hitachi 42pd9r10 dead
  • azza1234
    • Nov 2013
    • 124
    • united kingdom
    Just got this tv as spares or repairs as wouldnt switch on so got it home checked fuse in plug and powerboard all ok plugged in and no sign of life no standby light or anything is there a common fault with these plasmas
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: hitachi 42pd9r10 dead
    Images ?
    • azza1234
      • Nov 2013
      • 124
      • united kingdom
      Sorry heres the photos
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Do you know how to check resistors ? If so check the big block type that I have zoomed in on in the picture:
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          Well--Whatever you do--Dont waste dosh on it!
          Every one of these Ive seen--Inc the Philips that used the same panel/chassis had a clapped out/cruddy PDP giving awful mal-discharge and nasty green fringing on fleshtones...
          Fujitsu/Hitachi used a low voltage PDP (65V Vs,--everyone else uses around 180-220v) with poor aging characteristics...
          Orrible bloody things, I don't bother with them anymore...
          TELEFIX
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            Owhhh but would be nice to fix, they are quite reliable apart from that.
            • azza1234
              • Nov 2013
              • 124
              • united kingdom
              The white ones? If so my meter says 10.4 on both
              • azza1234
                • Nov 2013
                • 124
                • united kingdom
                Theres no voltage going to the powerboard from this when plugged into the mains?
                • dick_barton
                  • Aug 2015
                  • 6642
                  • Wales
                  Have you checked the white ceramic fuse on the board along side the connector or even the fuse in the 13Amp plug?
                  Edit
                  Just reread your first post in which you say you have checked both fuses.
                  Have you checked the On/Off switch to see if it has gone open circuit
                  • azza1234
                    • Nov 2013
                    • 124
                    • united kingdom
                    Yer checked both and all ok
                    • azza1234
                      • Nov 2013
                      • 124
                      • united kingdom
                      Dont know what i did but all is working again
                      • Danny kikkert
                        Dead dps-162kp-1 powerboard
                        by Danny kikkert
                        I have a dps-162kp-1 runtka932wjqz powerboard wich has no power at all on the cold side.
                        I replaced ic7903, r7900, R7902, C7901, d7950.
                        Checked the diodes around the chip and also the caps.
                        On the ic pin 5 no voltage, pin7-8= 315V
                        On the T7901 pin 1-4 no voltage, pin 2-3=315V
                        Anybody have any idea where to look further?
                        Any help is welcome
                        Thanks Danny from holland
                        08-31-2024, 11:13 AM
                      • double_DD
                        How can I be sure that my EC chip is dead?
                        by double_DD
                        As the title suggests, how can I be sure that my EC chip is really dead?
                        I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                        Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                        03-12-2025, 07:47 AM
                      • Ruptor
                        Hitachi 55" TV dead after 18 months (Vestel 17MB100)
                        by Ruptor
                        I couldn't find any other thread that matches my TV problem but have been told it is a common fault. The fault is a flashing LED as if it is in upgrade mode that happens after a few seconds and stays forever. I can't remember all the tricks that have been tried like holding the select button when powering on but nothing worked. The shop sent me a flash drive to plug in a USB port but that did nothing either and they said it was dead which is disgusting for a piece of solid state electronics. I took the back off eventually after removing 34 screws to check for blown caps but everything looks new...
                        09-27-2021, 10:19 AM
                      • disorder
                        ps5 edm-033 dead after hdmi/usb ports destroyed
                        by disorder
                        hello guys,
                        i need help to repair a edm-033 ps2
                        history : as always hdmi port and usb ports destroyed after unplugged
                        after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                        so i changed it
                        now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                        but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                        i don't see any projection of liquid metal on pcb.
                        01-14-2025, 12:48 PM
                      • Beton
                        Finding a dead short component
                        by Beton
                        Hi guys!
                        I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                        So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                        I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                        I have a bench PSU and if I try to inject voltage the voltage...
                        12-10-2021, 01:05 PM
