JVC LT-40DJ51J - Vestel 17IPS20 - LEDs very dim
  • ictc
    replied
    Same issue with same PSU. I still can't figure out the main cause of the low voltage.I have other two working spares PSU were backlight rise until 140v and stays stable. On the faulty one the voltage measured on the connector cn 500 with led connected, rise till around 114v than fall down to 107v remaning stable but never reaches the 140v needed to light up the leds...
    Any hint?
  • R_J
    replied
    Re: JVC LT-40DJ51J - Vestel 17IPS20 - LEDs very dim
    17IPS20 with resistor at J60, some of the boards have nothing at J60, some have only a 2 pin plug at CN500
  • m4life
    replied
    Any update on Vestel 17IPS20 - LEDs very dim
  • ReeceyBurger123
    replied
    Originally posted by flocko
    J60 is a plain jumper wire, what have you been putting in that vape of yours?
    Lol also mine had a resistor will get image of it
  • flocko
    replied
  • ReeceyBurger123
    replied
    Any update ? I had same issue with VES390 other day Leds very dim J60 output resistor was nearly OC it was physically burnt. I stole one off another board I did not get its value though.
  • shomi75
    replied
    I had the same problem. Resolved with replacing two led stripes. Before I had 120v on led and now it is about 160v
  • ReeceyBurger123
    replied
    Hmm maybe it is a fault with the Leds then. As I said you need to test them 3 not glowing with you DMM not the 12v Psu.
  • tn245
    replied
    Yes. I have borrowed a known good PSU and main board for testing. It seems the PSU was ok but there is some issue with the main. There does seem to be a problem with the LEDs too as the borrowed boards are not always able to light the backlights although with the new main I am getting the higher voltage at start-up on both PSUs.
    I will try reflashing the firmware on the main and also will test and replace LEDs as needed. I am short of time to work on this set though.
  • ReeceyBurger123
    replied
    Any update on the set ? I recent had a 17ips20 with no 24v for the Leds found the transistor for the 24v/Led driver was not being turned on. Two shorted smd diodes on the bottom of the psu. Will link video which helped me diagnose it shortly.
  • tn245
    replied
    It doesn't as far as I can tell. Unless my DMM's (UNI-T UT61E) peak function is not fast enough to catch it? Replaced parts are U500, Q502, Q505 and R509.
  • ReeceyBurger123
    replied
    It should be hitting that then detects that the Leds are not getting power then collapse. Does it still not do that ? Also what did Michael actually replace ?
  • tn245
    replied
    Hi Reecey. I was for the time being ignoring the LEDs and concentrating on the PSU as shouldn't it still be hitting something above 123V with the string disconnected - even if briefly?
  • ReeceyBurger123
    replied
    Hmm why dont you test them dim Leds with your DMM ?
  • tn245
    replied
    Just to update. It's had new driver IC and FETs Q502 & Q505 plus R509 which was out of spec. Boosted diode (D504) tests ok and have also tried a replacement. Sent PSU to Michael Dranfield who said it was was working for him after R509 replaced but in my set it is not. With LED string connected or not, voltage never gets above 123V. Maybe a problem with dimming signal from main board? I may try to cobble together an oscilloscope to check out the PWMs but I'm having to put the TVs aside till next week so will get back to it then.
    Pictures of the back of the board and LED driver section attached.
  • ReeceyBurger123
    replied
    Originally posted by comptek
    i aways use cotton or latex gloves saves finger prints on the inside of the screen
    I dont have to I sort of slot he screen sides between my hands so that I dont have to put my hands on both sides.
  • comptek
    replied
  • ReeceyBurger123
    replied
    No worries glad to help, also reply is late because it didnt post for some reason lol
  • PL519
    replied
    Hi ReeceyBurger123,
    thanx for Your advice. Did it nearly the same way as You described, but lifted the lcd with the plastic bezel, seemed to be a little more safer for the display. Anyway, after that it was easy to locate the defective lcd, took it out and managed to exchange it with a similar one from a telly with a broken screen. Everything fine now, all led´s lit up. Just waiting for the glue holding this little optical lens now to dry up, then i´ll reassemble the unit again.
    Thank you Vestel, you gave my afternoon a real sense https://www.badcaps.net/forum/images.../icon_razz.gif.
    ReeceyBurger123 many thanx for Your assistance and good luck to tn245, who started this topic!
    Wolf
  • ReeceyBurger123
    replied
    Its not easy I tell you, for your panel Ves420 you need to do this:
    1. Remove stand support brace and unplug Tcon ribbon cables that go to screen driver board.
    2.Unscrew front Led and Ir sensor board and optic from the front frame.
    3.Unscrew all screws around the outside out the metal frame going to front plastic bezel.
    4.Flip Tv over and pry off front bezel its clipped down so just undo the clips by folding it outwards.
    5.After removed unlatch tab bond driver pcb from metal chassis fold both over onto lcd screen and tape down to stop it from flexing.
    6.Carefully remove Lcd screen and place some where safe, be very careful here hold it by the sides try not to flex it !
    7.After that there is another black plastic bezel that holds diffusers down, its secured with clips unlatch them and remove platic bezel.
    8.Grab all the diffusre sheets together and place them aside in the orginal order.
    9.Remove the white reflector sheet off the back on the panel, there are 4 plastic optic clips that hold it down as well as some double sided tape. The clips are secured throuh the underside of the metal chassis.
    You then have access to the Leds.
    Or watch my video which covers the Ves315 Led screen which is similar to take apart:
    https://m.youtube.com/watch?v=0uBhca7zyXI
    If you crack the screen the game is over to be very careful. Good luck and keep us updated
  • Pipolups
    Corsair K70 LUX RGB dying LEDs
    by Pipolups
    Hi there !
    I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
    Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
    10-08-2024, 11:58 AM
  • nick4275
    Vestel Based JVC no picture, leds on
    by nick4275
    Hoping someone has troden this path before !
    I'm looking at a JVC LT-39c790 - a vestel based unit.
    So, the remote turns it on, led's light up but no picture at all.
    I have a spare mainboard, so I know its not that. The PSU seems ok too.
    On the AUO T-Con I've got 16v on HAVDD_H but nothing on HAVDD_L - which I'm assuming should also be 16v ?
    So, Ive resorted to testing eveything I can on the board as I can't find any schemas for it (AUO 39T15 C04 Ctrl Bd) and I think I've found a diode gone short. it marked D005 on the board and E1 on the package...
    11-21-2023, 04:43 AM
  • psdavid65
    Toshiba 40L1333DEV Vestel 17IPS20
    by psdavid65
    Quick Question Please.
    Is low resistance on gate pin 5 of U202 normal? I have a very very low resistance of 5 ohm on this gate. In diode mode, it looks shorted and beeps. Is this a normal behavior of this FAN6300 IC?
    All other components on this vestel board have valid readings except for this U202 IC.
    09-21-2023, 12:29 PM
  • Jaime Morillo
    Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
    by Jaime Morillo
    Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
    The TV was stuck on the logo and I couldn't access the update menu.
    I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
    The image result was good, but the image is inverted.
    The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
    Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
    08-18-2025, 11:38 AM
  • lmcancu
    RCA RLDED 4331B: 43 inch LED TV: Backlight issue
    by lmcancu
    Hi I am having an issue with the LED backlight of this TV. I can see the picture with a flash light, so I determined it was a backlight issue.
    Initially, after opening it I found 2 shorted and 1 open LED on 2 strips (total of 4). I removed the LEDs and shorted the pads together to verify if the backlight would work.
    Testing it, I found the backlight turned on and I measured 54V when TV was in standby (off), and 100v when TV was turned on. The 4 strips each contain 9 LEDs, so 36 in all minus 3.
    Instead of putting it back together I decided to replace...
    04-01-2023, 01:11 PM
