LED back lights
  • 120volts
    • Oct 2013
    • 57
    LED back lights
    What the heck
    They advertise that LED back light is the new greatest thing but it's seems to be the worst new thing. Why didn't they make them more accessible ?
    I guess it's great for techs who are willing to pull the screen assembly apart.
    Dan "TV Tinkerer"
  • 120volts
    • Oct 2013
    • 57
    Re: LED back lights
    I've been picking TVs out of the dump for years, Now I find LED backlight failure is becoming very common. Not fair to consumers when a $3 part causes the failure of a $400 or $500 TV. Why didn't they mount them from the back so they could be replaced?
    Dan "TV Tinkerer"
      • 31303
      Re: LED back lights
      same reason the fuses are soldered in, because "no user recoverable parts inside" so go buy another!
      • ZnsaneRyder
        • Oct 2015
        • 88
        • Merica
        Re: LED back lights
        I just ordered 100 white SMT LED to repair these LED strips because the strips are too expensive and the LEDs are weak anyway.
        I have a Sanyo to repair, got it to come on, just two blown LED, very nice TV.
        • ZnsaneRyder
          • Oct 2015
          • 88
          • Merica
          Re: LED back lights
          After much tribulation with the Sanyo, it is better to patch a new piece of strip in place of the old LED. Better than Soldering SMT and dealing with the lenses on the leds
          • michael dranfield
            • Jan 2016
            • 232
            • England
            Re: LED back lights
            For the same reason there are no schematic diagrams in the service manual on modern sets and spare boards are no longer available after only 18 months ,you are supposed to drop the set in the bin and go out and buy another one which will last less time than the one it replaced .
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              Re: LED back lights
              It does seem as though the sets produced today are made for a limited lifetime but I guess that's the the result of producing cheap sets. My Panasonic plasma now 8 years old is still going strong but was very expensive at the time it was purchased.
              What I can't get my head around is the sheer number of screen breakages and as mentioned above, led failure. Pity the led strips weren't run in slotted guides for easy removal of the entire strip. I couldn't see that pushing up the manufacturing cost of the sets.
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                Re: LED back lights
                That's because manufacturers like Philips sold the tv branche to a cheap chinese/japanese ( not sure ) company which make the tv's really cheap. They use for example the same capacitors which people buy on eBay in bulk ( 125 for $7 ).
                Those leds are made to last for a small period of time so people will buy a new tv instead or repairing it. Thats why those led tv's cost like $ 300/400.
                No way that my VT50 plasma tv will go for a led tv
                  • 31303
                  Re: LED back lights
                  there is a website i'v seen with the ultimate ghetto-hack fix for this.
                  the guy cuts the rear out of the panel frame, and mounts it in an old crt monitor case with the pcb's on the bottom and a domestic cfl lamp in a batten holder screwed to the back of the case!!!
                  • tennno`
                    RCA LED46C45RQ,Sound but no Back lights
                    by tennno`
                    Sound no picture RCA LED46C45RQ,Power Supply Board RE46HQ1301.
                    Has All voltages coming from main board.No voltage going to
                    Back lights from power board.Have no Schematic.Back lights work when
                    Led Back light Strip tester is used.Tester shows 110 volts from each
                    side.Also if you use the side controls and use the vol +or- tv shuts
                    down.
                    Thanks for any help
                    04-10-2022, 03:34 PM
                    Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                    by sam_sam_sam
                    This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                    I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                    I am comparing them to a brand new one that I installed
                    The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                    I going to let it run for several days before I remount back on the wall next to the...
                    09-05-2024, 06:48 PM
                  • Musictuff
                    70UH6350 Back lights
                    by Musictuff
                    My LG tv started going dark a few seconds after powering on. I replaced the led back lights after doing the flashlight test. The problem I am having now is the bottom of the screen is really bright and the middle to the top of the screen is darker. I can actually see the individual leds at the bottom of the screen. Not sure why that is. I've tried lowering the backlight setting but I can still see the led's at the bottom, and the middle to the top of the screen gets even darker.
                    04-09-2023, 11:45 AM
                    HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i7-9700 Specification for Upgrade or Repair
                    This specification for the HP ProDesk 600 G5 + APC Back-UPS 700VA can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + APC Back-UPS 700VA boardview and ProDesk 600 G5 + APC Back-UPS 700VA schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                    09-12-2024, 02:30 PM
                    HP ProDesk 600 G5 + APC Back-UPS 700VA ProDesk 600 i5-9500 Specification for Upgrade or Repair
