Philips 50pfp5532d/05 no picture
  • Cobblers
    • Jan 2016
    • 90
    • Uk
    Hello all.
    This set does not power on. I have 5v standby 15v vg. 12v ssb and vsnd 17v neg and pos. I get no vs or va with x and y sus disconnected. If i give 5v to vson is get 207v vs and 62v va. I can see a bulging cap on the x main c4712 but was trying to get power first. Thanks. Any ideas.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Philips 50pfp5532d/05 no picture
    Bad Ysus probably, is the upper buffer Ic exploded ? I will link video by Tom66.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Tom66 Video:
      https://m.youtube.com/watch?v=25HTy6esBHs
      My Video on preventative measures to take on this chassis:
      https://m.youtube.com/watch?v=JjQ--2SZdyY
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Double Post.
        • Cobblers
          • Jan 2016
          • 90
          • Uk
          Ok. So i had a good look at the boards i removed the y main and buffer and also the x main.
          After a close look they dont seem to have the obvious damage that is in the links to the vids you sent me.
          So with the x and y mains disconnected should i not still have voltage on the vs and va connectors?
          I went around and refreshed the solder like you suggested.
          When i plug the power in i get 3 solid lit leds.
          1 led is lit on the daughter board on the power supply.
          2 leds are lit on the logic board i think they are marked 8001 8002.
          All large fuses are good.
          The 2 surface mount fuses on the logic board are good.
          Is there any more checks i can do?
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            You need to check Vsc and Ve voltage on the Xmain and Ymain.
            • Cobblers
              • Jan 2016
              • 90
              • Uk
              Ok, i can see the test point for the ve on the xmain but not the y main? Where abouts should i be looking. On the main power plugs for the boards i have vs vcc and ground.
              Xmain i have.
              Vcc 14.88
              Vs 2.6
              Ve 1.12
              Y main i have
              Vcc 14.8
              Vs 2.6
              Sorry cound'nt find a ve point to test
              • Cobblers
                • Jan 2016
                • 90
                • Uk
                Just to add if i put a link in between 5v and vs on, on the power board connector cn8002 i get 207v on the vs line on both the y and x main boards i also get 94v on the ve on the x main.
                What would stop me from getting a vs on signal when i turn the set on?
                The plug with vs on comes from the logic board but that connects to the ssb which is connected to the side panel.
                Do faulty x or y mains and buffers prevent the vs on signal to stop them from powering up?
                Im struggling to find any manuals that have the scematics and and test procedures for this exact model. Ive found simerlar but the board layout s all seem slightly different thanks for the help so far.
                • Cobblers
                  • Jan 2016
                  • 90
                  • Uk
                  Ok so this morning i swapped the logic board. The set started to power up i had 3 green led lit on the logic board plus led 2002 was flashing about once a second. This had not been happening before i changed the board.
                  Within about 10 seconds the third from bottom y buffer chip exploded.
                  So do i need to change the y main and buffer now do you think?
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Your not diagnosing it properly dont just throw boards at it. Does the Ymain have the green Led on it lit up ?
                    • Cobblers
                      • Jan 2016
                      • 90
                      • Uk
                      Yes it is lit up.
                      • Cobblers
                        • Jan 2016
                        • 90
                        • Uk
                        It wasnt before though.
                        • Cobblers
                          • Jan 2016
                          • 90
                          • Uk
                          Led 5800
                          • Cobblers
                            • Jan 2016
                            • 90
                            • Uk
                            So the y main is in protection mode now. I noticed you were selling some boards in the for sale section. Do you still have any for this tv how much would you want for the boards i need?
                            Cheers.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Im no longer selling the boards, have you tried disconnecting the buffers to see if the protect light is still on ?
                              • Cobblers
                                • Jan 2016
                                • 90
                                • Uk
                                Yes its still lit with the buffer removed
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Ok so the Ymain is faulty, do you know how to check for S/C ?
                                  • Cobblers
                                    • Jan 2016
                                    • 90
                                    • Uk
                                    I can use my meter to test for continuity between 2 points if you tell me where to check. Im a lift engineer so use my meter mostly for checking voltages and shorts too earth or between trailing cables looking for damaged wiring. If you tell me where to check ill have a go.
                                    Thanks for the help.
                                    • Rauni
                                      Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
                                      by Rauni
                                      Hello, this is my first post on this forum, and my first attempted to repair a TV.
                                      My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
                                      Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
                                      Read also that we should test what happens if we...
                                      10-01-2023, 12:06 AM
                                    • Schwoin
                                      Philips 243v5lhsb00 Monitor Picture too bright
                                      by Schwoin
                                      Hey everyone,
                                      the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
                                      While i tried to tilt the screen a little bit while it was displaying a picture, iยดve noticed, that there appeared some purple pixels. In the following picture
                                      you can see them on the top half of the photo.
                                      At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
                                      03-21-2023, 12:40 PM
                                    • madyoyo
                                      Philips 37pfl560: Yellow picture
                                      by madyoyo
                                      HI.
                                      I have a weird problem with an old Philips 37pfl560 TV i put out of storage: the picture have a noticeable yellow hue, and its not caused by the settings (did a factory reset). I've never seen this before. I will try to get a photo with a real camera, with my phone its hard to see because of automatic white balance, but in real live the whites are really yellow.
                                      Anyone have an idea of what can cause this? Can CCFL tubes get "warmer" with time? This tv have several analog inputs,so its nice for retrogaming....
                                      05-30-2025, 10:16 AM
                                    • charlesdutcher
                                      No picture issue in Philips Chassis FTL2.1
                                      by charlesdutcher
                                      My Plasma Philips 37inch chassis FTL2.1 does not show picture. It automatically goes into protection mode after 30 seconds (red led blinks at 3Hz)
                                      Is there someone having any symptom like this? How to fix it?
                                      Thanks in advance!โ€‹
                                      08-06-2024, 09:55 PM
                                    • groomit
                                      Philips 50PUS7363/12 Backlight but no picture
                                      by groomit
                                      I'm having trouble with above mentioned TV. Bought it defect.
                                      Picture was heavily compressed around the horizontal axis. Fiddeled and tried different things (mask clock lines, swap T-Con). But no difference.
                                      Then I identified a heating capacitor on the left hand Signal-PCB (?) below the display. Replaced it by hand soldering. Checked for shorts afterwards. But now the screen stays black.
                                      I can see backlight, but screen stays black.
                                      What I've tried:
                                      - Disconnect right side cable from T-Con -> same (backlight but no pic)
                                      - Disconnect left side...
                                      11-22-2024, 02:43 PM
