Sony KDL-32M3000 ghosting
  • tech2014
    • Aug 2014
    • 807
    I have a Sony Bravia with strange symptoms. It is an LCD TV and it appears to have ghosting, or trails behind anything that moves on the screen. Is this a main board issue or a bad panel? Here are some pics of the TV screen. I haven't opened the tv yet. I want to know if its a panel problem before I waste any time on it.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Sony KDL-32M3000 ghosting
    What Tcon is in this ? I had a different Tv with failed Gamma Ic on the Tcon was causing very bad ghosting like this.
    • tech2014
      • Aug 2014
      • 807
      thanks for the quick reply. I will take the tv apart and take pics.
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        Ok mate
        • tech2014
          • Aug 2014
          • 807
          Here is a pic of the t-con and the inside of the tv
          • tech2014
            • Aug 2014
            • 807
            anyone???
            • tech2014
              • Aug 2014
              • 807
              so nobody has any idea what would cause this.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                I would say either mainboard or panel tabbonds.
                • chrismurphy
                  • May 2014
                  • 251
                  • australia
                  Tab bond issues
                  Take of the cover to the screen tabs and press each one to see if it changes ,if one does than the screen is the issue
                  I dont think this is a T-con issue
                  • Shinju
                    • Mar 2014
                    • 1239
                    You could try a new T-con but that looks like the typical Sony TFT LCD failure with the tab bonding.
                    Seeing that you only have one TFT ribbon cable coming out of the T-con makes it hard to test left and right screen integrity.
                    Very rare occasions the video output on the mainboard can cause LCD pixel text/picture bleed.
                    • tech2014
                      • Aug 2014
                      • 807
                      thank you very much!!! I also feel its a tab bonding issue. Is it worth trying to fix this or not? If it isn't reliable I would rather not waste my time.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        Worth a shot, I have sold Tv's that I preformed tab bond repairs on over 2 years ago not an issue. Also all the others I have done have been fine.
                        • tech2014
                          • Aug 2014
                          • 807
                          ok. From what I see in the service manual, seems very labor intensive. I have to remove all of the circuit boards. Wont be able to have tv on and press on tabs to find the one that is the problem.
                          • Shinju
                            • Mar 2014
                            • 1239
                            You can do break it down with all the boards intact, all you need to do is remove the front bezel and then remove the front metal shroud around the LCD panel and presto.
                            IMO its a lot of work but might as well give it a go if you already have it apart.
                            • tech2014
                              • Aug 2014
                              • 807
                              ok I got it apart, and now the screen looks fine. Should I put electrical tape on the tab ribbons? The tabs look fine. Also when I press on them there is no reaction on the screen.
                              • Shinju
                                • Mar 2014
                                • 1239
                                If you are not getting any change with the tabs its probably the embedded IC chip inside the ribbon cables attached to the screen.
                                At this point I would just button it up and call it, if the mainboard is cheap or T-con you could try those but at this point being a 32" cost of parts vs a new TV thats up to you.
                                I know with most sony mainboards they are not just plug in play you will need to update the firmware if applicable, enter the Service menu and make sure to select the proper panel type ect.
                                Thats all I got to offer for advice! Good luck!
                                • Shinju
                                  • Mar 2014
                                  • 1239
                                  Can also try Freeze Spray or heat (hair dryer) the tabs up to see if that makes any changes.
                                  • tech2014
                                    • Aug 2014
                                    • 807
                                    I tried a hot air gun and freeze spray, and there was no reaction for either. Should I just put it back together and see if it works, or is it better to just call it a day on this tv.
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Push on the tabs when its on see if it makes an improvement.
                                      • tech2014
                                        • Aug 2014
                                        • 807
                                        after i took the tv apart to get access to the tabs, the screen is normal now. Pressing on the tabs had no effect.
                                        • Cheesesteak
                                          Sony XBR-55A8G 4K OLED image ghosting/jumping around
                                          by Cheesesteak
                                          Hello All,
                                          Hoping one of you wizards might be able to help me, I'm new to TV repair, I'm trying to troubleshoot a ghosting/jumping image on a 4k 55in Sony XBR-55A8G OLED TV.
                                          I have tried re-seating all cables, and lightly manipulating the cables while the TV is on to see if the picture changes with pressure on any of the cables/connectors. I also replaced the TCON board and the ribbon cables connecting the TCON board to the panel, the issue has not changed with the replacements or with any cable manipulation / re-seating.
                                          I saw some people had success...
                                          04-18-2022, 04:35 PM
                                        • Carlos#2003%
                                          Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                          by Carlos#2003%
                                          Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                          02-15-2024, 07:52 PM
                                        • samolo75
                                          Sony 49XE8096 intermittent ghosting
                                          by samolo75
                                          I started posting in a different thread and I was told it was not the best ans the tv model and the fault did not match. I am copping here what I wrote.
                                          After starting the TV it works ok for a few seconds and then starts showing ghost image with horizontal lines intermittently (except the very top). The frequency of the ghosting is steady, like every second or so, it goes from normal to ghosting every second and back.
                                          The TV is a 49XE8096. I already did quite a lot of trouble shooting. And I got the doubt if the problem is in the panel or de Tcon.
                                          When disconnecting...
                                          02-04-2021, 01:10 PM
                                        • dkneyle
                                          Sony KDL-46HX850 Can't upgrade/update firmware
                                          by dkneyle
                                          Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                          Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                          09-25-2024, 10:44 PM
                                          Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                          This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-06-2024, 05:27 AM
