RCA LED46C45RQ backlight but no picture
  • dynikus
    • Mar 2016
    • 7
    Hey guys, so my neighbor gave me an RCA LED tv, but there's no picture when I turn it on. I've tried some googlefu to find out what the problem most likely is, and everywhere said it's most likely the t-con board, so I ordered a new one and made sure the part numbers matched, but it didn't fix the problem.
    As far as I can tell, there aren't any blown capacitors on any of the boards, and the fuse on both the new and old t-con seem good, so I'm not sure what I should check next.
  • CapLeaker
    Leaking Member
    • 8130
    Re: RCA LED46C45RQ backlight but no picture
    there are a few things you can do:
    Check that you have power on both sides of the fuse on the TCon. Unplug one of the ribbon cables between TCon and the LCD panel, turn the TV on and see what happens. Then do the other side.
    Get an oscilloscope and probe the LVDS while turning on and off the menu all the time, or risk buying a new main board, hoping the LCD is good.
    Then you could "freeze" the eeprom on the main board (can of air upside down) and turn the set on. Check if there is a replacement eeprom available at SJ (there is). Make sure that your symptom is noted there.
    • dynikus
      • Mar 2016
      • 7
      Voltage is the same on both sides of the fuse. I didn't notice anything happen when either ribbon cable was unplugged.
      Don't have an oscilloscope and don't think I'll be buying one, but would it be plausible that the LVDS cable is bad? or would the problem most likely be with the main board?
      and what does freezing the eeprom do?
      • CapLeaker
        Leaking Member
        • 8130
        At this point we don't know if video is actually coming from the main board or not. If there is something coming from the main board, then check the TCon, etc... The LVDS cable itself being bad? Not really. So buying a board at this stage is not so hot, since you don't know which one to buy, unless you just throw money at it and cross fingers that it will fix it.
        The are some TVs that have trouble with the eeprom going bad. By freezing it and turning the TV on I'll give it a 75% chance to turn on, if that is the problem.
        • triplefour
          by triplefour
          09-13-2023, 10:43 PM
        • TR103
          by TR103
          - it keeps rebooting
          01-22-2025, 04:12 PM
        • shelby5041
          Samsung LCD TV no picture backlight on no 12v at tcon
          by shelby5041
          hi
          i have a samsung lcd tv
          it powers on with sound and backlight but no picture
          all voltages from PS are good 12v 3.3v and 5v
          whats odd is that at the tcon i tested voltage across the fuse on the tcon and i get 0v
          i figured main board issue..so i ordered a used main board....when i put replacement main board in i still have same issue
          no 12v at the tcon fuse
          i disconnect the panel ribbon cables to rule out any panel issues and i still have no 12v at the tcon fuse
          the odds of having 2...
          10-08-2021, 08:21 AM
        • Ierwin
          by Ierwin
          05-13-2025, 03:31 PM
        • Fly_Among_Stars
          VIZIO E70-E3 Half picture with half TCON
          by Fly_Among_Stars
          I have a VIZIO E70-E3.
          Symptoms: Black screen, no picture, but LED backlights are working.
          I probed the power board and voltages are as listed on the board.
          Main board appears fine, too.
          I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
          There are two separate ribbon cables feeding the LCD.
          If both are connected, the screen is black.
          If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
          04-24-2023, 08:20 PM
