Using bulb to test X main after IGBT/Gate driver IC replacement
  • tech2014
    • Aug 2014
    • 807
    I have a Samsung plasma TV that keeps clicking at power up. I found VS measured shorted on the X Main. I found it had 4 shorted IGBTs. I replaced all of them and also plan on replacing all of the gate driver ICs, FAN73611 and FAN73711. After replacing the gate driver IC, I want to somehow test the board with a bulb to make sure I didn't miss anything.
    How would I go about doing this?
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Using bulb to test X main after IGBT/Gate driver IC replacement
    Disconnect the Vs supply Only from the Y-SUS/X-SUS, then wire a 100-150W 240V bulb in series from Vs plug on the PSU to Vs point on Y-SUS/X-SUS--Whichever you're testing/protecting....
    TELEFIX
    • tech2014
      • Aug 2014
      • 807
      ok, how do you wire the bulb?
      • Alastair E
        Chief Womble
        • Mar 2013
        • 1963
        • U.K.
        Youve replaced IGBT's, Driver-chips etc etc.....
        And you're asking HOW TO WIRE A BULB!!
        Sheesh!!
        TELEFIX
        • tech2014
          • Aug 2014
          • 807
          never done it or know anyone who has. bulbs don't come with wires.
          • Alastair E
            Chief Womble
            • Mar 2013
            • 1963
            • U.K.
            Oh good grief....
            Batteries dont come with leads--But you manage with those!
            Thats what Soldering-Irons are for!
            TELEFIX
            • vinceroger69
              • Mar 2012
              • 6714
              i just use a bulb holder for the bulb and then connect that way.
              • tech2014
                • Aug 2014
                • 807
                thanks for the reply vinceroger69, that makes sense, and without the attitude
                • mikkele86
                  Power amplifier SMPS IGBT keeps blowing - Artcoustic PDA1000
                  by mikkele86
                  hello.
                  I have two power amplifiers, both having their IGBT blown on the PSU.
                  The original mounted IGBT where marked with IRGB20B60PD1PbF and the gate driver is a IR2156STRPBF.
                  I looked at mouser and digikey and could not find any available IRGB20B60PD1PbF and somehow ended up using a Bourns BIDW20N60T.
                  I replaced the gate driver, the gate resistor and both IGBT. But as soon power is turned on, both IGBT shorts out completely (gate, emitter, collector) and the fuse on the AC line gets killed.
                  So I though i missed a capacitor or diode. I removed...
                  01-06-2024, 06:45 AM
                • osrex
                  LED DRIVER KEEPS DYING
                  by osrex
                  Hello, this is my first post and im just a beginner, so be easy on me guy. thanks
                  i have a LED chandeilier that switches colors from white to cool white to warm when toggling the switch, it has 24 LED arms, each arm is 30 CM length.
                  i have no datasheet at all for the LED lights, all i have is its length.
                  long story short, testing the chandelier on the ground, and it works fine for 1 - 2 - 6 hours, no problem.
                  as soon as i fix the chandelier to the ceiling and bury the driver inside the hub,...
                  05-05-2025, 03:36 PM
                • tvguy12012012120
                  by tvguy12012012120
                  02-07-2025, 05:13 PM
                • repair-it
                  TOSHIBA DLP 52HM95 How to reset timer module on bulb
                  by repair-it
                  I replaced the bulb only on my Toshiba DLP The bulb is a TB-25. This is the first time I've done a bulb only replacement. Supposedly there is a timer module that needs to be re-calibrated or reset. I don't know where the module is located. I see some vendors selling the bulb with the housing stating module included which leads me to think the module is located inside the enclosure the bulb mounts in, but I didn't see it. Maybe it's inside the plug attached to the bulb?
                  Anyway - I am seeking information on how to reset this so called module so that the lamp will operate. Apparently...
                  10-11-2023, 07:18 PM
                • ezenia
                  LUMIMAN Smart Bulb IC ID?
                  by ezenia
                  I have a LUMIMAN Smart Bulb that suddenly stopped lighting one day. The bulb is still detected in the app, but won't light. I've probed around and nothing seems to look off with any of the diodes, caps or resistors. The Bluetooth/Wi-Fi module seems to be working as it's still detected in the app. I even tried deleting and re-pairing the bulb (it didn't light, but I was still able to follow the pairing instructions), it re-paired fine, but still no light.
                  In diode mode, the LEDs all light up when probed so I'm guessing this means the LEDs themselves are OK. I was expecting...
                  04-28-2025, 05:56 PM
