lcd tv not getting 5v on p/s out but reads 4.6 instead
  • tpny
    • Feb 2016
    • usa
    hi, i have an lg 37" lcd about 10 years old. when power cord is plugged into wall the led on the front housing lights up red, but tv won't turn on when i press the remote or button on the housing. the p/s board has a "P-ST-5V" pin on one of two ribbon connectors going into the mainboard; if I unplug these connectors thus isolating the p/s board, I can read 5V on my digital multimeter on this "P-ST-5V" pin.
    Now I unplug every port on the motherboard and only plug in the two connectors from the p/s, "P-ST-5V" now reads 4.6V on my meter. And I cannot turn on the TV. Is this my problem? Is it correct to think that I should see a steady 5V at this pin even it's plugged in? If this is my problem should I look in the p/s board for the faulty component(s) or mainboard? I want to think mainboard since I am using a newly replaced refurbished p/s board but you never know. Please offer some input, thank you very much!
  • sordids999
    • May 2013
    • 2161
    • uk
    Re: lcd tv not getting 5v on p/s out but reads 4.6 instead
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • CapLeaker
      Leaking Member
      • Dec 2014
      • 8326
      If you unplug the main board from the PSU, it in return will not power up, unless you force it on with resistors.
        Originally posted by sordids999
        posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
        +1
        How about the model number of the TV?
        • stylishconsultant
          un60j620dafxza - Samsung No Display Problem
          by stylishconsultant
          Hi All,
          Need help.
          I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
          So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
          problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
          might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
          09-04-2024, 03:26 AM
        • orcic
          MASTER TL240 and new mainboard LW36BKC01
          by orcic
          I have an old MASTER TL-240 LED TV. Since it stopped working and it had a DVB-T receiver that is being dismissed in Italy, I've decided to replace the mainboard with a DVB-T2 one.
          The original problem was that when switching on the TV, the power LED was transitioning from red to steady blue, without showing video or audio.
          After checking some voltages on the power supply board (HKL-240101-B Rev. 1.4, HKL from now on) someone suggested me to replace the mainboard.
          Now I have some doubts about how to connect the new mainboard to the old power supply.
          First of...
          05-12-2023, 08:10 AM
        • Malva
          Problem LG 49UB850V (Mainboard: EAX65684604 / EBT62954607)
          by Malva
          I'm trying to repair my LG 49UB850V TV (WebOS 1.0, UHD model from 2014).
          Mainboard model: EAX65684604
          PCB marking: EBT62954607
          SPI chip: Winbond W25X20CLNIG Problem description:
          Originally, the TV would turn on (backlight and LED OK if I force them on), but it shut down as soon as any input was received from the IR sensor or remote. The backlight and power board were working fine.
          After testing and verifying the voltages (DRY ON, PWR ON, 12V/24V rails), I suspected a corrupted SPI firmware. What I tried so far:
          • I bought another
          06-25-2025, 02:07 PM
        • l0lhaxz1
          QN65QN90A - Mainboard MLCC failed - now bootloop
          by l0lhaxz1
          Hi
          I have a QN65QN90A which was purchased around launch I guess making it about 1.5-2 years old... had been working fine until a few days ago, simply went black and would no longer turn on (at all). No standby light and no typical PSU relay click etc. Absolutely dead.
          Pulled it apart without doing much research first, suspecting the power supply as it had a faint buzz (I guess due to the forthcoming found short), investigated PSU for some time and concluded there was no fault that I could spot with the board removed.
          Came to learn after a bit more research...
          02-06-2023, 08:59 AM
        • CapLeaker
          Crimping CAT7 connectors high failure rates
          by CapLeaker
          I’ve had and got a few projects using quality CAT6 and CAT7 23awg solid copper, shielded, direct burial cable. Each time I use CAT7 connectors, most of them fail making good connections to the 4 wire pairs after crimping. I tied a couple of crimping tools, thinking my crimper is bad. Also used different CAT7 RJ45 connector manufacturers. Same thing. I kinda calculate 6 connectors to make one cable!
          Get this: I use CAT5 or CAT6 connectors, no problem. Very rare I have a miss crimp with those. So what gives?! ...
          11-09-2024, 04:11 PM
