Lg 50pm6700 horizontal bands.
  • Malachi
    • Dec 2015
    • 1077
    • Usa
    I purchased an lg 50pm6700 for $20 that was new but with a cracked screen.
    I did my research and by the panel number I found it is the same as the 50pa6500.
    I found one on Craigslist that I traded some stuff for. Seller said the display was perfect up till the time it wouldn't turn on.
    I brought it home, took the back off and found the only difference between the two is the A board or video board, not sure exactly what it is called.
    I swapped them out, still wouldn't turn on.
    I took the power supply out of my new, cracked screen tv, and put it in the other one.
    The TV turns on but there are 2 bands at the top of the screen. Can anyone give me any advise?
    I also changed a board from the top left, I think it's called the buffer board but no change.
    I have extra of every part except for the psu.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Lg 50pm6700 horizontal bands.
    Change the Ysus board from the smashed one.
    • Malachi
      • Dec 2015
      • 1077
      • Usa
      Lol which one is that? The one the buffer board is attached to?
      • ReeceyBurger123
        Never Give Up !
        • May 2014
        • 7325
        • Britain
        If not run the test patterns, by removing Lvds cable (flat cable from mobo to control) and jumper the two pins on it and turn the Tv on.
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Its the one that the buffers plug into.
          • Malachi
            • Dec 2015
            • 1077
            • Usa
            I have no idea what that means. Sorry I am a 48 year old newb.
            • Malachi
              • Dec 2015
              • 1077
              • Usa
              I changed the Ysus board, now I have no picture at all.
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                Ok, is everything in properly and is the board number the same ? Make sure all the screws are in too !
                • Malachi
                  • Dec 2015
                  • 1077
                  • Usa
                  The ebr number on the Ysus are the same, the number below Ysus is different.
                  I will put all the crews in. I only had 1 in to hold the board in place.
                  Does it make a difference?
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    Yes lol, not having the screws in can kill the Ysus ! The screw holes are used for local ground can be catastrophic if you dont have them in.
                    • Malachi
                      • Dec 2015
                      • 1077
                      • Usa
                      Still no picture. Just sound. Should I put the old Ysus board back in?
                      • Malachi
                        • Dec 2015
                        • 1077
                        • Usa
                        Both Ysus boards are number EAX64282201
                        • Malachi
                          • Dec 2015
                          • 1077
                          • Usa
                          Put the old Ysus board in, now it's worse.
                          • Malachi
                            • Dec 2015
                            • 1077
                            • Usa
                            Put the original Ysus board in, the one from the first picture with the band across the top, now it looks like the bottom one.
                            Tried it all again. Ysus from smashed board, no picture just sound.
                            Original Ysus, the last picture I uploaded.
                            Changed the buffers, no change with eithe Ysus board.
                            Do I need another Ysus board?
                            The smashed screen tv would power on with sound and no picture, I figured due to that cracked screen but I guess it could have also had a bad Ysus board?
                            • Malachi
                              • Dec 2015
                              • 1077
                              • Usa
                              This is what it says on shopjimmy about the first buffer board I replaced
                              DO NOT REPLACE THIS BOARD WITHOUT ALSO REPLACING THE YDRVBT AND YSUS BOARDS! If you replace this board alone, it WILL fail again.
                              Could that be part of my problem?
                              • Malachi
                                • Dec 2015
                                • 1077
                                • Usa
                                Should I trash it?
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  No why trash it when its possibly fixable ?
                                  • Malachi
                                    • Dec 2015
                                    • 1077
                                    • Usa
                                    I don't know what to do next.
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      Do you have a DMM ?
                                      • Malachi
                                        • Dec 2015
                                        • 1077
                                        • Usa
                                        No, I only have an analog meter.
                                        I do have double of all boards except the power supply. I've already tried the control board and that didn't help.
                                        • howardc64
                                          by howardc64
                                          07-24-2025, 05:17 PM
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • fredtred
                                          Physically bending the T-Con board creates horizontal dotted lines on OLED55CXPUA
                                          by fredtred
                                          Hello!
                                          I have been trying to solve this issue the past 12 months to no avail. I have been a lurker here during that time but finally decided to post my problem and see if anybody knows a solution.
                                          Problem
                                          My tv (OLED55CXPUA) has an issue where it displays horizonal lines of dotted artifacts.
                                          (See Attachment 1)
                                          Self Diagnosing
                                          After a very long troubleshooting period I traced the issue to the T-Con board. If I gently flexed/bend the board I could make the display go from GOOD to BAD and vice versa. I have ruled out the connectors/wires...
                                          10-29-2023, 01:09 PM
                                        • rstrube
                                          ViewSonic Pf815 (branded as P225f) Horizontal Deflection Issues - Running out of Ideas
                                          by rstrube
                                          Note: apologies I initially posted this request for help in the wrong forum! I am reposting it here and will take down the original posting.
                                          Hi Everyone,
                                          I've been working on repairing this beautiful CRT monitor off and on for the past several months and I'm really at a loss for what might be causing the problem.
                                          Unlike other common Horizontal Deflection issues which result in a steady vertical line, when I turn the monitor on, there is a pulsing (somewhat segmented) vertical line. I've attached a photo that shows the issue (difficult to capture without video)....
                                          Today, 01:37 PM
