Panasonic PVC-2021 Vertical Deflection
  • Krankshaft
    • Jan 2007
    • 2328
    Re: Panasonic PVC-2021 Vertical Deflection
    I agree for critical regulation like the vertical IC this approach was sloppy. An IC based regulator would have been better.
    The last Panasonic I worked on used linear IC regulators and none of this zener crap.
    I could have adjusted the height but it would feel weird to do this service mode value shouldn't drift unless something had changed since calibration.
    It's against my nature to tweak service mode adjustments unless a critcal part replaced requires it. I certainly didn't want to mask a real problem like a failing vertical IC.
    All in all I think it's because of the iffy temperature stablity of the core of the regulator circuit the zener diode it's right next to the regulator transistor like 2/16 of an inch away as it generates heat (and believe me it gets quite toasty) it heats the diode. Maybe this was intentional to heat up the diode and stabilize it thermally? Maybe not.
    Thanks for all the help on this guys.
    • Toasty
      • Jul 2007
      • 4171
      #42
      >>i really dunno why they bothered...why not just put 7812 and be done with it...<<
      Because the 7812 would still need this circuit as it is the on/off control. You'd need this plus the 7812. The zener was cheaper.
      veritas odium parit
      • Krankshaft
        • Jan 2007
        • 2328
        I honestly think that this was the core consideration of this circuit design.
        I considered scrapping the zener and using an LM317T to get the 11 volts but the end result would look a little hacked due to the resistors to set the output.
        Well hopefully I won't have to deal with a weird circuit like this again.
        Hear that Panasonic! Keep your kinky circuits to yourself .
        • Toasty
          • Jul 2007
          • 4171
          #44
          The cat foretells more Panasonics in your future...
          veritas odium parit
          • PlainBill
            • Feb 2009
            • 7034
            I'm surprised the vertical deflection was that sensitive to voltage. Of course, TVs have always had plenty of vertical overscan. It's been a fact of life from the days TV CRTs were round. Rather than using a regulator IC for the +12 supply, it should have been incorporated into the vertical deflection IC. Essentially a no cost improvement.
            And who says parts don't drift as they age? Yes, carbon film resistors are more stable than carbon composition, still care to bet some of the resistors haven't drifted in value? Caps change, too.
            PlainBill
            • Rensiee
              Panasonic TH-50PX8EA Black screen, only relay clicks
              by Rensiee
              I have been reading a few threads on here regarding Panasonic plasma tv's. I've found one thread which explains the same problem as mine, unfortunately the thread has not been completed.
              I got a free tv (TH-50PX8EA) from a friend which shows no screen. When plugged in only one red light shows up and when pushing the ON button, the red LED turns of and will only turn on again when pressing the ON button again.
              When plugging in the TV i hear two relays click fast and after a few seconds the third relay clicks.
              I have measured the voltage in the VSUS line, which...
              06-18-2024, 12:58 PM
            • Returning Buick
              Viewsonic G810 vertical deflection problem
              by Returning Buick
              I have a G810 monitor i've had for years but it has developed a problem with vertical collapse. Is there anybody here who has worked on these and can help me find where the circuit even is for the vertical deflection?
              04-01-2025, 07:57 PM
            • CoinCoin88
              Garage door RX unit (Cardin S38C) does not short relay to send opening signal
              by CoinCoin88
              I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
              Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
              09-15-2025, 03:36 AM
            • motorahead
              Sony Trinitron (KV-20FV12) Vertical Deflection Stopped
              by motorahead
              Hi everyone, I've been troubleshooting my 20" Sony Trinitron (KV-20FV12) CRT after it failed to show a picture. The standby LED is blinking 4 times, which according to the service manual is a failed vertical deflection via the self-diagnostic check during power up.
              After getting the TV checked out by a technician and doing research on my own. The most obvious first step was to replace the IC502. I've done so with an exact NOS replacement with no luck. I've read a few suggestions to make sure the 12V supply to pin 2, but that voltage check would seem misleading? It seems if the...
              10-21-2023, 03:50 PM
            • BigPete
              Panasonic Heatpump Dryer Repair
              by BigPete
              I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
              The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
              In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
              Unfortunately the whole machine has to come apart to fix it.
              I have...
              11-01-2025, 06:40 PM
