Philips 42PFL9664/12 blury picture lousy refresh rate
  • DrazenJ
    • Jan 2016
    • 11
    • Croatia
    Hi!
    I have problem with my Philips tv set.
    For a start there was a picture only in the upper most part of the screen (some 1 cm wide)and the rest of the screen was dark.
    I have clean the contacts and find out that when I have disconected left t-con control I've got picture on the right side of the screen.
    Searching trough the Internet I saw solution where you place small ammount of the tape over the gold contacts of the t-con flat cable (ca 5mm) and I have got picture on the left side of the tv as well!
    But the problem is that the refresh rate on the left side is horrible now. You can see previous picture of the menu for e.g. on the picture I've took.
    Can someone point me where to Search for a fault?
    Btw there is not reported errors in the service menu of the TV set.
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Re: Philips 42PFL9664/12 blury picture lousy refresh rate
    Take the frame of the Lcd module off and press on the tab bonds see if it clears up. Look on youtube for tab bond repair.
    • DrazenJ
      • Jan 2016
      • 11
      • Croatia
      I did that! Nothing has changed. I saw that solution as well but it did not helped in my case. There is not a single change when playing with a tab bonds..
      • CapLeaker
        Leaking Member
        • 8147
        I also would say it is the tab bonds or something with the ribbon that does the left side.
        • DrazenJ
          • Jan 2016
          • 11
          • Croatia
          Thank you for inputs.
          Here is an update.
          From the t-con board there is a some noise sound which is present only when both flat cables are connected.
          As soon as I disconect faulty side flat cable the sound is gone.
          The sound is comming from the low voltage regulator ld1086-18. It looks litlle bit burned as well..
          So now I will measeure a voltage comming to tcon for First or do you have any other suggestion?
          • DrazenJ
            • Jan 2016
            • 11
            • Croatia
            Voltage between regulator pins are as follows:
            33 V between pins ,
            15 V between input and output
            18 V between output and ground.
            Well as far as I found is that the maximum input voltage should be 30 V so does it mean I have to high voltage on the input and way to high voltage on the output?
            Tnx in advance
            • Rauni
              Philips 58PUS7805/12 showed no picture; after T-Con replacement, shows halo
              by Rauni
              Hello, this is my first post on this forum, and my first attempted to repair a TV.
              My Philips 58PUS7805/12 stopped working recently. It is not that old, about 5 years. We were on a trip for a few days and when we came back, it had stopped working out of a blue (Perhaps our house was hit by a lightning strike? Don't know.)
              Read from a guide that I should test if the screen shows picture with one of the T-Con cables disconnected. Did that, it showed perfect picture (first on left, later on right side).
              Read also that we should test what happens if we...
              10-01-2023, 12:06 AM
            • Schwoin
              Philips 243v5lhsb00 Monitor Picture too bright
              by Schwoin
              Hey everyone,
              the picture on my philips monitor looks way too bright so that black appears grey and colors also seem too bright.
              While i tried to tilt the screen a little bit while it was displaying a picture, i´ve noticed, that there appeared some purple pixels. In the following picture
              you can see them on the top half of the photo.
              At a certain point during the tilting, the picture looked normal again but as soon as i laid it back down, the purple pixels were gone and the picture was bright again.
              03-21-2023, 12:40 PM
            • madyoyo
              Philips 37pfl560: Yellow picture
              by madyoyo
              HI.
              I have a weird problem with an old Philips 37pfl560 TV i put out of storage: the picture have a noticeable yellow hue, and its not caused by the settings (did a factory reset). I've never seen this before. I will try to get a photo with a real camera, with my phone its hard to see because of automatic white balance, but in real live the whites are really yellow.
              Anyone have an idea of what can cause this? Can CCFL tubes get "warmer" with time? This tv have several analog inputs,so its nice for retrogaming....
              05-30-2025, 10:16 AM
            • charlesdutcher
              No picture issue in Philips Chassis FTL2.1
              by charlesdutcher
              My Plasma Philips 37inch chassis FTL2.1 does not show picture. It automatically goes into protection mode after 30 seconds (red led blinks at 3Hz)
              Is there someone having any symptom like this? How to fix it?
              Thanks in advance!​
              08-06-2024, 09:55 PM
            • groomit
              Philips 50PUS7363/12 Backlight but no picture
              by groomit
              I'm having trouble with above mentioned TV. Bought it defect.
              Picture was heavily compressed around the horizontal axis. Fiddeled and tried different things (mask clock lines, swap T-Con). But no difference.
              Then I identified a heating capacitor on the left hand Signal-PCB (?) below the display. Replaced it by hand soldering. Checked for shorts afterwards. But now the screen stays black.
              I can see backlight, but screen stays black.
              What I've tried:
              - Disconnect right side cable from T-Con -> same (backlight but no pic)
              - Disconnect left side...
              11-22-2024, 02:43 PM
