Sony KDL-46X4500 - 6 LED Blink Code
    replied
    Re: Sony KDL-46X4500 - 6 LED Blink Code
    Looking at the service manual for the 46'', this TV uses RED, BLUE, and GREEN LEDs for Lights source, not the typical WHITE LEDs.
    This is not going to be easy troubleshooting.
    I will not do the panel tear down yet.
    Thed LED board may look something like this.
    http://www.sony.co.nz/article/358578...ct/kdl-46x4500
    RGB Dynamic LED
    BRAVIA X Series can display the widest range of colours through the use of RGB LED backlighting which has a unique arrangement of red, blue and green LEDs.
  • AlbertRoss
    replied
    Correct board but as you said, we are for some reason unable to get the website for shopjimmy here in the UK?
    So do I take a chance and tear down the panel or go for a new board?
    replied
    OK, I found the picture of the board at shopjimmy (you may not be able to get the website in UK.
    http://www.shopjimmy.com/sony-a-1553-199-a-gl-board.htm
    Picture provided by shopjimmy.
  • AlbertRoss
    replied
    P/N for the LED driver is: 1-877-581-11.
    A1553199A.
    I've only disconnected the lower connector that enters into the rear panel which I presume goes to the LEDs?
  • CapLeaker
    replied
    Sounds like you have to tear the panel down. Bad LEDs?
    replied
    It uses LEDs for backlights with that big LED driver board on the left side, I have never seen LED driver board that big before, so basically you have disconnected the LED backlights from the driver board and the 6-BLINK code went away.
    I need to do some research about this model. I will download the service manual to see what kind of info it has for this TV:
    Can you read the P/N of that LED driver board?
  • AlbertRoss
    replied
    3.38V on the BLon pin both when TV on and standby, bearing in mind I still have the 1k resistor connected so I'm probing the empty cavity from where I removed the wire. I have done the flash light on the screen but unable to see a image?
    I was thinking the same thing about the CCFLs so was trying to find some kind of inverter board?
  • AlbertRoss
    replied
    Seems as if I've just repeated myself, I will do some more measurements.
  • AlbertRoss
    replied
    Disconnected lower wiring connector which I presume operates the backlights?
    The top wiring connector, just above the heat sink is still connected.
    The TV will now stay on with green LED light showing and the center SONY logo on the front panel remains lit. The TV is able to turn on/off either by using the remote or TV switch, it doe's not enter blink mode but still no picture or sound?
    Not sure if I should now remove the 1K resistor and then try again?
    replied
    Can I see the pictures of the whole back side of the unit that will show how all the boards are connected together?
    My mistake to think that this model uses CCFL, it uses LED backlights so it does not have HV Inverter circuits.
  • AlbertRoss
    replied
    I have disconnected the lower connector that I presume operates the backlights? The top connector that I also presume is for the backlights, is still connected. The TV now stays on with green LED showing and doe's not enter blink mode. I'm now able to turn the TV on or off using both the remote and the TV switch but there is still no picture or sound?
  • CapLeaker
    replied
    What do you get on the BLon pin when it is unhooked from the PSU? Ever shined a good flashlight into the screen to see if there is any life on the LCD?
  • AlbertRoss
    replied
    Backlights do not come on during this time, have never seen any backlights, no sound or image, only the SONY logo and a few icons on the front lower panel.
  • AlbertRoss
    replied
    Almost, just tried it again.
    Power cable connected to wall outlet and TV, switch on wall outlet (00.00V) turn on TV with panel switch, green LED shows on front panel, approx. 6 seconds later with green LED light still on, the voltage drops to 00.00V. It does this just before the TV enters blink code?
    Have never seen the backlights work, also no sound or picture?
  • CapLeaker
    replied
    When the TV is on with a green LED, you have 0V on the INV_ERR pin.
    But then there is a short blip to 3.08V and the main board goes to blinking? No backlights for 2 seconds or something?
  • AlbertRoss
    replied
    I have now checked all voltages again because before I had 00.00V on INV_ERR. With TV on (green LED) I have 00.00V, just a split second before TV goes in to blink mode I get a voltage of 03.08V but then drops to 00.00V?
  • AlbertRoss
    replied
    Removed BLon terminal from plug to main board, soldered 1K resistor from STB (rear of board) across to BLon. TV on - 03.37V, after a couple of seconds, TV went in to blink mode, voltage dropped momentary but then went back up to 03.38V.
  • AlbertRoss
    replied
    Ok, thanks, will do first thing tomorrow!
  • CapLeaker
    replied
    BLon sitting at 1V isn't enough to turn the backlights on. I should have more than 2V.
    So you may have to do following:
    Unplug TV. Remove the BLon pin out of the plug that comes from the main board back to the power supply (we dont want to feed back power). Next solder a 1k resistor from STB to BLon on the powe supply. Plug the TV back in and turn it on and check those voltages again.
  • AlbertRoss
    replied
    Readings taken just before TV goes in to blink mode:
    HVR - N/U
    DIMMER - 00.98V
    B/L_ON - 01.00V
    INV_ERR - 00.00V
    BALLANCER_ERR - 00.00V
    POWER_ON - 03.31V
    AC_OFF_DET - 03.13V
    STB - 03.37V
    REG12V_GND - 00.00V
    REG12V_GND - 00.00V
    REG12V_GND - 00.00V
    REG12V - 11.98V
    REG12V - 11.97V
    REG12V - 11.98V
  • cloo
    Panasonic ZT60 plasma tv with strange behavior and 8 blink code
    by cloo
    I recently got my hands on a 60" Panasonic P60ZT60 plasma tv (european model) that has some strange issues along with an 8 blink code.
    It know this tv is getting old but it was once considered one of the best plasmas ever made, and i think it is still holds on to that even by todays standards.
    So, long story short. When i first got the tv it had a very bright washed out picture with very raised blacks in all picture modes and i couldn't find the cause in the picture setting menus.
    After doing a factory reset this problem was gone and the picture was back to...
    01-06-2025, 06:02 AM
  • reporter1979
    2 red blink code on old led tv Sony KDL-40W2000
    by reporter1979
    Hi all, the TV KDL-40W2000 was flashed by a lightning.
    Firstly I got the 3 red blink code.
    Following other threads I changed the power supply board and got always 3 blinks.
    So I changed also the mainboard and now I get 2 blinks error code. Tried also with the other ps board, still getting 2 blinks.
    The TV turns on for a minute or two with green led and blank screen, if I press buttons the green led blinks fast. It turns to 2 red blinking led after a while.
    What else can I do?...
    02-17-2023, 11:50 AM
    LCD LED TV Service Menu Codes
    ALL LCD LED TV SERVICE MENU CODES
    Service Menu Code with Board Name
    China Universal Board / Jumper Board Service Menu Code
    Changhong Ruba Service Menu Code
    Ecostar LED TV Service Menu Code
    Orient LED TV Service Menu Code
    Haier LED TV Service Menu Code
    TCL LED TV Service Menu Code
    Samsung LED TV Service Menu Code
    LG LED TV Service Menu Code
    Videocon LED TV Service Menu Code
    Supra LED TV Service Menu Code
    Toshiba LED TV Service Menu Code
    Symphony LED TV Service Menu Code
    Veste/ LED TV Service Menu Code...
    10-31-2024, 03:58 AM
  • Storyteller12
    Sony XBR-65X900E 4 Blink Code
    by Storyteller12
    I have this set. It turns on and is watchable for a few minutes but then shuts off and flashes 4 red lights.
    I don't work on Sony much but assumed it was backlights from what I read.
    Opened up the TV and tested all the backlights with led tester and the all work.
    I know sometimes that doesn't mean anything since it's not running at full current but I hate to spend $120 on backlights (shopjimmy) is the only one that even has them just to find out I missed something.
    So anyway to test these lights similar to the way we test...
    12-31-2022, 02:17 PM
  • rmacintosh
    Panasonic Plasma repair - TH-P60GT50 - Dead, 3 blink code
    by rmacintosh
    I aquired this Panasonic 60" plasma around the time my first child was born. It was meant to be a project tv, hoping to fix it chipping away at the repair in my free time. Well that was 2 years ago and i'm really just getting around to making a sincere effort to see if I can ressurect this beast.
    The symptoms of the tv ar as follows:
    • Plug AC in to back of TV
    • After about 2 seconds the relay on the P-sub board will click on and then a fraction of a second later it clicks back off
    • The 3 blink code is given by the power LED
    • If the TV is unplugged and then
    03-14-2020, 12:24 AM
