Samsung UN29EH4000 PS troubleshooting
  • handsworth
    • Oct 2015
    • 174
    Hi guys, this is my first post but I've been here many times for information. So I bought this 29" Samsung on CL $10. Did all the preliminary stuff and found that the backlights wont come on. Remote works, have sound and can see the picture image using the flashlight test. Ah , good so far. So I disco'd the main board, and the backlights just flash once when plugged in. I gather its either the PS or the LEDS. So before I take this thing fully apart to test the leds, can someone tell me what voltages I should be getting at the LED connection on the PS. Attached is the PS top and bottom. Your help is greatly appreciated.
    Correction: UN29F4000
  • CapLeaker
    Leaking Member
    • 8326
    Re: Samsung UN29EH4000 PS troubleshooting
    More likely the LED's. What do you get on DCV on each string? Does it ramp up then off?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Originally posted by capleaker
      more likely the led's. What do you get on dcv on each string? Does it ramp up then off?
      +100
      • handsworth
        • Oct 2015
        • 174
        If I'm doing it right, I only get +100 on pins -11 and +12. Reads 230V.
          Per chart as printed on the power supply-LED driver board, the LED Voltage is 113V, so the Boost converter is working but your LED circuit has open circuit.
          • handsworth
            • Oct 2015
            • 174
            So is the open circuit on the PS board or in the led string of lights. Just so I know which one to tackle.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              In the Led lights, so you will need to take the whole panel apart.
              • handsworth
                • Oct 2015
                • 174
                So I carefully took the panel apart and found one led had burned and came off one of the strips. I already ordered a new strip and hope this solves my problem. Will update in a few days. Thanks for the help.
                • handsworth
                  • Oct 2015
                  • 174
                  I received my new LED strip today and that solved the problem. TV is good to go. Thanks for the advice and hopefully I can help someone else.
                    Thanks for the follow-up.
                      09-07-2024, 05:50 AM
                    • max789
                      Samsung UE48H6410 replaced Mainboard but backlights doesnt go on
                      by max789
                      Hello, I have a problem with my Samsung UE48H6410SSXZG with the main board BN41-02156A and the power board BN44-00709A. Everything seemed like this, the TV could no longer be switched on, the standby LED always flashed 5x2 times. Backlight was off and no sound from TV. Also made the flashlight test and there was no picture.
                      I made the following tests:
                      1. Disconnected the main board from Power Board = backlight works.
                      2. Connected the main board and disconnected the T-Con = backlights does not work.
                      So I ordered a main board from Ebay also BN41-02156A but from...
                      01-18-2024, 06:56 AM
                      09-06-2024, 11:40 PM
                      09-06-2024, 08:40 PM
