Bush LC39GL12F - W25Q32 EEprom Bin file
  • pic_whiz
    • Feb 2014
    • 36
    Does anyone have a copy of the 4Meg bin file for this TV? Hoping to bring this set out of standby.
    Cheers,
    Matt
  • pic_whiz
    • Feb 2014
    • 36
    Re: Bush LC39GL12F - W25Q32 EEprom Bin file
    Just a gentle reminder in case someone has a copy somewhere??
    • vinceroger69
      • Mar 2012
      • 6714
      • uk
      Ive recently repaired the 46 in model of this set, i brought a preprogrammed chip from ohm supplies as i couldnt find the bin file online.
      • cheeky2
        • Dec 2012
        • 339
        • uk
        Did you get hold of the binary for this TV? I managed to get hold of one from another set same board but different TV model so proved the fault was down to the spi chip. However it didn't control remote and screen different as well!
        If you have it can you upload it or pm me
        Thanks in advance
        • m1ch43lzm
          by m1ch43lzm
          Hi everyone
          09-06-2025, 05:47 PM
        • my2k2
          Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
          by my2k2
          Good day to every one,
          I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
          Does anybody have an eeprom dump file? I really appreciate any help.
          Thanks in advance.
          07-01-2024, 09:04 PM
        • to5it0
          by to5it0
          10-24-2025, 01:35 AM
        • Forest79
          by Forest79
          07-23-2023, 07:39 AM
        • SidneyCanadas
          93C46 and 93C56 EEPROM
          by SidneyCanadas
          I tore apart my instrument cluster for my 2008 Toyota Corolla made in 2007 in Cambridge, Ontario, Canada and pcb location: IC6=EEPROM is a surface mounted device with part # of 93C46W7, some claim the EEPROM out of a Camry part # 93C56 will allow odometer to roll over 299 999 KM or miles. The data sheet for both is below:
          https://cdn.badcaps-static.com/pdfs/...c6e42b20d3.pdf 2
          Anyone know if the Camry one will work on my Corolla?. And which EEPROM reader/writers do you all recommend I purchase that will allow me to read the old values of the old...
          06-14-2023, 01:16 PM
