Samsung UN60H6350AFXZA - No Pic
  • Audioplus
    • Feb 2012
    • 157
    No picture, responds to remote and has turn on-off audio prompts, audio works via digital out. By pass main board from power supply to panel to confirm it's not backlight issue.
    I replaced the main board (did not help), can the power supply still be issue?
    Did I get a bad main board (Best Buy parts direct)?
    or can it be T-Con?
    Thanks all!
    Re: Samsung UN60H6350AFXZA - No Pic
    We need good clear picture of the whole back side of the TV so we can see how all the boards are connected.
    • Audioplus
      • Feb 2012
      • 157
      Bud
      Don't have immediate access, I think there are only 2 cables from power supply,from power supply to Main Board, power supply to panel
      Main board to T-Con (ribbon), main board to wifi, main board to IR and the cable to PS (total 4)
      Confirmed panel OK by disconnecting PS to Main Board, although it seems like power is OK, panel lights up when main is bypassed), IR works with power on/off, digital audio out illuminates.
      No obvious issues with main or power supply, Shop Jimmy has a kit, PS, Main, T-Con, Wifi for $99.99 think I'll opt for that thinking that Parts Direct sent me a bad mainboard?
      Regards!
      • Diah
        • Feb 2013
        • 6575
        T-CON Fault
        on ebay just for 7 USD http://www.ebay.com/itm/SAMSUNG-UN60...-/121548979290
          We know that the power supply and LED drivers are OK when you have backlights without the cable to the main board connected, so something is locking out the main board from sending the BL-ON to turn on the backlights, it is either the main board, the WIFI board or the T-CON is locking out the signal, so try disconnection the T-CON board first and see, then the WI-FI board and see.
          $99 for all three boards is pretty reasonable price.
          • Audioplus
            • Feb 2012
            • 157
            Now that makes sense!
            Thank you . . . I'll confirm if it works
            • Audioplus
              • Feb 2012
              • 157
              Replaced the T-Con and it had blue LED's lit up (had not seen that previously), no response from remote, I said 'H___ with it', replaced the main board and PS (purchased the kit) works fine. It actually looked there was a MOTH that had fried a solder joint on the Power Supply. Is that possible?
              • Oglon3r
                • Jul 2015
                • 18
                Got the same exact problem on the exact model right now.
                Audio but No Visual.
                Seems to me like a T-con issue, will begin with that.
                Will also get the measurements to pinpoint failure.
                Anybody got a good idiots guide for multimeter usage? lol
                Thanks!
                • Hamie
                  • Apr 2014
                  • 1383
                  Uploading a good pic of the TCON would help.
                  • alltvrepairs
                    Plasma Samsung PS-50C96HD Main board BN94-01223C switches off supply after few seconds
                    by alltvrepairs
                    I have this almost brand new Plasma was well stored. I would like to repair it for a friend of mine.
                    I have noticed that it works for few seconds then switches Off the Power_ On signal. Have disconnected boards and left maion board and power supply and still the same. The power supply with PS_ON and VA signals On stays on so it is not a problem in the power supply.
                    Any one met this problem in the past?...
                    10-08-2025, 07:34 AM
                  • Asraf Atb
                    Help Needed: Samsung UE55MU8000 Dead - Possible Main Board Issue
                    by Asraf Atb
                    Im looking for some advice regarding my Samsung UE55MU8000 TV with main board model BN94-11606C. The TV suddenly stopped turning on and now shows no signs of life at all not even the standby light at the bottom.
                    Initially, I suspected an issue with the PSU, so I took it to a repair center. They tested it and confirmed that the PSU works perfectly, even on other TVs. Based on that, I started investigating the main board.
                    I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....
                    01-27-2025, 05:02 PM
                  • mrautom8
                    Samsung TV UN75H6350AFXZC main board schematics?
                    by mrautom8
                    Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
                    Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
                    While relay is on, all voltage rails are present and steady (scoped) on main board.
                    I love a good logic puzzle but getting lost without any schematics.
                    No shorts on ANY capacitor main board.
                    Thermal camera shows 3.3V inductor getting warm instantly but...
                    10-19-2025, 06:32 PM
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • Dani_2024
                    by Dani_2024
                    10-28-2024, 05:06 PM
