Questionable polymer on my Sharp LC-42SB48UT
  • AcGeorgiegirl
    • Jun 2013
    • 203
    I know this is maybe a fluke, because they don't have vents for expanding like the wet caps do, but I've a psb with a polymer that definitely looks like it's top is domed up a bit, on a tv that doesn't reach 5v standby. It goes up to 1.8. I'm wondering can I replace this polymer with a regular electrolytic, and if so, should the uf or voltage be a different amount? I would have included a pic, but I couldn't get the "bulge" to show up with my camera, sorry.
  • Diah
    • Feb 2013
    • 6614
    Re: Questionable polymer on my Sharp LC-42SB48UT
    short answer Yes, same uf but with 10% more voltage than polymer.
    either its hardly to say from the top look of polymer. as all had curve top . best way took out and check.
    • Alastair E
      Chief Womble
      • Mar 2013
      • 1963
      • U.K.
      Try it and see...
      --Either work--Or not....
      Poly caps dont tend to fail as regularly as std caps so would doubt thats the issue.
      TELEFIX
      • AcGeorgiegirl
        • Jun 2013
        • 203
        Is it more probable that the psb's filter cap might be going bad? I don't have an esr to test, but thought about replacing it after trying the polymer.
        • Diah
          • Feb 2013
          • 6614
          in general no, but some lost contacts on its bed. just re soldering or heating them will be back to life
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            Doubt it, more likely stdby reg is working in burst-mode for some unknown reason, maybe leaky diode on its o/p or short on that rail in m.b. or no f/b loop due to dodgy opto or the controller chip itself.
            TELEFIX
              • 31304
              not 10%, you need the cap to be rated for atleast 150% of the voltage it will see.
              a lot of people do stupid things with cap voltage ratings, you can get in big trouble if you dont know what is actually going to hit the pins.
              • Diah
                • Feb 2013
                • 6614
                you miss understood, 10% more as actual voltage value, exp. 30 = 35 lol
                • AcGeorgiegirl
                  • Jun 2013
                  • 203
                  Thanks, Alastair. Any chance of getting a bit of a workflow idea for testing/troubleshooting all those techie things you mentioned? I started trying to decipher what they mean, but I exhausted Google's abilities.
                    • 31304
                    no, i understood and as an ex design-engineer i know that 10% is not enough overhead to deal with ripple for long.
                    you need 50% overhead or the cap will heat up.
                    • Diah
                      • Feb 2013
                      • 6614
                      no, i understood and as an ex design-engineer i know that 10% is not enough ....you need 50% overhead
                      well, the poly caps installed now days are all had 100% more as real current ,poly cap ex 12V line had 25 VC , do you really think how much more ..they will let them more life.. no.. they may fail to produce the real currents at once. 10% more mean as this example 12V line instead 25V cap enough whole life 35V cap.. sorry for any bad feeling you got.
                        • 31304
                        35v on a 12v line is good, it will have a higher current capacity.
                        • AcGeorgiegirl
                          • Jun 2013
                          • 203
                          Could you give me some explanation of your acronyms, possibly? I don't know what "o/p", "m.b", "f/b loop", and "opto" are referring to.
                            • 31304
                            o/p = output
                            m.b. = main board
                            f/b loop = feedback loop
                            opto = opto-isolator, usually part of a feedback loop
                            • AcGeorgiegirl
                              • Jun 2013
                              • 203
                              Awesome, thanks! Very helpful.
                              • chth96
                                Should I replace polymer capacitor?
                                by chth96
                                a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
                                I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
                                Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
                                Is this ESR value of polymer capacitor correct?...
                                11-18-2022, 04:22 AM
                              • Perry Babin
                                Derating of polymer electrolytics
                                by Perry Babin
                                There have been suggestions for derating polymer electrolytics to below the rated values. I've seen documents that recommended this and some that indicate that derating isn't required. The documents recommending derating are often old or refer to old documents. Do polymer caps of this type still require derating for reliability?
                                If they require derating, why would the manufacturer give them their rated voltage?
                                This is the basic type of capacitor I'm referring to and included simply to eliminate other caps that use similar names.
                                https://www.mouser.com/datashe...
                                10-24-2025, 11:57 AM
                              • Perry Babin
                                How do organic polymer caps compare to liquid electrolytic for reliability
                                by Perry Babin
                                I have a situation where a power supply is commonly abused and the 12v supply caps take a beating. They don't commonly fail but they run hot. I was thinking about going from a liquid electrolytic (Panasonic FC and Nichicon HE) to an organic polymer. The values have been 330uF. I typically use a higher-than-needed voltage to get a lower ESR. The supply is operated from 12v.
                                If not organic polymer, what would be the caps that could take the most abuse?
                                08-18-2025, 04:04 PM
                              • advant
                                by advant
                                02-03-2020, 12:25 AM
                              • sefoster
                                Sharp Aquos Lc-80LE757U flashing Sharp on screen when plugged in
                                by sefoster
                                I have a Sharp Aquos LC-80LE757U that randomly made a loud popping noise when when watching TV one day. We found that the fuse blew and the thermistor. We ended up replacing the entire power supply board and have also replaced the TCON board. Now as soon as I plug the TV in it lights up and has the Sharp logo flashing on and off of the screen. If I unplug the ribbon cable from the TCON board to the main board I get the 2 long 5 short error code. Any ideas on where to go from here? We've tried resetting it but nothing has worked. If we plug it in and let it cycle through the flashing of the Sharp...
                                11-20-2022, 09:29 AM
