Pioneer lx6090 2 x flashing red light at start up
  • kamei10
    • Feb 2016
    • 44
    • Belgium
    Hi since today my pioneer don't start up anymore. When it in standby the red light work and when i power up the tv with the remote control you hear the click as usual but there is no image, the blue led will also not go on but the red standby led flashing 2 times.
    Somebody have a clue what is wrong with the screen and is it easy to repair it as i love the screen, hope to get it repair as it is still the best tv i have had.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Pioneer lx6090 2 x flashing red light at start up
    Nice Tv wait for Tom66 to chime in he will help you out, but if you get stuck DO NOT BIN IT OR SELL IT well worth waiting and spending money it to repair. I think two red blink is a fault on the Ydrive board. You can start by uploading images of the boards inside the Tv please.
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      Link to service man:
      • kamei10
        • Feb 2016
        • 44
        • Belgium
        Hi, thanks for the fast reply , first i need to get this tv upstairs to put it on a table where it can be for a time for repair as i probably need to order one or more parts and it should be not fixed on one day.
        I can buy another lx6090 but i dont know the problem on the screen, but maybe for parts if the panel is faulty.
        There is a line on the screen in the left corner at the downside of the screen, should it be a faulty panel or also a problem with some of the cards, search a lot for finding this problem in forums but nothing found from a pioneer with this problem
        http://i67.tinypic.com/2gwx1fd.jpg
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Normally just a lose connector going to the panel will cause that on the other one Keep us updated.
          • kamei10
            • Feb 2016
            • 44
            • Belgium
            OK i will keep you updated. Have this type also the trap switch or are these switches only in the older types ?
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              No they dont buddy.
              • kamei10
                • Feb 2016
                • 44
                • Belgium
                I have tried to mesure the values like on this thread https://www.badcaps.net/forum/showthread.php?t=43882
                I have opened the back and did the mesures but i didn't mesure anything, you can hear some noise from the psu. When i took out the y drive connecter it still the same, no values and the psu make the same noise.
                When i put the power on with the y drive disconnected the red flashed 3 times instead of 2 and also the intern red led (i think on the mainbord)
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Ok so with Ydrive disconnected you dont get any Vsus at all ? Also these sets when they lock out into an error show a red Led on the mobo and when Ydrive is disconnected from the Psu tv flashes 3 Red because it detects Ydrive isnt plugged in.
                  • kamei10
                    • Feb 2016
                    • 44
                    • Belgium
                    No, i have no Vsus with the ydrive disconnected, there is only one led on the mobo that will flicker the same times than the red led outside on the front
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Ok what about when Xdrive is unplugged ? Does it rise for a second ?
                      • kamei10
                        • Feb 2016
                        • 44
                        • Belgium
                        Now with both disconnected it doesn't go higher than 20VAC , the same as with both connected but the right power board from the psu where the main voltage is connected to is still making a noise sound when powered up.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Ok so with Xdrive it was 0 ? Also plug Ydrive back in and check what it goes too.
                          • kamei10
                            • Feb 2016
                            • 44
                            • Belgium
                            I tried again and with the ydrive alone connected it stay at 0 VAC,
                            With the xdrive alone connected 20 - 25VAC
                            With both disconnected around 20 - 25 VAC
                            With both connected stay it at 0V
                            Maybe is my multimeter not fast enough to read as the other person could read 208V on the points, so should the ydrive assy need to be replaced ?
                            The numbers on the board are:
                            ANP-2214-B and AWV2541-D-60F
                            Should these boards works also from a lx5090 as it is only a stamp on the board with 50 or 60 on
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              Ok before you do, do you know how to check for S/C and does your meter have a diode mode ?
                              • kamei10
                                • Feb 2016
                                • 44
                                • Belgium
                                what means S/C , yes multimeter have a diode mode, its a fluke
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  S/C means short circuit, look up on youtube how to test transistors for short circuit might be worth going over the Ydrive and Xdrive testing the big transistors on them they normally fail first.
                                    You need to use Vdc not Vac mode.
                                    • kamei10
                                      • Feb 2016
                                      • 44
                                      • Belgium
                                      OK, i will try again than this evening
                                      • kamei10
                                        • Feb 2016
                                        • 44
                                        • Belgium
                                        I measured now on VDC and have following measurements:
                                        - With Ydrive connected 0V
                                        - With Xdrive connected 210V
                                        - With X and ydrive connected 0V
                                        - Vadr 75VDC
                                        Do i need to discharge something to take out the ydrive plate and for measure the transistors ?
                                        • 7ony
                                          Samsung plasma - flashing standby light
                                          by 7ony
                                          The TV is a 2013 Samsung plasma, model # PN60F5300AFXZA.
                                          Snagged it up in non-working condition a couple years ago. Previous owner said that sometimes he could get it to come on after repeated tries but other than that he couldn't get it to turn on.
                                          Personally I haven't been able to get it to turn on at all. The standby light comes on solid when plugged in, but pressing the power button results in the standby light flashing once every 4 or so seconds. No "click" noises, no light from the panel at all. Just the flashing standby light.
                                          No visible...
                                          08-31-2020, 05:18 PM
                                        • Bloopeta
                                          Samsung UE43KU6400U Flashing Red Standby Light
                                          by Bloopeta
                                          Have a Samsung UE43KU6400U that will not turn on, just continuous flashing red standby light.
                                          Power button does nothing
                                          Have unplugged the mainboard, and backlights illuminate.
                                          Have tried removing panel ribbon cables one at a time, and that makes no change.
                                          With mainboard unplugged, all voltages from powerboard seem ok, but with mainboard connected, they never quite reach full voltage, and drop and raise in a constant loop (in time with click noise from mainboard.
                                          Using backlight tester, I get 63.6v on both sides, so seems like no bulbs...
                                          09-11-2023, 02:34 AM
                                        • fuxxy
                                          Samsung UN55D6000FXZA - Won't stay on, standby light flashing rapidly
                                          by fuxxy
                                          This is a set I posted about a few years ago. Replaced LED strips and worked fine until now.
                                          Plug the set in, and it will turn on and functions with no issues.
                                          After a while, (sometimes hours, sometimes minutes, sometimes immediately) the tv shuts off. When I approach the TV I notice the standby light is flashing rapidly, but the pulse of each flash is not long enough to notice from afar.
                                          Other than the standby light, the unit is completely unresponsive until the power is removed and reapplied, then the cycle starts over. It does appear that the time it takes...
                                          08-02-2022, 09:44 AM
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
                                        • esqmooo
                                          HP Elitebook 845 G8 dead, only caps lock flashing 7 times. Charging light always on
                                          by esqmooo
                                          Hello everyone.
                                          This is my development machine. I've been using it since two years and half without any problem except sometimes it wouldn't wake up from sleep.
                                          Lately the issue became more frequent and powering it up would take few seconds to show the POST screen.
                                          Then the computer refuses to power on at all. Now only the caps lock button flashes 7 times then stops. The charging light is always on whenever a power source is connected (battery or charger).
                                          I tried long pressing on the power button, after several seconds it would go off then when the button is released...
                                          03-11-2025, 03:57 PM
