Quick help needed! This will take you less than 10 seconds!
  • EsTonInaToR
    • Feb 2016
    Plain and simple, a guy is selling a broken plasma tv for very cheap.
    I'm a student who's quite poor so if this is fixable at all it would be awesome!
    So please experts, just quickly tell me if this is fixable and roughly how much it will end up costing. I really only need a quick expert opinion on this.
    Here's the tv, he says he doesn't know what's wrong with it, but that the screen is NOT damaged:
    and here's a picture of the back, though I can't read any of it myself..
    Thanks in advance guys!
  • dcapper
    • Dec 2013
    • 496
    Re: Quick help needed! This will take you less than 10 seconds!
    Looks like a panel fault. Garbage.
    • goontron
      5000!
      • Dec 2011
      • 4108
      • US
      Panels screwed.... Trash!
      hey, 3 seconds flat!
      Follow the white rabbit.
      • EsTonInaToR
        • Feb 2016
        Perfect, you guys rock! Thanks for the help! Super timely too.
        • willis6732
          820-01949 - A2337 - Quick Fan Spin for a Few Seconds. Charging and Main Rails OK
          by willis6732
          This macbook wont turn on. Only a quick fan spin. Sometimes fans spin a few second. Somtimes they spin fast for a few seconds. Other than that no signs of life
          All the Coils on the board have voltage and battery charges fine as well.
          I noticed this not sure if it is suspicious:
          PPVCC_CPU_PH1 / CPUCORE_SW1 = 40 Ohms (Flex Bv shows 90 Ohms)
          =.023 Diode Mode (Flex BV shows .090)
          I would appreciate som support in the diagnosis.
          Th anks,
          K...
          06-14-2024, 08:15 PM
        • twonk9098
          Lenovo Legion 5 high fan spin turns off after 34 seconds
          by twonk9098
          I have a Lenovo Legion 5 with a Ryzen 7 series CPU and RTX 3070 GPU. My issue is that it turns on and all seems fine except after a few seconds the fans spin up high and the laptop turns off after 34 seconds.
          I can get into bios and can even boot and login to Windows however after 34 seconds no matter if Im at the bios screen or booted into Windows it will just turn off.
          I have managed to run HWmonitor and the temperatures of the CPU and GPU are fine, I can also touch the heatsync which is warm but not hot.
          I have tried a few new bios but exactly...
          07-14-2024, 11:19 AM
        • liquidzorch
          Lenovo 15iml05 Power led lights for 12 seconds then off 12 seconds
          by liquidzorch
          Hello. I bought a faulty Lenovo ideapad 3, but it turns out the 3Valw buck converter burnt a hole through the board. I was able to clean it up, and remove all the shorts. I now can power the 3.3v rails from a bench power suppy while connecting the laptop to its psu, and I get the additional 5valw, 1.8v, and 1.05v, form what I can tell in the schematics, those are the only 4 voltages I should see before turning on, and they are present. When I hit the power button, the power indicator on the left side turns on (not the one on the power button), stays on for about 12 seconds, then turns off for...
          10-18-2024, 05:19 PM
        • c_corr
          Asus P4C800-E VRM issues
          by c_corr
          This board had the initial fault in VRM with high side Mosfet from PWM1 (phase 1) getting very hot. It also had the VRM caps quicly heating up in 10-15 seconds after power on.
          This board uses mext ICs and Mosfets in VRM:
          - ADP3180 PWM controller - in 3 phase mode
          - ADP3418 as Modfet drivers
          - High side Mosfets STD38NH02L (from ST)
          - Low side Mosfets STD90NH02L
          Some of the symptoms were very similar with the "Dead Asus P5P800-VM" in this forum.
          I had the sawtooth voltage on Vcore too this was probably the cause of the Vcore caps...
          02-08-2025, 11:59 PM
        • PowellSkier
          Harman/Kardon AVR 645 returning to stand-by after a few seconds.
          by PowellSkier
          A Harman/Kardon AVR 645 repair has been a hobby of mine for the past several years. My latest attempt involved the purchase of a DOA unit for part swapping and testing. The original AVR would power up then shut down after a few seconds. I completely tore down both units, found a couple of bad components and reassembled one of them. Same issue, no speakers connected. After extensive research I found a repair document from Harman/Kardon that explains the protection circuit in fantastic detail and provides specific test points for each fault (power, DC detection, overload & power) and the voltage...
          06-17-2024, 11:43 AM
