SAMSUNG UE32EH4003W Backlight
  • pyrosster
    • Aug 2013
    • 43
    • Spain
    Hi guys
    Got this tv today and it doesn't turn on the backlight.
    The voltages on the power supply are good and and I'm wondering what else can I look?
    The voltages on the power supply are:
    CN803
    1-2 PWM_DIM = 13V
    3-4 B13V = 13V
    5-6 BLL_ON/OFF = 13V
    7-8 VAMP = 13V
    9-10 GND = 0V
    11-12 A5V = 5.3V
    13-14 POWER_ON/OFF = 5.3V
    CN802 -> LED BACKLIGHT
    1 D+ 0V
    2 S- 170V
    3 NC
    4 S+ 170V
    5 D- 170V
    These voltages for the led backlight are ok?
    Thanks for your help!!
    Re: SAMSUNG UE32EH4003W Backlight
    Your LED driver Voltage is fine, it is more likely that you have open circuit in the LED strings.
    How about some good clear pictures of the whole back side and the boards?
      09-07-2024, 05:50 AM
    • sansanpartida
      Samsung QE82Q70RAT no backlight
      by sansanpartida
      Hi everyone!
      Hope you're all having a great day, and thank you very much for stopping by and taking the time to read this post to help me with my parents' Samsung TV.
      My issue: No backlight.
      Model: QE82Q70RAT
      Type No: QE82Q70RAT
      The TV was already serviced by Samsung once under warranty for the exact same issue, but six months after the fix, the backlight went out again. Now, Samsung is asking for nearly the same price as a brand new TV to fix this with the same 6-month guarantee.
      So hopefully, I can fix this cheaper.
      05-22-2024, 06:56 AM
    • howardc64
      Samsung UN55NU7300F Curved TV. Half side backlight out. Fixed by just removing the rear snap cover
      by howardc64
      TV was fixed just after removing Samsung's rear snap cover.
      This curved TV's construction is rather interesting. When the snapped on back is removed, rest of the TV will relax the curvature. Top of LCD panel is loose as it wants to straighten out against the slightly curved bezel. Snapped back provide most of the curvature shape. So just simple disassembly of rear cover will allow the rest of the TV frame to relax its curvature. Thats probably what fixed it but no idea which connection. 4x LEDs are edge lit.
      Maybe PSU->backlight connector didn't have a good contact?...
      07-23-2025, 12:34 AM
    • howardc64
      Samsung QN75Q6FNA backlight no display, red LED blink 2x, fault in panel
      by howardc64
      • Prior owner tried a replacement main board. No difference.
      • Samsung 2x red blinking standby LED = panel fault
      • Jumpered FB_TRDY_1 (pin 1 CN1300 left. main tcon->left side buffer boards) and FB_TRDY_3 (pin 95 CN1301 right. main tcon->right side buffer boards) This allows testing individual T-Con (on main board) connection to panel on this Samsung. Found fault on left side (viewing from rear of TV)
      • Each side has 2 buffer boards, disconnected left side flex between 2 buffer boards. Fault is on the left most board.
      • Tape masking eventually isolated to CN1300 pin 15 (CKV4_GOA) Display
      07-19-2025, 10:54 PM
    • Ierwin
      by Ierwin
      05-13-2025, 03:31 PM
