Lg42lw450u back light and sound good. No picture.
  • Cobblers
    • Jan 2016
    • 90
    • Uk
    Re: Lg42lw450u back light and sound good. No picture.
    Think im gonna keep hold of mine for now. Just incase anyone gets the same fault i found that r127 on the tab board was shorted. I removed it and the screen then powered up fine but it had a black line down it. So like i was advised it was a short causing the issue.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      That resistor should show shorted as its low enough ohms, but as you said panel fault not fixable.
      • adamp91gvm
        • Jan 2014
        • 706
        • uk
        Is it the two ribbon to t con one ? Will you sell it
        • koby058
          vostro comes up with back light but no picture
          by koby058
          Hi people!!
          The owner said it showed bad picture once in a while (attached)
          I see that there is back light but no picture.
          I want to ask if it is possible to disable the NVIDIA GPU and use the intel one?
          Also attached schematic and BDV
          LINK to schematic & boardview - https://www.badcaps.net/forum/troubl...ll-vostro-5590...
          07-13-2025, 01:03 PM
        • dronerat
          Samsung UE48JU6400W - back light on, sound on, sometimes picture.
          by dronerat
          Hi Guys,
          This forum has been in great help to me, but I stumbled upon a strange problem with a salvaged Samsung TV that I am banging my head to troubleshoot.
          PSU: L48S6 FHS BN44-00807D
          T-Con: BN95-01937A
          Panel: CY-GJ048HGLVLH
          MB: NA (Currently as the TV is assembled and forgot to take picture)
          As I said earlier I have some issues with the TV I got from a friend of mine. The TV had no picture, but sound, back light and everything else was working fine.
          It was sent to an authorized service for repairs and returned with the...
          05-15-2020, 08:03 AM
        • kca
          Samsung UN60F8000BFXZA ~ No Picture or Sound - 5 Res Light Blinks
          by kca
          Hello all ~
          I’m working on this Samsung 60” LED and purchased a new main board a couple of days ago that did not fix the 5 blink issue. The original main board’s HDMI ports (all 4 of them) failed to work and no amount of reflow remedied that.
          This 5 red light blink code on the front panel LED is followed (about 15-20 seconds afterward) by an automatic reboot, and results in 5 more red light blinks. Then the entire cycle repeats itself indefinitely.
          No picture. No sound.
          I tested all the voltages coming out of the power supply...
          10-12-2023, 05:23 PM
          Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
          This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
          I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
          I am comparing them to a brand new one that I installed
          The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
          I going to let it run for several days before I remount back on the wall next to the...
          09-05-2024, 06:48 PM
        • slimsoul
          Samsung TV`s UE32J5500AK and UE48H6400AK Red Standby Light - No Picture/Sound
          by slimsoul
          Hi, I'm new here and looking for some advice on how to diagnose an issue i have with 2 samsung TVs.
          I have a UE32J5500AK and a UE48H6400AK both with the same issue of red light but nothing happening on the screen, the red light responds to remote or button press by flashing once but stays red. I have searched forums but most turn up a blinking red light.
          I have tried replaceing the power board on the UE32J5500AK last year but this resulted in the same outcome.
          The UE48H6400AK recently developed some small bright areas on the screen, then last week would not power...
          03-12-2024, 03:55 AM
