846A
                                    AS1003 FAN6861 FSEZ2016 SG5842 SG6846B
                                    AS1207 FAN6862 FSEZ2037 SG5842A SG6846C
                                    DAP024 FAN6862L LTA504SG SG5842J SG6846G
                                    FAN100 FAN6862R LTA504SJ SG5842JA SG6848
                                    FAN102 FSBH0170 LTA703S SG5851 SG6849
                                    FAN103 FSBH0270 LTA704S SG5851A SG68502
                                    FAN104 FSBH0370 LTA705S SG6741 SG68502A
                                    FAN301 FSBH0F70 LTA809FA SG6741A SG68502B
                                    FAN400A FSEZ1016A LTA810FA SG6742 SG6858
                                    FAN400C FSEZ1116 LTA811FA SG6742HL SG6859
                                    FAN6747 FSEZ1216 PO168MY SG6742HR SG6859A
                                    FAN6751 FSEZ1216B PO268MY SG6742ML SG6860
                                    FAN6752 FSEZ1217 PO368MY SG6742MR SGP100
                                    FAN6753 FSEZ1307 SG5701 SG6842J SGP101
                                    FAN6754 FSEZ1317 SG5841 SG6846 SGP400
                                    FAN6791
                                    The following Fairchild products are already under permanent injunction based on earlier litigation:
                                    FAN7602 FSD200B FSDH0265RLDX FSDL321L_NL
                                    FSCM0465R FSD200B_NL FSDH0265RLDX_NL FSDM0170RNB
                                    FSCM0465RGWDTU FSD200BM FSDH0265RLN FSDM0265RL
                                    FSCM0465RIWDTU FSD200BM_NL FSDH0265RLN_NL FSDM0265RL_NL
                                    FSCM0465RJ FSD200BMX FSDH0265RLX FSDM0265RN
                                    FSCM0465RJX FSD210 FSDH0265RLX_SB82190 FSDM0265RN_NL
                                    FSCM0565R FSD210B FSDH0265RN FSDM0265RNB
                                    FSCM0565RCYDTU FSD210BH FSDH0270RNB FSDM0265RNB_NL
                                    FSCM0565RCYDTU_NL FSD210BM FSDH0370RNB FSDM0265RNC
                                    FSCM0565RD FSD210BM_NL FSDH321 FSDM0265RNC_NL
                                    FSCM0565RGTU FSD210BMX FSDH321B FSDM0270RNB
                                    FSCM0565RGWDTU FSD210BMX_SB82110 FSDH321L FSDM0365RL
                                    FSCM0565RIWDTU FSD210DH FSDH321LX FSDM0365RL_NL
                                    FSCM0565RJ FSD210H FSDH321LX_NL FSDM0365RLX
                                    FSCM0565RJX FSD210HD FSDH321Z FSDM0365RN
                                    FSCM0765R FSD210HD_NL FSDH321Z_NL FSDM0365RN_NL
                                    FSCM0765RC FSD210L FSDL0165RL FSDM0365RNB
                                    FSCM0765RCYDTU FSD211 FSDL0165RL_NL FSDM0365RNC
                                    FSCM0765RCYDTU_NL FSD211H FSDL0165RN FSDM0370RNB
                                    FSCM0765RD FSD211H_NL FSDL0365RL FSDM100
                                    FSCM0765RGWDTU FSD500 FSDL0365RL_NL FSDM100_NL
                                    FSCM0765RIWDTU FSDH0170RNB FSDL0365RN FSDM101
                                    FSCM0765RJ FSDH0265RL FSDL0365RNB FSDM311
                                    FSCM0765RJX FSDH0265RL_NL FSDL321 FSDM311_NL
                                    FSD1000 FSDH0265RL_SB82109 FSDL321_NL FSDM311L
                                    FSD200 FSDH0265RLD FSDL321L FSDM311L_NL
                                    FSD200_NL FSDH0265RLD_NL
                                    AS1000 FAN6755W FSBH0170A LTA703S SG6840
                                    AS1003 FAN6756 FSBH0170W LTA704S SG6841
                                    AS1207 FAN6756AHL FSBH0270 LTA705S SG6841x3
                                    DAP024 FAN6791 FSBH0270_F116 LTA809FA SG6842
                                    DAP02A FAN6793 FSBH0270A LTA810FA SG6842J
                                    FAN100 FAN6861 FSBH0270W LTA811FA SG6843
                                    FAN102 FAN6862W FSBH0370 PO168 SG6846
                                    FAN103 FAN6862 FSBH0370_F116 PO268 SG6846A
                                    FAN103W FAN6862H FSBH0F70 PO368 SG6846B
                                    FAN104 FAN6862HR FSBH0F70A SG3843G SG6846C
                                    FAN104W FAN6862L FSBH0F70A_F116 SG5701 SG6846G
                                    FAN301 FAN6862R FSBH0F70WA SG5841 SG6846WA
                                    FAN400A FAN6863 FSEZ1016A SG5841J SG6848
                                    FAN400C FAN6863L FSEZ1216 SG5842 SG6849
                                    FAN6747 FAN6863R FSEZ1216B SG5842A SG68502
                                    FAN6747W FAN6863W FSEZ1217 SG5842J SG68502A
                                    FAN6747WA FAN6863WE FSEZ1307 SG5842JA SG68502B
                                    FAN6747WALMY FAN6863WL FSEZ1307S SG5843 SG6858
                                    FAN6749 FAN6863WR FSEZ1317 SG5851 SG6859
                                    FAN6751 FL103 FSEZ1317A SG5851A SG6859A
                                    FAN6751MR FL7730 FSEZ1317WA SG6741 SG6859D
                                    FAN6752 FL7732 FSEZ2007 SG6741A SG6860
                                    FAN6753 FSB117H FSEZ2016 SG6742 SG6902
                                    FAN6754 FSB127H FSEZ2037 SG6742HL SG6905
                                    FAN6754A FSB137HL FSL127H SG6742HR SG6932
                                    FAN6754B FSB147H FSL137H SG6742ML SGP100
                                    FAN6754WA FSBH0170 LTA504SG SG6742MR SGP101
                                    FAN6755 FSBH0170_F116 LTA504SJ SG6742WMR SGP400
                                    FAN6755UW
                                    • kevinm34232
                                      • May 2012
                                      • 1884
                                      Re: U203; "At a certain sequence of events, the TV does not turn on
                                      and the standby LED is not lit. For example, after disconnecting
                                      of power, then after you turn
                                      within 3 minutes."
                                      In all those posts did anyone ever check voltages when it wouldn't turn on, or has there not been a confirmed case of this on here yet?
                                      • tw2005
                                        • Oct 2011
                                        • 6458
                                        several reports of that exact scenario where after a loss of power they could not get the Tv to turn on but after a few days it came back. you'd have to do your own searching but I start with model numbers and the PSS board part number, maybe u203, and b159-201 as keywords. you're bound to find something even if it's in another country
                                        x5, xt50
