LG 37LS570S TV no picture or sound
  • fpegman
    • Mar 2011
    • 16
    • Spain
    LG 37LS570S TV has no picture just blue screen have replaced TCon board still same any body help please
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: LG 37LS570S TV no picture or sound
    Got an image of the fault ?
    • fpegman
      • Mar 2011
      • 16
      • Spain
      Sorry nothing to see just a blueish screen
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        Yes but can you post pictures of the boards and the fault? Does the menu work? Some tv's have a blue background which you can disable haha.
        • fpegman
          • Mar 2011
          • 16
          • Spain
          The blue background is not the one you can disable menu does not work just get a plain bluish screen and there is no viable fault on any of the boards
          I did get a part picture when I first got the tv but I had vertical lines on the screen so checked the LED connecting flat cables and lost everything so I got a new TCon board and still nothing I did have sound before but not now I have tried with a DVD connected with HDMI cable still dead
            Try running the T-con with just one ribbon cable connected at a time. Do you get a partial picture?
            • Diah
              • Feb 2013
              • 6575
              since you where only at T-CON playing, there are of sure when you took the ripon cable you had now broken line or shortet betwenn 2 line, in this case you have this fault and the register of the LCD has bein delete ( empty at main memory of it. took out the t_CON totaly from main board, you should have sound when you play HDMI No 1 with ACR
              • fpegman
                • Mar 2011
                • 16
                • Spain
                Yes I did have sound before I took out the cables and I had a partial picture but with vertical lines I now have just nothing so what shall I do now please
                • fpegman
                  • Mar 2011
                  • 16
                  • Spain
                  No I tried that thanks
                  • fpegman
                    • Mar 2011
                    • 16
                    • Spain
                    Any other suggestions please
                    • fpegman
                      • Mar 2011
                      • 16
                      • Spain
                      Help please
                      • iglitare
                        by iglitare
                        09-04-2025, 07:13 AM
                      • TR103
                        by TR103
                        - it keeps rebooting
                        01-22-2025, 04:12 PM
                      • Ierwin
                        by Ierwin
                        05-13-2025, 03:31 PM
                      • jchang
                        Samsung UN70NU6900F no picture and no sound
                        by jchang
                        Hi all
                        I was just given a Samsung TV with the issue. I read various threads and videos and attempted the ribbon tape method to gain an image, but no luck.
                        Symptom:
                        No picture no sound.
                        When I plug in the power cord, Backlight LED turns on for a half second and then turns off. The red LED next to the power button located center bottom flashes 2 or 3 times. When the power button is pressed after, it does the same thing.
                        No sound at all.
                        What I tried:
                        1. I tried unplugging the left or right ribbon...
                        01-09-2023, 06:28 PM
                      • Fly_Among_Stars
                        VIZIO E70-E3 Half picture with half TCON
                        by Fly_Among_Stars
                        I have a VIZIO E70-E3.
                        Symptoms: Black screen, no picture, but LED backlights are working.
                        I probed the power board and voltages are as listed on the board.
                        Main board appears fine, too.
                        I believe the problem is either a bad T-CON board, or connection to LCD, or bad LCD.
                        There are two separate ribbon cables feeding the LCD.
                        If both are connected, the screen is black.
                        If only the ribbon cable that feeds the right side of the screen (when viewed from the front) is disconnected, the left side of the screen shows picture and...
                        04-24-2023, 08:20 PM
