Last TCP50G20 i will be working on.
+ More Options
Posts
  • Tech 57
    • Aug 2014
    • 37
    I tried to rebuild the sc board 30 parts and pow flash of light it's done
    Might have a bad panel or some other boards at fault.When I got into repairing this board the foil traces were burnt where the transistors on the heat sink
    were.should of known.Guys on the forum here had some good luck at repairing these.Guess this TV had more problems then i bargained for.
    The next TV I get in here for repairs maybe not so many problems.
    Happy Valentines Day!
  • tw2005
    • Oct 2011
    • 6458
    Re: Last TCP50G20 i will be working on.
    Well it would have been nice if you gave us some pictures and a list the bits you replaced. That's a lot of parts.
    can't say I've had burnt traces except when I bypassed the sos6 cct thinking it was ok and had a shorted SMD diode I missed. that cooked the board and trace.
    Was the board a virgin?
    • flocko
      • Nov 2012
      • 1121
      the problems I have found with the boards that have ended up with me after a few failed repairs, is that when the heat sink components are removed. the small front to back solder sleeves come away with the component as the board is twin sided, then when the new part is fitted there is no connection between both sides of the board. this does not show when testing as this would be done on the solder side of the board. Flocko
      • tw2005
        • Oct 2011
        • 6458
        How often would you fail though? Or are you referring to other peoples attempts and the boards are damaged?
        • flocko
          • Nov 2012
          • 1121
          no talking boards that I have had sent to me after failed repairs. I always get the same tale I changed all the parts again and it blown once more? when I get the boards and check the parts that should connect from front to back there is no connection. as the sleeves are missing the components are only connected on the back, you can change the parts over and over but if they are only connected to the back side of the board they will keep blowing, and as you know take more and more parts with them
          • tw2005
            • Oct 2011
            • 6458
            It'd be interesting to have a collection photos of the worst examples .
            Would take a bit of doing to destroy those. I was pretty rough in the beginning and came close on the very 1st board after 5 goes.
            • flocko
              • Nov 2012
              • 1121
              I dont think it is that hard to damage these boards. if you remove components using a pulling force on them from the front as you heat the three legs, its not that hard to pull the the sleeves out and miss the fact, thinking its just solder on the legs, then when you fit the replacement there is a void were the sleeves should be and the solder only takes on the back of the board and cannot flow to the front so no connection is made, normal testing will not show this as most of us will test from the back and any component tested would test to be good, but any connection to the front of the board is missing
              • Tech 57
                • Aug 2014
                • 37
                I do have one more sc board I am working on
                It's a TNPA5175AB see how this one goes.
                Some good tips about checking the double sided connections when you solder.
                This has no burnt foil traces like the other one.
                Keep you posted how it turns out.
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • Hakuu
                  by Hakuu
                  Hi There,
                  More Details
                  TV Model - LG OLED77G1PUA
                  07-12-2023, 02:37 PM
                • jb_Bak
                  by jb_Bak
                  CN6401
                  Pin 01 NC
                  Pin 02 NC
                  Pin 03 "BL_ON": 0V
                  Pin 04 "N/C"
                  Pin 05 "STBY 3.3V": 3.5V
                  Pin 06 "GND": N/C
                  Pin 07 "AC_OFF"...
                  09-27-2021, 04:52 PM
                • canadaboy25
                  Panasonic TC-P54VT25 No image. A or D board?
                  by canadaboy25
                  I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                  The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                  I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                  01-17-2021, 01:06 AM
