Re: Panasonic tc-p55gt30
You are missing a plastic cover that goes over the power cord. If you are careful with the cord, you could probably just cover the opening with tape to risk shock. I would try to find the cover. Someone has had it apart apparently with that missing. Not sure on the fans, but I think there are four. More than likely with 8 blinks, you probably have a bad SS board which is the board on the right side looking from the back. You will need to remove the "A" board or at least move it out of the way to get to the connections. The "A" board is the one with all the video connections. I will try to look tonight at the training guide to tell you how to check the 8 blink code or if you are lucky tw2005 will chime in as he is really knowledgeable in Panasonic plasma's. The SS board can be repaired at component level, but I think you can get them pretty cheap. Definitely diagnose first. I think on this model if you want to use the component, composite and audio you need adapters which are available. I guess I am getting ahead of myself, first you have to get it fixed.
Disregard my last two posts. Using my awesome internet skills, lol, I've found the part number for the cover and it only has 2 fans.Leave a comment:
A couple of pictures of the back. I haven't doe anything. Tomorrow I'll open her up.
There is a part missing by where the power cord is. I've never seen a TV like that. Can any one tell me what is missing?
Also it looks like there are slots for 4 cooling fans but there are only 2, on the left side.
Is this how this model is?Last edited by Malachi; 02-24-2016, 06:09 PM.Leave a comment:
I just picked it up. Man it's heavy for a 48 year old out shape to carry and fit in the back seat of a Honda Civic.
The seller didn't want $50 anymore. She got offered 32" tv's in trade I traded a 37" sylvania lcd that I picked up for free.
It wasn't working, put a new t-con board it for $20 and it worked.Leave a comment:
I just fixed a p55gt30 and definitely buy it for $50.00. Need to find out the code. The boards on these are very hard to find and can be a little tricky to diagnose. Recommend downloading the Panasonic trouble shooting guide usually Electranya has them for free. There is a lot of Panasonic help on this forum and I got help on mine and it worked out. I paid $100.00 for a 7 blink oneLeave a comment:
One of the best TV's ive ever owned i got mine for free out of a electronics dumpster lolLeave a comment:
Malachi, if you are afraid to annoy the seller than just tell him you will take the tv and go over and just check it out. If it has a cracked screen, or if the sets turns on and has lines, just don't go through with it. If its anything to do with the tv turning on and then shutting back off, or not turning on at all, then definitely buy it! Be prepared to spend at least $100 on parts to get it fixed however unless you can do the repair on a component level. Those SC and buffer boards go out more often than anything else and can get tricky to fix yourself if you don't have much experience.Leave a comment:
Quality difference between the PZ80U and the GT30 will be huge! You will not be dissapointedLeave a comment:
I know. I had a th-42pz80u then a th-50px75u.
Now I have 2 lg. a 50pm6700 and a 60pn6500.
The panasonics looked much better. I was going for size.
I'd like to swap the 50pm6700 with the Tc-p55gt30.Leave a comment:
I would buy the tv! But thats also because im a huge Panasonic plasma fan. I own a 50VT50 and last Saturday i bought a defective 50VT30.
This set for $50 is cheap!Leave a comment:
I don't want to annoy him by asking too many questions. Lol. He may move to the next buyer. I was the first one to contact him.
The panel is not cracked that I can see in the pictures. Of course not being on, but no visible cracks.Leave a comment:
Then i would still buy it. Only reason i would NOT buy this tv for $50 is when the panel is cracked. And if the panel is cracked you can always sell the boards for more!
Find out what the blinking code is and search the forum! I'll bet that the tv is blinking 7 times....Leave a comment:
He says the led blinks. He isn't home from work yet. If it's on solid without blinking, don't buy it?Leave a comment:
For $50 i would buy this tv.
If it has power then it probably is giving a blinking error. ( Led is for example blinking 7 times ).
So find out if it gives this blinking pattern , if so then buy this tv!!Leave a comment:
I have the option of buying this for $50. Owner says it doesn't turn on but gets power.
Seeing I lost almost $200 on the lg 60pv250, should I take a chance on this?
He says it still gets power.Tags: None
by riparoHi everyone, I have a Panasonic OLED TV model 55EZ950E, as soon as I turn it on I don't have any image the LED goes from green to red LED blinking every 4 sec, I found the service manual suggests checking OLED PANEL, PB BOARD, T-CON connectors but it seems like everything ok, I didn't find any burns under the pb board
I attach a link to download the service manual, thank you for anyone who can help me
https://tel-spb.ru/download/?brand=P...0E_LA73.rar -
by CoinCoin88Hello there,
Google led me again to badcaps when trying to troubleshoot a dying Plasma that is sitting at my uncle's roughly 550 km from where I am. It's an old G20 from 2010 or so, that isn't being actively used so you can consider the panel "not too sollicitated".
Symptoms: TV starts, works for 5-10 minutes, then screen turns black and safety kicks in and spits a 13-blink code with the red LED. Once this code kicks in, the TV will not display any image anymore. Unplug it for a few minutes, plug it again, it'll work then fail a few minutes later.
Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
...1 Photo11-20-2024, 08:52 PM -
by ItepKHey everyone!
I've gotten this TV for free, neither have it seen a TV repair man, neither have it been opened before.
This post describes my entire troubleshooting process of this TV.
When I turn it on using the ON/OFF switch at the side of the TV, the light rapidly flashes green, then it stays on, but it does not react to any of the remote buttons, side buttons, and doesn't play audio.
I've taken the unit apart, and I've started to check some voltages:
- On the P11 connector, there is 15V DC only for a brief moment, then it goes
by TofHello everyone, here is the issue I am facing with my Panasonic Oled TX-65FZ800e.
When the TV has not be used for some hours, I power up the TV with a video input and the image is displayed perfectly for 30seconds and then the TV switch off with the red light blinking every 4 seconds for ever.
The service manual explanation: EVDD_SOS (EVDD 24V error) with check point (oled panel, P board, A board, T-CON)
I opened it and found a burned connector on PB-board on the 24V pins.
The 24V wires have change a bit of color due to the overheat and the corresponding... - Loading...
