Finlux TV/DVD 22F6072-2 Will Not Work With Remote Control
  • AlbertRoss
    • Jul 2012
    • 181
    • United Kingdom
    I have a Finlux TV/DVD 22" that will not work when using remote control. Have replaced the original remote control batteries, also purchased another Finlux remote but still unable to get the t.v working using remote?
    Apart from this problem, the t.v works fine but am stuck on what to check next?
    Thanks.
  • CapLeaker
    Leaking Member
    • 8182
    Re: Finlux TV/DVD 22F6072-2 Will Not Work With Remote Control
    check the little IR board on the TV. Maybe there is a shorted cap on the board, a bad regulator, or a bad IR receiver.
    • AlbertRoss
      • Jul 2012
      • 181
      • United Kingdom
      Have checked the caps and resistors.
      R1-99.9R
      R2-56.1R
      C1-2.5uf
      C2-2.5uf
      C3-2.5uf
      C4-0.14uf
      C5-0.14uf
      C6-0.14uf.
      Not sure on how to check the IR1?
      • CapLeaker
        Leaking Member
        • 8182
        IR1 has a GND pin an 5V input pin and a output pin. Check if the 5V or so are there and if that is o.k. hook up your DMM or better yet a oscilloscope to GND and the output pin. Take the remote and press a button. You should see pulses.
        • AlbertRoss
          • Jul 2012
          • 181
          • United Kingdom
          Do not have oscilloscope so hooked up DVOM between ground (center pin) on IR and 5v output pin, pressed remote and voltage dropped to around 4.7V. Also did this test at the 5 pin connector (IR to AV Board) same result so seems as if the IR sensor is working o.k?
          • CapLeaker
            Leaking Member
            • 8182
            When you test the IR sensor with a DMM, you should see a constant DC voltage. Once you press a button on the remote, the voltage should "jump around" a little bit. If it does, the IR is good and there is a problem on either the wiring or on the main board.
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              More common issue is the firmware messes up and the Tv wont log the IR board when on. You need to re-flash the firmware onto the actual Spi flash Ic rather than Via Usb.
              • multimeter
                • Jan 2011
                • 739
                • united kingdom
                if you have replaced batterys and have a phone with camera function,look at the IR sensor on the remote through the camera, if its working you will see it flash like a torch when pressing the buttons,also could be firmware/flash corruption on the mainboard
                fixed so far...376 lg lcd tv's,24 onn tv;s,24 panasonic lcd,16 jvc lcd,12 marshall jcm800 amps,refurb of various disco equipment lighting,old style disco decks ,and a flymo!
                please let us know if everything works ok if your tv gets fixed, as it will be and aid for anyone else having the same problem and wishing to fix it.it would save people clogging up this site with topics that are duplicated,and can be found easily using the search function.,and taking up valuable space.enjoy your fixed tv!,hopefully!
                • AlbertRoss
                  • Jul 2012
                  • 181
                  • United Kingdom
                  Tried the original remote with new batteries using the camera method, there was no flash so did the same test on the new remote and this time I saw a flash. So far I'm unable to find any firmware download for this main board (17MB82-2) also unable to find a replacement board, the closet I can find is for a 24" and 32" so not too sure if this would work on my 22" t.v?
                  There are a few boards for the 22" but they only have one HDMI socket?
                  • piipo
                    Old Privileg 5.1 speakers remote control question
                    by piipo
                    Hi, I have an old Privileg brand 5.1 speakers. I have lost the remote control. I have an universal Harmony remote but there is no Privileg brand in it's software to add. Does anybody have an idea what alternative brand for a remote can I try instead? I'm attaching an image of what the speakers looks like. The image shows 2 main speakers, they are 5 + 1 in total. Thank you very much
                    09-18-2024, 01:55 AM
                  • hemant_2222
                    Schematic for Denon Remote Control RC1156
                    by hemant_2222
                    Hello Everyone,
                    Hope everyone is enjoying their repairs at hand!.
                    I am looking forward to get the schematic of Denon remote control RC1156. Actually long time no use of the remote leaked the battery thereby corroding few parts as well as the tracks.
                    I was able to join few of them but the remote is still not working, so i am looking forward for your help, in case anyone understand the schematic or the remote circuit diagram and could me assist me in repairing it.
                    Please refer to the attached picture, i think the voltage divider is missing...
                    10-06-2023, 02:05 AM
                  • wolf1976
                    wireless receiver for 6 speeds fan control with remote control
                    by wolf1976
                    hi i have a receiver that is destroyed from the overvoltage i guess
                    my question is has three wires u v w for driving a motor fan i found an other receiver wireless from aliexpresss with the same propertiew but for dc motor
                    the motor fan has not label
                    i have an other receiver operational
                    In your opinion can i measure the voltage at the output ?
                    what do you suggest me with a simple instrument multimeter or using someone instrument more specific ?
                    thanks in advance...
                    07-23-2025, 03:12 PM
                  • t4796
                    Fujitsu Aircon remote control
                    by t4796
                    I managed to drop this recently. It fell flat and square onto the floor from about 1.8m. Can't remember if face up or face down.
                    The remote still kinda works but the display is blank and only shows up if I repeatedly flick the little silver crystal/oscillator looking thing on the board.
                    Not sure if this part is the culprit or if flicking it is moving something else, but it seems localised to that component as far as I can tell.
                    Having trouble working out the value of it since it doesn't seem to have anything other than a brand name printed on the side of it....
                    01-03-2025, 11:24 PM
                  • LordJohn
                    Opel Zafira remote control missing resistor
                    by LordJohn
                    Can someone help me with either diagram for the IC on the attachment, diagram of remote control it self or the value of the missing resistor liked to pin 4 on the IC in the attachment.
                    I will restore the ripped traces, but the remote still be useless without this resistor.
                    Thanks in advance....
                    01-24-2023, 07:42 AM
