Sony 32inches LCD TV turning off and on
  • rickronn
    • May 2008
    • 5
    I am experiencing problem with my Sony 32 inches LCD TV which would turn off and then on suddenly. This would occur frequently when I first turn on the TV, then it would go away when the TV has been on for over an hour.
    Thanks in advance for any help.
    Best regards,
    Rickronn
  • japlytic
    • Oct 2005
    • 2086
    Re: Sony 32inches LCD TV turning off and on
    This looks like a thermal problem.
    If not under warranty, carefully try disconnecting and reconnecting the power supply board(s) first.
    There should not be any bulging capacitors on the power supply board(s).
    • rickronn
      • May 2008
      • 5
      I did try to open up the unit and clean up the dust to help air flow but it did not help.
      Also, it is strange that it switches off and on when it is turned on a while. Then it is gone after it has been powered up over an hour.
      Best regards,
      Rickronn
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        i remember sony sets with tons of ringcracked solder joints.
        time to take a closer look.
        • rickronn
          • May 2008
          • 5
          Any other possibilities? Anyone has experienced similar problem?
          • Harvey
            • Apr 2007
            • 264
            Model Number?
            • rickronn
              • May 2008
              • 5
              Hello, Harvey,
              Sorry for late reply. Model no. is KLV-L32MRX1.
              Best regards.
              • sabretooth
                Sony KD-60X6700E not turning on
                by sabretooth
                I have a Sony Bravia KD-60X6700E which has decided to stop working. To describe the symptoms - it just decided to stop powering on one morning. No standby LED, no sounds, no picture, no startup logo - nothing. Doesn't respond to the remote nor the physical power button on the unit.
                I have tested the power cable for continuity. I have also tested the fuse, and that too, has continuity. However I haven't gotten much further with the probing. I've prodded the secondary side of the power supply where the connector connects to the main board, and there's no voltage...
                12-21-2024, 08:03 AM
              • Carlos#2003%
                Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                by Carlos#2003%
                Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                02-15-2024, 07:52 PM
              • dkneyle
                Sony KDL-46HX850 Can't upgrade/update firmware
                by dkneyle
                Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                09-25-2024, 10:44 PM
                Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                09-06-2024, 05:27 AM
                Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                09-06-2024, 05:30 AM
