17PW82 No Standby Common Repair
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: 17PW82 No Standby Common Repair
    Yep I enjoy fixing Tv's tbh even though some are a pain Ive got alot of other projects I need to finish too but too much on with Tv's atm lol
    • tvguy12012012120
      by tvguy12012012120
      02-07-2025, 05:13 PM
    • cheeky2
      LG 42LG3000 Strange fault will not go into standby!
      by cheeky2
      I have this LG 42LG3000 Tv which operates on all inputs without any issues whatsoever. However when you try to turn the Tv off the screen goes blank as it would normally however it then turns itself back on again!
      So far I have replaced the main board without any resolution to the problem.
      When the inverters master and slave VIT71053.54 VIT71053.55 are disconnected from the power supply then the TV will turn off as it should (obviously without any ccfl output).
      I have read through a few posts for this model without anyone having this issue as far as I can tell.
      I...
      05-04-2021, 06:02 AM
    • Fredrik_Bostrom
      LG 60PK250N ZA No picture
      by Fredrik_Bostrom
      To start with I think I have red every single topic on this forum about the No picture fault on this TV. Seems like a common fault but I just can´t find a match i other forum threads for my TVs fault.
      Symptoms:
      No picture, not even a little primer.
      Unable to check if I have sound since I don´t have any picture to navigate the menu to be sure I´m on the correct input.
      When connecting power cable it clicks just like it used to and the red standby light on the front comes on.
      When pressing the power button on the front it clicks like it´s...
      01-25-2024, 02:03 AM
    • psssst
      Yamaha TSX 120 Standby Problem
      by psssst
      Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
      03-01-2024, 07:25 AM
    • fharris1977
      Vizio D50u-D1 Dead Set No Standby
      by fharris1977
      Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
      12-28-2023, 10:25 AM
