Panasonic TH-42PX80U PSB
  • whiz62
    whiz62
    • Dec 2013
    • 242
    • usa
    I picked this up the other day and someone had already removed Q406 from power board. My question is if anyone would know if the screw for the transistor would have had a nylon insulator. Also found an open ceramic cement resistor that was open and wondering if it is ok to use a 10 ohm 10 watt axial instead of what the picture shows. Thanks.
  • Alastair E
    Chief Womble
    • Mar 2013
    • 1963
    • U.K.
    Re: Panasonic TH-42PX80U PSB
    Resistor in pic has thermal fuse inside along with resistor. A correct one should be obtained and fitted for Safety Reasons.
    --A straight 10 ohm wirewound can be used to Test the set--but then the correct part fitted.
    As to whether the screw needs a washer--All depends on the Transistor....
    TELEFIX
    • tw2005
      • Oct 2011
      • 6458
      If it's replaced with the original casing type, no but if definitely needs the insulating silicon pad behind it or you will have a dead short.
      RJK5020 may have been what was there
      • whiz62
        whiz62
        • Dec 2013
        • 242
        • usa
        Thanks for the reply Alastair E. Will try and locate resistor. Looking at transistor and screw closely, there is no room for insulator to fit into through hole.
        • whiz62
          whiz62
          • Dec 2013
          • 242
          • usa
          Thanks tw2005, There is some kind of thin sheet insulator on the heat sink as shown in the pics.
          I also think I found the resistor I need from Mouser, # 588-TWW5J10RE. Looks just like the one on the board. But it did not say anything about being thermaly fused.
          Thanks guys!
          • whiz62
            whiz62
            • Dec 2013
            • 242
            • usa
            Got the parts installed today and all is well. Now I will order the correct 10 ohm resistor. Thanks guys for your input.
            • jinu_j
              by jinu_j
              Hi
              05-03-2025, 10:51 PM
            • mikey5791
              Need help to replace burned resistor in 350w atx psu
              by mikey5791
              Hi to all forum members,
              Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
              The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
              Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
              Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
              12-26-2024, 04:55 AM
            • MidnightRoller
              Can a resistor lose resistance after hot air?
              by MidnightRoller
              I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
              I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
              02-02-2022, 11:46 PM
            • artvandalai
              What resistor ohm will work better to repair this waterpik?
              by artvandalai
              The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
              01-05-2025, 04:10 PM
            • BigPete
              Panasonic Heatpump Dryer Repair
              by BigPete
              I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
              The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
              In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
              Unfortunately the whole machine has to come apart to fix it.
              I have...
              11-01-2025, 06:40 PM
