toshiba 40L1333b 17MB95s-1
  • russellhearn69
    • Mar 2016
    • 16
    • Northern Ireland
    I'm hoping that i can find a bit of help with my problem as i ha been all over the internet and can't seem to find anything that works.
    I have read through this forum and i have followed all the instuction that i have found but still have had no joy.
    I'm getting the dreaded slow flashing red/green light and the tv won't turn on so I'm trying to do the firmware update using the method of holding the OK key on the remote but i just get rapid blinking of the green/red led and nothing else happens, i downloaded the firmware from toshiba but it only gave me 1 file (upgrade_mb90.bin) so i was mising the, usb_auto_update_A1.txt which i got from another members post (27070712_MB95_OEM_MO_V224t_SVN_110213_ENV_GEN_256.xls)
    I commented out the mboot.bid as recomended by tom66 but still getting nothing.
    As stated in the title my TV is a Toshiba 40L1333b with the main board being 17MB95s-1
    Please help me as i'm cracking up!!!!!!!
  • sordids999
    • May 2013
    • 2149
    Re: toshiba 40L1333b 17MB95s-1
    What fault are u having with your tv ?
    • russellhearn69
      • Mar 2016
      • 16
      • Northern Ireland
      appologies all i'm getting is a slow flashing red/green light and i've updated my original post, sorry for the confusion.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Its not wanting to accept the core folders, try freezing the spi flash Ics then rebooting firmware if that fails your have not got the files correct. I hate it when these Vestels do that such a nightmare to fix !
        • russellhearn69
          • Mar 2016
          • 16
          • Northern Ireland
          thanks for the response but you just lost me there, can i ask what you mean by "freezing the spi flash ics then rebooting firmware"
          • tn245
            • Oct 2013
            • 530
            The usb_auto_update_A1.txt file usually has the update file as mb90_en.bin. Did you try renaming the upgrade_mb90.bin file to mb90_en.bin or changing the name in the txt file?
            • russellhearn69
              • Mar 2016
              • 16
              • Northern Ireland
              i did try that earlier and nothing happened however i just tried it again and the tv done something.
              held the ok button and i got the rapid flashing red/green and it was reading from the usb but only for about 10 second and then stopped reading the usb and the red/green light just keeps flashing
              • tn245
                • Oct 2013
                • 530
                It reads the file from the usb into memory first, then it writes it to the nand chip which can take a little while. It should eventually restart on its own. The thing is the update script may not match exactly the structure of the bin file you're using in which case it won't work. Can you put the usb_auto_update_A1.txt file you're using up here as an attachment so I can take a look?
                • russellhearn69
                  • Mar 2016
                  • 16
                  • Northern Ireland
                  just found a different usb_auto_update_A1.text file that is slightly different, would it make much difference if i was to try it?
                  • russellhearn69
                    • Mar 2016
                    • 16
                    • Northern Ireland
                    here you go
                    • russellhearn69
                      • Mar 2016
                      • 16
                      • Northern Ireland
                      haha, the tv came on but now the picture is upside down, is there no end to the garbage that vestel sell
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Looks like the firmware is not for the panel used lol stupid Tv's what screen is in that ?
                        • russellhearn69
                          • Mar 2016
                          • 16
                          • Northern Ireland
                          it's a toshiba 40L1333b with the 17mb95s-1, screen is upside down, no audio, only 1 hdmi in the menu, really starting to go mad now, searched everywhere to to and get the right firmware for it but nothing is working, even the firmware from toshiba isn't correct
                          • russellhearn69
                            • Mar 2016
                            • 16
                            • Northern Ireland
                            Managed to get into the service menu so took a photo for you all to have a look at and to me it looks like the firmware on it is from 22" screen and the tv is 40" any way i hope this helps
                            • steviewonder
                              • Dec 2013
                              • 183
                              • england
                              I have the firmware for the 40D1333b,but cannot remember for the life of me where I got it from!...if you PM your email address will see if I can send it to you via a attachment,worth a try..
                              Steve.
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Its upside down because you have it set to the VES400 panel which uses a LSC400HM08 screen, your model of Tv uses a LTA400HM23 screen so you need to get the software for that screen not the one its set up for now.
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Steve.
                                  Can you attach it to the forum ? Will be alot of help.
                                  • russellhearn69
                                    • Mar 2016
                                    • 16
                                    • Northern Ireland
                                    Re: toshiba 40L1333b 17MB95s-1 (Solved)
                                    Ok I folks after being up all night i managed to find the proper software for the tv, i have attached the files that i found, hope this helps others who had the same problem.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      Thanks for the file im sure it will help other members too and glad you have managed to fix your tv another set saved from landfill etc.
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        Awesome One thing I want you to do, if it fails again in a few days with the same symptoms/fault of flashing Led let us know.
                                          09-06-2024, 05:27 AM
                                          09-06-2024, 05:59 AM
                                          09-06-2024, 05:33 AM
