LN-T4661F Lines
  • drunkwithpower
    • Oct 2015
    • 10
    LN-T4661F Lines
    My daughter has an old Samsung LN-T4661F with intermittent black lines (almost clouds) and pixelation running horizontally through the picture. The amount of lines fluctuates greatly but they tend to calm down as the TV heats up. Any ideas?
    I apologize in advance of the horrible quality of the pictures and videos - daughter's handiwork.
  • CapLeaker
    Leaking Member
    • 8327
    Re: LN-T4661F Lines
    tab bonds
    • howardc64
      by howardc64
      07-24-2025, 05:17 PM
    • Stanley1843
      by Stanley1843
      06-29-2024, 11:54 AM
    • jeyoung12
      Samsung QN50Q60t lines on screen
      by jeyoung12
      Hi all
      I have lines on the screen...which is an age old problem that can be remedied by watching Youtube videos and getting out the tape.
      My issue (after successfully fixing a different sammy tv with a separate tcon board and isolating the side of the panel...):
      This tv has an integrated tcon...so it is a bit more confusing when trying to isolate the clocks.
      It has a c ribbon and i have taken each end out to see if that will isolate the lines. instead, it makes it much worse ALL over the tv!
      So....i don't know what end of the C ribbon to work with...
      02-26-2024, 10:38 AM
    • Rubenlily
      Samsung QE50Q67TAU - horizontal lines
      by Rubenlily
      First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
      I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
      I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
      I'm no expert but I've done the tape...
      08-16-2023, 01:12 PM
    • visionbluedemon
      Help. Sony kd-65x85dj vertical lines
      by visionbluedemon
      First. it has no picture at all. i solved it by covering the ckv lines using tape to to block the connections
      Second. now has picture but with vertical lines that follow the image. tcon board ic overheating
      tried blocking LC lines too, but same results
      is it lcd panel issue or tcon board issue?...
      07-25-2025, 04:56 AM
